  • #1 14620854
    Jarek91
    Welcome to honorable forum members.
    I am asking for help in recognizing the system, the designation of which is on the housing 82002. I attach his pictorial picture. I will add that it probably can have and has something to do with USB ports. Probably power supply and a number of overload protections.
    I have some circumstantial evidence that it could be: ,, 1h High Side Switch ICs: (By the way, is there anyone able to determine how this element is defined in our language?). If anyone has knowledge in this area and is able to provide several alternatives to this system more common to get in the home market, I will be grateful.
    I do not rule out that this is a family of bd82006fv-j systems. I will add that the system you are looking for is at least in the Play Station 3 (PS3) slim version (not super slim).
    "82002 \ PS3 - USB - Decoding system.
  • #2 16320191
    JACOOS
    Help: 6
    Rate: 14
    The description of the system is attached.
    JACK
    • High-Slide Power USB 5V.pdf (309.67 KB) You must be logged in to download this attachment.
  • #3 16320521
  • #4 16332337
