Fixing 500L Cracked Stoneware Pot: Best Glue & Techniques for Strong Repair
zbyszek144 23154 14
How can I repair a cracked 500 L stoneware pot so it does not fall apart?
For a stoneware pot that needs to stay together, the thread suggests reinforcing the cracks with steel clamps and water glass rather than relying on ordinary glue. Make the clamps from 40–50 mm wide steel strip about 4–5 mm thick, split them into two half-rims, drill two fi 8 holes at each end, and tighten them very slowly and carefully so you do not worsen the cracks [#17187935] Pour water glass into the cracks before clamping, then soak the cracks with water glass several more times after tightening; it acts as a binder/sealant, not as the main glue [#17187935][#17194771] If the pot is only decorative, another suggestion was epoxy resin plus epoxy putty for wider gaps, after cleaning the cracks well and drying them thoroughly [#17184992] Another option mentioned was epoxy/liquid metal or a glue for ceramic chimney liners, but the strongest practical advice in the thread is the clamp plus water-glass reinforcement [#17194984][#17185133]
  • #1 17184592
    zbyszek144
    Rate: 9
    Hello, I have a stoneware pot with a capacity of 500l jet quite large but unfortunately the cracks are quite strong and I would not like to fall apart :(
    My question: how can you glue such a miracle and how to do it?
    Thank you very much for the hints! !
  • #2 17184795
    smax17
    Help: 262
    Rate: 638
    You won't stick.
  • #3 17184813
    1st
    Help: 59
    Rate: 169
    I'm not sure, but maybe some potter, glue clay (or what they use there) and burn again.
    [Edit]
    in Opoczno, can someone from a tile factory help?
  • #5 17184992
    saskia
    Help: 174
    Rate: 1086
    It depends on what it is for, because as a decoration it is enough epoxy resin with filling wider joints with epoxy putty just after lubricating the resin, when it is still sticky, so that the resin itself will be like a binder of epoxy putty, because the resin itself will flow out of the gaps, and the putty is too dense and not sticky enough to stick firmly to the stoneware.
    These kits can be obtained in different colors and match the color of the stoneware.
    Of course, the gaps need to be well cleaned of carbon deposits to get gluing.
    The tavern should do it, but you need to dry the gaps well before gluing, and the whole hand to sleep with a belt so that it does not fall apart during these operations.
  • #6 17185086
    zbyszek144
    Rate: 9
    And you don't know, could such a mounting glue, e.g. patefix, cope?
    Added after 7 [minutes]:
    And you don't know, could such a mounting glue, e.g. patefix, cope? It serves only as a decoration but I do not want it to fall apart.
    Outside, I thought of doing nothing only from the inside, cut it harder with a grinder and fill it (glue it) but I don't know what or is it a good idea at all?
  • #7 17185111
    zimny8
    Help: 26
    Rate: 503
    zbyszek144 wrote:
    only from the inside cut it harder with a grinder and fill (glue) but I don't know what or is it a good idea at all?
    Glue is best kept where it is not, or more precisely where it least. Preparation as for welding does not make sense, because there are no such electrodes :) .
    There used to be a ceramic glue called "cristal" or something, look.
  • #8 17185122
    abart64
    Help: 270
    Rate: 630
    I would give glass fiber patches and resin from the inside. What flows out can be sanded.
  • #9 17185133
    Radiokiller
    Level 30  
    Help: 156
    Rate: 236
    Look for glue for ceramic chimney liners.
  • #10 17187935
    zbigniewsk
    Help: 14
    Rate: 52
    Good day.
    I suggest using steel clamps made of 40-50 mm wide strip with a thickness of 4-5 mm divided into two half-rims and at each end drill two holes fi 8 for screws. For this buy water glass that should be poured into cracks before clamping the rim. The entire crimping operation should be carried out slowly. After tightening, soak the cracks with water glass several times. How did I get such a regenerated stoneware barrel with a capacity of about 120 liters and I used it for over 30 years until the stone fell off the board and nothing helped here. This is how my father regenerated it because such stoneware barrels were very valuable for pickling cucumbers or cabbage and they are still enough to see prices in stores.
  • #11 17194755
    zbyszek144
    Rate: 9
    Dude, is this water glass sticking those cracks?
  • #12 17194771
    zbigniewsk
    Help: 14
    Rate: 52
    Good day.
    Please read here how it works and how it is used water glass https://www.castorama.pl/inspiracje-i-porady/...wacze/do-czych-wykujeuje-sie-szklo-wodne.html and https://kb.pl/porady/szklo-wodne-zastosowanie-cena-i-wszystko-inne-co-warto-wiedziec/. Water glass will act as a binder, not glue, i.e. it will protect us tightness at steel clamps that will not allow the cracks to grow and even slightly reduce them. Please remember to tighten the screws on the clamps very carefully so as not to aggravate the situation. Good luck.
  • #13 17194984
    telecaster1951
    Help: 829
    Rate: 818
    Neatly? There are two ways. Lacquer with the addition of metal, i.e. the Japanese method. The road is terribly. Or so-called liquid metal, i.e. epoxy resin with the addition of metal. Generally, the same as the Japanese invented a few hundred years ago, only in a synthetic version. If you stick it on amen.
  • #14 17322243
    palmus
    Help: 232
    Rate: 745
    I suggest car window adhesive, glues everything to everything.
  • #15 17323091
    zimny8
    Help: 26
    Rate: 503
    I remembered it today; GS crystal cement hypo adhesive.
