PS3 System Restore: Guide for Successful Update via USB at 55% Error Issue
kamil1537 17892 3
  • #1 16387894
    kamil1537
    After purchasing the PS3, there was a problem with the system. Namely, when it was turned on, the update started, which at 55 percent was stopped and then an error popped up.
    When trying to update via USB, the pen drive does not detect it. I don't know what I'm doing wrong? I hope you will help me, I spent 14 hours with him and I have no strength for it.
    Please help.
    Best regards.
  • #2 16387978
    michu14031
    Help: 12
    Rate: 38
    The question is, do you want to avoid the costs of sweating or vice versa?
    As for Pendrive, try on another one, or it depends on the file system in which you have formatted
    What is your hdd or sdd disk ?? maybe there are problems with him
    look at the manufacturer's website
    Moderated By Mirek Z.:
    I have removed the inactive link.
  • #3 16388040
    kamil1537
    I want to avoid costs
    when I insert the flash drive to flash a few times and at the end of his role in this I bought a second one and the same happens it looks like I turn on the dog and shows updates to version 4.53 press select and start asks to wait after an hour prints error 8002f281
    I came to the settings where it was to update the system neither via the net nor through the pendrive does not go I tried almost everything NWM or I do something wrong
    I read a lot about how to upload the system I do the same but it is different for me as if he did not try
    disks have already been tested 3 in it original toshiba 80gb empty I uploaded the 4.81 system there by a computer and I still want the system
    thank you for replying
    ps. I'm still trying to do this system but still the same :(
