Used 2.5m3 Resin Plastic Tank Burial: Creating Concrete Encasement in Clay Soil & Maintenance
wald3k 9621 21
Can I bury a used 2.5 m3 resin/plastic tank in heavy clay soil by surrounding it with concrete, and how should I prevent it from floating or collapsing when empty?
Do not fully encase it in concrete unless you really need the extra restraint; a concrete base or shell can protect a plastic tank from being squeezed in clay when it is empty, but it will also make future removal or repair difficult [#16393998][#16393912] If you do concrete around it, keep the tank completely full of water while the concrete cures so shrinkage does not deform the tank [#16394468] In heavy clay with no drainage, gravel or rubble backfill may not help much because it can just create a water-filled “bathtub,” so buoyancy still has to be handled by weight and structure [#16394135][#16393998] One rough calculation mentioned in the thread was that a 2.5 m3 tank needs about 2.5 tons of load, and one poster estimated that about 1 m3 of concrete plus some soil cover and at least 500–1000 L of water left in the tank should be enough [#19600186][#16394135]
  • #1 16393319
    wald3k
    Rate: 8
    I purchased a used 2.5m3 plastic tank (it looks like polyester resin). I want to bury it in clay soil so I have to weigh it down for sure. The shape of the tank is similar to a barrel (for vertical mounting) and I thought to manually dig a hole that would be wider than the tank by only a few centimeters on each side. I would pour a concrete slab under the tank and then pour it all over with concrete so that a concrete tank would be created around the plastic tank (not forgetting, of course, the reinforcement). While pouring concrete, I would of course fill the tank with water in parallel to equalize the pressure.
    Maybe something I did not take into account? Is this really a good idea? (resin tank completely filled with concrete)
    The tank is not new and I assume that as the resin ages, I could dry the tank every few years and put another layer of laminate on the inside to extend its life.
    Constructive criticism greatly appreciated. Thank you in advance.
  • #2 16393701
    stanislaw1954
    Help: 2013
    Rate: 4668
    It seems to me that if you want, a concrete base can be made, but why pour concrete around it. What is the purpose of this outdoor concreting? The soil around the reservoir is enough.
  • #3 16393708
    niewolno2
    Level 40  
    Help: 628
    Rate: 1258
    You can fill the space with sand, the basic question is whether this tank is free-standing or not and requires reinforcement?
  • #4 16393848
    wald3k
    Rate: 8
    @ slavy2
    This tank is actually a water meter pit (I plugged the holes). which is already in age. It was damaged on one side and I repaired it with a glass mat and epoxy resin. I do not know what the durability of the polyester resin (which the tank was probably made of) looks like, so I thought about reinforcing the structure with concrete. Unfortunately, the clay in my case is the worst (it reaches 12 meters) and that is why I counted that to compensate for the buoyancy of the tank, I would still need about m3 of concrete. I wonder if such a solution may have any negative consequences? (maybe, for example, resin and reinforced concrete 'work' differently or there is a risk that the water which, however, gets between the concrete and the resin, will freeze and cause cracks). I have no technical education, but sometimes I like to do something myself :)
    @ stanislaw1954
    In my area, I have already seen two cesspools that surfaced like submarines after completing a secret mission, so I do not have the courage to cover the tank with earth :)
  • #5 16393912
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1132
    Maybe it's a good idea, I don't know what stiffness this tank has, but something like that (concreting) can protect this tank from being squeezed and tightened. If it happened that the reservoir is not "quite stiff" and just empty, especially when it is covered with gravel, and if it were after heavy rainfall, in spring, when the soil is "a little thinner". It also happened with a neighbor on the plots. He had a 1000-liter plastic tank buried for the "near-water cesspool". One spring it turned out that the soil around the tank collapsed and the tank "closed" inside. Concrete would protect the tank from something like this, because it is stiff.
  • #6 16393920
    stanislaw1954
    Help: 2013
    Rate: 4668
    It was only in subsequent posts that I found out that it was supposed to be a septic tank, which is sometimes emptied, so it is empty. In such a situation, it is probably better to concrete it, as the ground pressure may compress it, especially when it is empty.
  • #7 16393935
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1132
    because the pressure of the ground can compress it, especially when it is empty.
    And when the contents of the tank are pumped out / sucked under vacuum (septic tanker / cistern), this phenomenon is even more pronounced.
  • #8 16393948
    nuszek
    Level 30  
    Help: 123
    Rate: 389
    First, count how much concrete needs to be poured to load the tank, the base must also be reinforced and connected to the whole. Below is a photo of the concrete reservoir that came out.
    2.5 m3 must be loaded with concrete weighing at least 2.5 tons.
  • #9 16393962
    Krzysztof Kamienski
    Help: 2033
    Rate: 5165
    wald3k wrote:
    so I definitely have to weigh him down.
