Antenna Cable Placement & Signal Quality: Maximizing Reception with Double LNB & NC+ Decoder
Parek13 5679 5
  • #1 16385181
    Parek13
    I have a problem with the signal quality in the decoder from nc +. The installations are on the balcony established in 2011 by c +. I have a double LNB and two antenna cables. The reception power is 90-100% and the quality, unfortunately, but only 30-40% (depending on the channel). I know that the quality is mainly the result of setting the installation, but I wonder if I tighten / loosen the cable on the balcony or try to move it, the quality can also change. Can the placement (cable high / low on balcony or cable taut / slack) affect reception quality?
    If so, how should the cables be installed to get the best signal quality?
    best regards
    andpol 33
    Help: 513
    Rate: 1145
    It shouldn't matter. If it does, it means the cable is of poor quality.
  • #4 16385597
    Parek13
    So it may be the cable's fault. Now with the second cable it has become 60%, but in the 1st cable it is still 30% so I think that up to 60% the cable does its job and then just setting the converter.
  • #5 16385637
    LeDy
    Help: 1989
    Rate: 2930
    Everything could be to blame for what's in the installation. As moving the cable changes whatever it is, replace it because there can be no reaction to the moving.
  • #6 16455406
    M.Mikolajski
    Help: 13
    Rate: 22
    It also seems to me that F-connectors are poorly made or loosened by weather conditions (wind) - such a question arises - after leaving the converter, the cables are connected to the boom or they fly loosely from the converter to the balcony - the symptoms are evidently related to the quality of assembly to be corrected (cable, connectors)
