Galaxy S6 EDGE - LAST Button Not Working: Lights Up, Back Button Fine, No Damage, Troubleshooting
danstario92 6225 10
Why does one touch button on my Galaxy S6 Edge light up but not respond to touch, while the Back button still works?
The most likely cause is a damaged touch layer/digitizer on that side of the phone, not a software issue. One reply suggests that using the phone heavily while charging can overheat the bottom area and damage the flex/wiring near the charger input, which can leave one capacitive button dead while another still works [#16650342][#16650356] Another reply states it seems to be a broken digitizer and recommends service repair; if the phone is under warranty, use that instead [#16650380]
  • #1 16650205
    danstario92
    As in the subject, the "last" touch button does not work for me. Lights up but doesn't work. I will add that the back button works fine. The telephone did not fall down and I did nothing with it. I turned the phone off and on and forced Touchviz to stop. Do you know what it might be ? Thanks in advance :)
  • #2 16650300
    ZEONpl
    Help: 5
    Could you send me a phone picture from the front?
    On the forum in the commentary and not on priv of course ;)
  • #3 16650321
    danstario92
    This is how it looks.
    I will immediately warn you that my phone has a cover ;)
    And the problem is that the button in the circle does not respond to touch (there is also no vibration when touched)
  • #4 16650342
    ZEONpl
    Help: 5
    It can be caused by unwanted software (some application) and the system tries to block it because it tries to gain access to the system.
    Tell me Do you have a Charger Input at the bottom or top of the phone?
    If at the bottom you probably played / played or used an application that consumes a lot of CPU, e.g. MESSENAGER
    and the phone has warmed up and in a place where it is connected it has overheated and the wire has melted it is very similar if the input from the charger is at the bottom of the phone.
  • #5 16650354
    danstario92
    In the middle at the bottom.
    I used the phone many times during charging (be it messenger, youtube or even pokemon go). It wasn't until yesterday that this button stopped working. And it is possible that only this melted, and from the "back" button no longer?
  • #6 16650356
    ZEONpl
    Help: 5
    Unfortunately yes I had this problem with SAMSUNG GALAXY Y I only had the bad luck that it worked for me to the middle button.
    It happened to me 2/3 years ago but still
  • #7 16650360
    danstario92
    So the only solution is the service? How much did you pay then?
    ZEONpl
    Help: 5
    I can't give you that, because I was planning to change my phone at the time, but I will search the internet for you
  • #9 16650376
    danstario92
    Thank you very much :)
    ZEONpl
    Help: 5
    It seems to me that this is a broken digitizer on the site joystick pl you can do it for 950 PLN best to contact by phone if the phone has a warranty then you know what to do GOOD LUCK :) .
    I think we can end the topic :)
  • #11 16650385
    danstario92
    I close the post
The discussion revolves around a malfunctioning "last" touch button on a Samsung Galaxy S6 Edge, which lights up but does not respond to touch. The user reports that the back button functions correctly and that the phone has not suffered any physical damage. Various troubleshooting steps have been attempted, including restarting the device and stopping the Touchwiz application. Responses suggest potential causes such as software issues or overheating due to heavy usage while charging. One user mentions a similar experience with a different Samsung model, indicating that the problem may be related to a broken digitizer. The conversation concludes with a suggestion to seek professional repair services, with a cost estimate provided for the digitizer replacement.
