Samsung TV Affects New Cyfrowy Polsat Decoder: Solutions for Decoder Switching Off
Magdazio 21477 6
  • #1 16386433
    Magdazio
    Level 4  
    Rate: 10
    I have a problem
    Since the time when I exchanged the Cyfrowy Polsat decoder for a new model, everything changed. Turning the TV off, the decoder switches off. To restore the inclusion of the decoder I have to be afraid to succeed. This is a problem for me because if we do not have a decoder on, there is no tv in another room.
    Can you change something and how?
    Samsung TV
  • #2 16386734
    Polon_us
    Help: 1184
    Rate: 1281
    On the TV, please turn off AnyNet +.
    You can also check the decoder itself.
    If the menu has "HDMI Control" options, please make sure they are turned off.
  • #3 16416425
    Magdazio
    Level 4  
    Rate: 10
    Unfortunately, I can not find it.
    I searched and tv and the set-top box ?
  • #4 16416530
    olekt2002
    Level 32  
    Help: 147
    Rate: 518
    Let the author give the exact Tv model, because without this, it can only be foretold.
  • #5 16422089
    Magdazio
    Level 4  
    Rate: 10
    I took a photo
    • Samsung TV Affects New Cyfrowy Polsat Decoder: Solutions for Decoder Switching Off 20170419_154928.jpg (2.55 MB) You must be logged in to download this attachment.
  • #6 16422308
    _kli_
    Help: 764
    Rate: 1042
    On the TV:
    System -> Anynet + (HDMI-CEC) -> Disabled
    What? Decoder connected via HDMI cable?
    In one of the latest updates, the CP decoders received the HDMI-CEC function. As I remember correctly, it is probably in the "Image and sound" tab. Try to turn it off.
  • #7 16424166
    Magdazio
    Level 4  
    Rate: 10
    _kli_ wrote:
    On the TV:
    Everything is great. Works ???
    Thank you for your help
The discussion revolves around an issue where a new Cyfrowy Polsat decoder turns off when a Samsung TV is powered down. Users suggest disabling the AnyNet+ (HDMI-CEC) feature on the Samsung TV and checking the decoder's HDMI Control settings. The author struggles to locate these settings but eventually finds them and successfully resolves the issue, confirming that the decoder now remains operational when the TV is turned off.
