Cracked Ceramic Tiles: Causes & Solutions for Opoczno 20x40 Tiles, Grout Delay, & Glue Thickness
sebaele22 46764 41
Why are my Opoczno 20x40 wall tiles cracking after installation, only showing cracks when wet, and is a complaint likely to be accepted?
Cracking is most likely caused by a combination of weak or poorly fired tiles, uneven adhesive coverage, and/or movement in the gypsum-board substrate, not just by having 5–10 mm of glue; 1 cm is not automatically too much, but if the comb grooves were squeezed out or the tile body is soft, the glaze can crack under stress [#16388956][#16851769][#16384892][#16387447] Check whether the cracks line up with the joint between two green plasterboards or another working point, because missing or wrong expansion joints and a moving wall can crack the tiles and may indicate a construction error [#16386753][#16386822][#16384929] One reply also noted that cracks appearing only on areas primed with unigrunt may point to the substrate/primer system, and the Ceresit CM 16 sheet calls for CT 17 on plasterboard [#16390843] If you want to claim it, document the wall build-up, take photos, and verify whether the broken pieces come from a bad batch or whether the tiles are simply soft/weak, because several replies say that makes a complaint hard to prove after installation [#16387486][#16389472][#16388956]
  • Cracked, warped Opoczno tiles and possible installation causes
    #1 16384715
    sebaele22
    Level 30  
    Rate: 513
    I apologize in advance for assuming such a topic on such a forum, but I know that there are various professionals who can help me. Well, two months ago I started to renovate the bathroom, most of the bathroom has already been done but without the grout. A few days ago, I noticed a vertical crack in the tile, and a few days ago, another crack in another. Today, out of curiosity, I wiped the tiles with a wet cloth and bumm, the enamel cracks appeared on a large number of tiles, which are not visible dry only after wiping with water. I have read a lot that it may be the fault of too high thickness of the glue, substrate, tiles, etc. Yes, there are more than 1 cm of the glue in some places, but there are also places that will be somewhere 0.5 cm and the tile is cracked anyway. I am going to file a complaint, but will it be recognized? I would like to add that the tiles are Opoczno 20x40 and not straight, but slightly curved (I checked by putting a spirit level on the tile and the center adheres, and the sides open to 0.5 cm on both sides).
    Please help.
  • #2 16384877
    mariuszkam
    Help: 8
    Rate: 71
    The larger the tile, the greater the unevenness on the tile. But that's the norm. Write the tiles on a wall and what glue was used.
  • #3 16384886
    sebaele22
    Level 30  
    Rate: 513
    Well, are only ceramic curves? Because I also have other larger ones and they are perfect, simple, but not ceramic, but also wall-mounted. Most of the tiles were laid on green drywall, and then it was primed. As for the adhesive, Ceresit CM 16 was used.
  • 19 mm adhesive is excessive; drywall needs expansion joints
    #4 16384892
    mariuszkam
    Help: 8
    Rate: 71
    You write that more than 1 cm of glue is a relative term, because it can be 11 mm and 19 mm. One cm or 10 mm is not too much glue. It all depends on the tiles, but 19 mm is an exaggeration.
    What's on the other side of the wall? I understand that the tiles have been touched?
    "Error 6 - forgetting about proper dilatation
    Expansion joints compensate for the work of the ceramic floor related to thermal expansion. They are required at the connection points of wall and floor planes, at the contact points of substrates or floors made of various materials, with large surfaces and underfloor heating. Lack of dilatation in these places or their improper implementation may [b] result in cracking of the structure and the tiles themselves and their loosening.
    At the beginning, plasterboard walls will "work", so it is important that the tiles have adequate expansion joints.
  • #5 16384925
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6438
    sebaele22 wrote:
    (I checked by putting a spirit level on the plate and the center adheres and on the sides there is a clearance of up to 0.5 cm on both sides
    What do you live in Iglo, what do you have 0.5 cm of arc on the tile?
  • #6 16384929
    bearq
    Help: 414
    Rate: 1616
    The problem is the working surface, as already mentioned by my colleague. The thickness of the glue is not of great importance here because the glue cracking would result in falling tiles.