✨ The discussion revolves around repairing a large 500L cracked stoneware pot. Various suggestions for effective adhesives and techniques are provided. Options include using epoxy resin with putty for decorative purposes, ceramic glue like "cristal," and glass fiber patches with resin for internal reinforcement. Water glass is recommended as a binder to stabilize cracks when used with steel clamps. Other suggestions include car window adhesive and GS crystal cement hypo adhesive. The importance of cleaning cracks and ensuring proper drying before application is emphasized.
TL;DR: For cracked stoneware, clamp‑and‑water‑glass repairs can last 30+ years; "The entire crimping operation should be carried out slowly." Use steel bands or belts, or epoxy for decor‑only fixes. For DIYers stabilizing large (e.g., 500 L) pots. [Elektroda, zbigniewsk, post #17187935]
Why it matters: This FAQ helps anyone asking how to fix a large cracked stoneware pot safely, economically, and without re‑firing.
What’s the strongest way to stop a big cracked 500L stoneware pot from falling apart?
Use steel bands as clamps with water glass as the binder. Bands: 40–50 mm wide, 4–5 mm thick, two half‑rims, M8 holes. Pour water glass into the cracks, then tighten the bands slowly. After tightening, soak the cracks several times. A 120 L barrel reportedly lasted over 30 years repaired this way. Tighten gently to avoid worsening cracks. [Elektroda, zbigniewsk, post #17187935]
How do I use water glass with steel clamps?
  1. Pour water glass into the cracks along their length.
  2. Fit two steel half‑rims around the pot and tighten the screws slowly.
  3. After securing, soak the cracks with water glass several times. Work gradually to prevent crack growth during tightening. [Elektroda, zbigniewsk, post #17187935]
Can I just re‑fire the pot to heal the cracks?
No. Re‑firing is not a feasible fix for cracked stoneware. The production process does not support “burn again” repairs outside industrial making. Focus on clamping or adhesive stabilization instead. [Elektroda, smax17, post #17184876]
Will mounting glue like Patefix work on stoneware?
Mounting glues were not endorsed in the thread. Use two‑part epoxy resin with epoxy putty for decorative stabilization. “As a decoration it is enough epoxy resin.” Clean and dry gaps first, and strap the pot during cure to keep compression. [Elektroda, saskia, post #17184992]
Can I glue only from the inside and leave the exterior untouched?
Yes, for decorative use. Combine liquid epoxy resin with epoxy putty. Wet the crack with resin, then press putty while the resin is still tacky to lock it in. Dry the gaps and clean deposits first. Strap the vessel with a belt to keep parts compressed while curing. [Elektroda, saskia, post #17184992]
What prep is essential before any adhesive repair?
Clean the cracks of deposits to ensure adhesion. Dry the gaps thoroughly before applying resin or putty. After wetting with resin, fill wider joints with epoxy putty so the resin bonds the putty. Strap the pot with a belt or band to prevent spreading while it cures. [Elektroda, saskia, post #17184992]
Is fiberglass cloth with resin a viable reinforcement for the inside?
Yes. Apply fiberglass cloth patches with resin on the inside to bridge cracks. Let resin squeeze‑out cure and sand it flush. This adds an internal composite layer while leaving the exterior largely untouched. [Elektroda, abart64, post #17185122]
What adhesive should I use if the pot faces heat or weather?
Use products formulated for ceramic chimney liners. They are intended for ceramic‑to‑ceramic bonding in demanding conditions. Check the label for compatibility and application method. [Elektroda, Radiokiller, post #17185133]
Is car window adhesive a good idea for stoneware cracks?
A contributor suggested automotive windshield adhesive as a strong, general‑purpose option. If you try it, test on a small, inconspicuous area first. Assess adhesion and appearance before full application. [Elektroda, palmus, post #17322243]
Does GS Crystal Cement (hypo) work on ceramics?
A user recalled “GS Crystal Cement (hypo)” as a ceramic adhesive. Availability can vary, so look for current equivalents if it’s hard to find. Check that it suits stoneware and your use case. [Elektroda, zimny8, post #17323091]
What about kintsugi or “liquid metal” epoxy repairs for a neater look?
For an ornamental finish, kintsugi‑style metal‑filled seams are an option. Traditional lacquer‑with‑metal is expensive. A practical alternative is “liquid metal” two‑part epoxy with metal filler to mimic the look. [Elektroda, telecaster1951, post #17194984]
Should I cut or grind the crack into a groove before gluing?
No. Do not prep the crack as if for welding. Heavy grinding removes supporting material and adds little benefit. Keep removal minimal and focus on compression and bonding. [Elektroda, zimny8, post #17185111]
What if the cracks are too severe—can it be glued at all?
If the vessel is badly fractured or highly stressed, adhesive alone may fail. “You won’t stick.” In that case, rely on clamping or consider replacement. [Elektroda, smax17, post #17184795]
Is epoxy safe for vessels that will hold food or fermentations?
Follow the advice given: use epoxy only when the pot is decorative. For functional vessels, avoid epoxy seams and prioritize structural restraint and stability over cosmetic fills. [Elektroda, saskia, post #17184992]
What failure should I watch out for after repair?
Impact. A stone dropped from a board destroyed a previously reinforced barrel after decades of service. Avoid drops, knocks, and point loads. [Elektroda, zbigniewsk, post #17187935]
Is water glass actually a glue?
Water glass acts as a binder to help seal and stabilize, not a standalone glue. “Water glass will act as a binder, not glue,” so pair it with steel clamps and tighten carefully. [Elektroda, zbigniewsk, post #17194771]