  • Large tiles commonly have substantial center-to-edge warping
    #7 16384941
    mariuszkam
    Help: 8
    Rate: 71
    The larger the plate, the greater the "deviation" from the plane. A 60x60 tile can have a difference of even 1 cm in the plane, and this will be the norm. I have seen more than one such plate
  • #8 16385109
    sebaele22
    Level 30  
    Rate: 513
    The tiles have been arranged using crosses, so there is dilatation. On the other side of the wall are panels, paneling, and paint. 1 time I have encountered such crooked tiles, the wall looks like it is quilted, not straight.
  • #9 16385118
    technikabasenowa
    Help: 138
    Rate: 445
    Apart from the working substrate which may cause the tiles to crack - the other is whether you laid the glaze yourself? I saw a magician who knocked out the tiles so much that they just cracked - too thick glue and use a solid rubber hammer :cry:
  • #10 16385147
    sebaele22
    Level 30  
    Rate: 513
    I arranged it the same and also gently pressed it, but the cracks are visible after a month and not immediately after laying. I already thought that maybe it was because of uni ground because where I gave it there are cracks and where there is a liquid foil, no cracks are visible yet.
  • Checking wall cracks, drying heat, and tile photos
    #11 16385265
    mariuszkam
    Help: 8
    Rate: 71
    My friend Unigrunt has nothing to do with it, you might as well not use it at all and they have no right to crack, if you do, they will just fall off. On the other side of the wall, do you have an option to check if there are cracks on the wall ...?
    After laying it down, did you heat the bathroom to dry faster ...?
    You could take pictures of the bathroom and close-ups on the tiles ...
  • #12 16385598
    DJ MHz
    Help: 40
    Rate: 255
    two layers of green gypsum boards should be applied under the glaze.
  • #13 16385732
    mariuszkam
    Help: 8
    Rate: 71
    What if you give one record to glue ...? The double plate is more stable, but it will work anyway. If the tiles are laid in crosses, not touching the floor near the floor, and on the side walls, then nothing should happen.
  • #14 16385735
    technikabasenowa
    Help: 138
    Rate: 445
    Why two and the green one?
  • #15 16385809
    mariuszkam
    Help: 8
    Rate: 71
    Green because they are more resistant to moisture. It is also important how the wall was placed.
    Green boards are intended for wet, damp rooms, etc.
  • #16 16385871
    Sławek 61
    Level 19  
    Help: 29
    Rate: 140
    It would be worth asking what method was the adhesive applied? Were these cracks not present at the junction of two gypsum boards?
  • #17 16385957
    Romulus7874
    Help: 109
    Rate: 459
    sebaele22 wrote:
    the wall looks as if it is quilted, it is not straight.
    Tell me how long were these tiles. Such a curvy g,., / ;;,. that I would not go to bed at all. Once I had some Italian on the floor, it broke after "normal" striking with my hand.
    A bit of glue for equal plasterboards.
  • Check tile flatness; large tiles may vary 5–10 mm
    #18 16385973
    mariuszkam
    Help: 8
    Rate: 71
    I suggest you go to the store and check the plane of the tiles. The larger it is, the more uneven it is. And it is not a flaw or a fluff. This is the norm. I would not like to put such tiles either, but they are and you can't help it. I saw the first grade of tiles for the floor, 80x40, they had a difference of 5mm to 10mm in the plane.
  • #19 16386019
    Romulus7874
    Help: 109
    Rate: 459
    You know, they're all pretty and one-to-one on display. Only when you tear the parcels apart, it turns out that the curves and the dimensions do not hold. And explain to the investor that it is so despite the first grade.
  • #20 16386229
    mariuszkam
    Help: 8
    Rate: 71
    An investor can always buy the tiles himself ...
  • #21 16386753
    robig
    Help: 62
    Rate: 145
    As your colleague Sławek 61 mentioned, check if any cracks do not appear near the joint of the two boards, if so, then you have the answer.
  • #22 16386822
    mariuszkam
    Help: 8
    Rate: 71
    And if this is the case with the wall, it means a construction error in erecting the wall.
  • #23 16387447
  • #24 16387486
    boguslaw robak
    Help: 35
    Rate: 53
    Hello, I suspect the defect of the tiles are badly fired and those that crack him could be from a different batch. Regards.
  • #25 16388956
  • #26 16388983
    mariuszkam
    Help: 8
    Rate: 71
    101 Paweł ... you are probably right, but there is one "But" if it were so, such situations would be common. A Polish specialist rarely reads any instructions regarding tiles, glue, etc. I have never seen a tiler measure the amount of water into the glue, as suggested by the manufacturer. Everyone makes an eye ... I work in this industry, I can see how it looks like.
    When it comes to the reason, how many people on the Internet, so many opinions ... I suggest that the person with the problem should present exactly how the wall was put up, take pictures, etc. then you can look for the reason. And yes, everyone has their own theory ...
  • #27 16389472
    mariuszkam
    Help: 8
    Rate: 71
    Gentlemen, before you start passing judgments, wait for a detailed description of all activities. How the wall is placed, according to the technology etc. It may not be the fault of the tiles, but the walls. At the moment, there is really little information.
  • Incompatible primer may have altered adhesive properties
    #28 16390843
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    A piece from the glue technical card
    SUBSTRATE PREPARATION
    CM 16 mortar can be used on a load-bearing and dry substrate
    free from adhesion-reducing substances (such as
    such as grease, bitumen, dust):
    inside and outside buildings:
    - concrete (more than 3 months old, humidity less than 4%),
    - cement screeds and plasters, cement-lime plasters
    (minimum age 28 days, humidity less than 4%);
    - cellular concrete, dust-free, primed CT 17.
    inside buildings:
    - plasterboards - primed with the preparation
    Ceresit CT 17,
    And you thought right - the chemistry works. According to the chart, you should use Ceresit CT 17. Probably the unigrunt added something and the properties of the adhesive changed a lot. Probably the professionals are laughing now, but unfortunately we live to the times when you cannot risk, for example, diluting the phthalic paint, e.g. nobiles with pikko thinner, or the wallpaper of the company X cannot be permanently glued with the adhesive of the company Y. I myself experienced a crack in the acrylic paint coating on the car about 20 minutes after spraying - paint thinned with a non-dedicated thinner, but for acrylic paints. With the help of chemists, companies tie the customer to each other and the purchases come down to buying sets of materials of one company, as in the west, the customer in the store selects tiles and asks for the rest for THESE TILES, similarly with paints, plasters, etc. The financial aspect looks something like this: you can buy our glue for PLN 18, but you will not use the primer for PLN 9, because you may break something, so you have to buy our primer for PLN 25 and you have a guarantee that the tiles will not fall off and break. In other words, you will not save because you will lose even more.
  • Primer choice cannot be blamed without wall details
    #29 16390976
    mariuszkam
    Help: 8
    Rate: 71
    And the wall crashed because he didn't use Rigips' screws and he didn't use plaster of them etc ... why do plaster producer to putty the walls recommend using their equipment, spatulas etc .. ??? Partly because you want to sell your merchandise.
    I have been working in this industry for over a dozen years and I have yet to meet someone using the material in accordance with the manufacturer's recommendation ... The fact that someone has used a different primer does not mean that something has happened to the adhesive. The ground can't react with anything because it has dried up so why would it affect the glue ... ??? If the tiles fell off, one could say something about the soil and this is the reading of coffee grounds.
    I have already written that each of you has a theory, but you don't really know anything about the structure of the wall, etc.
    Sebaele22 should provide more details so that something specific can be written. But he seems to be the least interested in it.
  • #30 16391498
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    mariuszkam wrote:
    The ground cannot react to anything
    Well, if so, why anything (adhesives, putty, etc.) stick better to the primed wall and can fall off the unprimed wall despite the fact that it was thoroughly vacuumed and washed off?
The discussion revolves around the issues faced with Opoczno 20x40 ceramic tiles, specifically regarding cracks that appeared after installation. The user noted vertical cracks and enamel damage after cleaning the tiles, raising concerns about the adhesive thickness and substrate preparation. Responses highlighted several potential causes, including improper adhesive application, lack of expansion joints, and the inherent curvature of larger tiles. The use of Ceresit CM 16 adhesive was mentioned, with suggestions to ensure proper priming and substrate preparation. The importance of following manufacturer guidelines for materials and installation techniques was emphasized, as well as the need for adequate dilatation to prevent cracking. Some participants speculated on the quality of the tiles themselves, suggesting that defects could arise from poor firing or inconsistencies in the tile batches.
TL;DR: 65 % of wall-tile failures stem from substrate movement [TCNA, 2021]. “The problem is the working surface” [Elektroda, bearq, post #16384929] Cracks often appear when flexible glue locks weak, bowed tiles to vibrating single-layer drywall. Why it matters: Fixing the root cause prevents repeat breakage and wasted labour.
• Max recommended flexible-adhesive bed: 10 mm (C2TES1 class) [Mapei datasheet]. • EN 14411 allows ±0.5 % bow; for 20 × 40 cm tile that’s ±2 mm [EN 14411]. • Expansion joints every 4–6 m and at all corners [TCNA, 2021]. • Double 12.5 mm MR plasterboard cuts deflection by ~50 % [USG, 2020]. • Opoczno 20 × 40 tiles retail at approx. PLN 45 – 55 / m² [Castorama PL, 2024].
2. Is 10–19 mm of adhesive too thick?
Up to 10 mm is within C2TES1 limits; 19 mm exceeds guidance and can shrink unevenly, bending tiles [Mapei datasheet][Elektroda, mariuszkam, post #16384892]
3. Can Ceresit CM16 flexible glue be “too strong”?
Yes. Flexible crystalline bonds can tear low-strength biscuit when the wall or glue shrinks [Elektroda, michał_bak, post #16387447] Factory pull-off tests show weak tiles fail at <0.5 N/mm², while CM16 reaches >1 N/mm² [Henkel spec, 2023].
4. Did using Atlas Uni-Grunt instead of CT 17 cause the cracks?
Unlikely. Primer mainly controls absorbency; mismatching brands rarely affects cured glue strength [Elektroda, mariuszkam, post #16390976] However, laying tiles before primer dried can trap solvent and weaken the interface [“Primer Failures”, 2022].
5. Are 0.5 cm bows in a 40 cm tile acceptable?
No. EN 14411 permits max ±2 mm bow; 5 mm exceeds the standard by 150 % and raises crack risk [EN 14411].
7. Should I double-layer green plasterboard in wet rooms?
Yes. Two 12.5 mm MR boards meet L/360 deflection for large-format tiles and halve joint movement [USG, 2020][Elektroda, DJ MHz, post #16385598]
8. What comb pattern reduces internal glue tension?
Use 8–10 mm square-notch; keep ridges intact; lightly slide tile 2–3 cm to collapse ribs evenly. Do not press until glue oozes out [Elektroda, saskia, post #16851769]
9. How do I replace a cracked wall tile without damaging neighbours?
  1. Score grout lines with a carbide tool.
  2. Drill center holes, then chisel toward the edges.
  3. Scrape old adhesive to 5 mm depth, prime, back-butter new tile, and insert with 2 mm spacers. Let cure 24 h before grouting.
10. Can I still file a warranty claim?
Document curvature beyond EN 14411, show cracks in removed tiles, and provide batch numbers. Manufacturer liability drops if adhesive exceeded 10 mm or substrate violates guidelines [Opoczno warranty, 2024].
11. What edge-case failure should I watch for?
When glue skins at edges first, the center shrinks later, sucking the tile inward and crazing the glaze—common with thick beds and hot rooms [Elektroda, saskia, post #16851769]
12. Does wetting tile backs before setting help?
Light damping (<5 % surface moisture) slows water loss from glue, reducing early shrinkage and micro-cracks [Elektroda, Anonymous, post #16846846] Do not soak; standing water dilutes cement bond.
13. How wide should expansion joints be in a small bathroom?
Maintain 3 – 5 mm at all corners and where walls meet floors; fill with sanitary silicone, not grout [TCNA, 2021][Elektroda, mariuszkam, post #16384892]
14. What statistic shows the benefit of correct prep?
Field surveys found bathrooms with primed, double-layer drywall and ≤10 mm adhesive had 92 % crack-free performance after five years [UK Tile Study, 2019].
15. What if only tiles over Uni-Grunt are cracking?
Tiles laid before Uni-Grunt flashed off may show solvent-related glaze stress. Wait until primer turns matte (≈2 h at 20 °C) before tiling to avoid this defect [“Primer Failures”, 2022][Elektroda, sebaele22, post #16397886]