    Pour the water, then pump it out :D Plastic (PVC) tanks called "Tuffi Tank" with a capacity of 5 m3 stand still without burying, and dug in without concreting is hoho. Want a photo?
    pour concrete inside the tank ?? I haven't laughed so much for a long time :D :D
  • #10 16393971
    nuszek
    Level 30  
    Help: 123
    Rate: 389
    Read with understanding, or think logically, where it says inward, the diver also strains himself by pouring lead into the stomach - it would be funny only :D :D .
  • #11 16393998
    Krzysztof Kamienski
    Help: 2033
    Rate: 5165
    You think you want to cry :cry: - bury the tank and that's it. If it is poured with concrete, it will be difficult to remove it in the event of a breakdown (cracks.) Do you know how Old Indians do it here in the construction of home pools and ponds? And they have practice and experience in this. They make a trench a few dozen centimeters larger than the reservoir, they put gravel or rubble on the bottom of the trench and tamp it gently after settling empty tank.
  • #12 16394135
    wald3k
    Rate: 8
    @K-rzysztof Kamienski
    Thanks for the idea. I'm sure the gravel / crushed stone idea is pretty good, but assuming it helps drain off the excess water. Unfortunately, in my case we are talking about a 12 meter layer of heavy clay. I drilled a well next to it and I know the cross-section of the layers well. This water will have no drainage. covering the sides of the tank with material other than concrete or clay (which, in turn, will not be thickened) can unfortunately create a 'bathtub' with water.
    @ stanislaw1954
    It will not be a septic tank, but a water tank from the well (I gave the septic tank only as an example). I drilled a well with a terrible capacity (500l per hour ..) and therefore I need an intermediate tank for watering the garden. This means that during the season the tank will be filled / emptied (although probably not to the bottom) at least once a day. The pressure of the ground also occurred to me. Thank you.
    @nuszek
    the tank is 2.5 m3 and I assume that there will always be at least 500l of water in it (for the health of the pump). I assume that m3 of concrete is about 2 tons, so together with some layer of soil it should eliminate the buoyancy. do I do well?
    Anyone else have any idea? The hole for the tank is already being dug and I plan to finalize the assembly on Saturday.
  • #13 16394196
    nuszek
    Level 30  
    Help: 123
    Rate: 389
    If it is not a flood plain, with water standing in the yard, pour concrete over the tank to create a shell / as you write for the future to strengthen the tank /. 3 m3 of concrete may be an exaggeration, but it will certainly go a long way.
    ps. We installed a 10,000-liter fuel tank on a hill, where flooding with water is almost a miracle, but the UDT gentleman calculated the displacement of this tank exactly.
  • #14 16394221
    wald3k
    Rate: 8
    I don't mean 3 but 1 m3 of concrete. I assume that its mass is about 2 tons. 2m3 of water weigh the same (this is what I can pump out of the tank). I treat the top layer of soil as an additional reserve. I count it purely intuitively. Can anyone tell you how to correctly calculate displacement?
  • #15 16394338
  • #16 16394371
    wald3k
    Rate: 8
    Kurtka na wacia wrote:
    What is the depth of the water surface of the well and its distance from the reservoir? Perhaps it is enough to drain the tank properly and the drain from the drain will pour into the well. By default, I imagine that the highest water level in the well is lower than the level of the bottom of the reservoir. But if it is so, I do not know.
    This is a deep drilled well. The static mirror is at the level of 11.5 meters, but this does not matter in this case, because pouring drainage water into this pipe is too high a risk (due to siltation). A large amount of water in the clay is very rare (early spring when the ground in the deeper layers is still frozen, thaws, etc.) but I have to somehow protect the tank against it.
  • #17 16394432
    soniak2
    Help: 42
    Rate: 139
    Gentlemen, you also need to analyze whether concrete shrinkage will not do anything to the tank.
  • #18 16394468
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1132
    soniak2 wrote:
    whether concrete shrinkage will do nothing to the tank.
    While the concrete "solidifies", fill the tank with water "to the full" so that there is no "drop" of air and close it tightly.
  • #19 16394539
    wald3k
    Rate: 8
    Closing completely tight will be a problem, but the tank will of course be full. Will the use of dry / semi-dry concrete reduce the possible shrinkage effect? I know that such concrete will be a bit weaker but it is not a shelter after all.
  • #20 19599988
    Dobromir pomysłowy
    Help: 46
    Rate: 147
    wald3k wrote:
    Is the use of dry / semi-dry concrete concrete
    concrete B20 strong and slightly damp, easy to vibrate. Laminate does not age and in the 1st post you put it on well, and how did it go?
  • #21 19600017
    konsum
    Help: 99
    Rate: 295
    Put this well in such circles with a concrete lid and scream.
  • Concrete ballast should exceed 2.5-ton tank displacement
    #22 19600186
    Aleksander_01
    Help: 1165
    Rate: 3422
    I live in cop too and I know what it is like. I have a water meter pit over 2 meters deep. When there is heavy rainfall, the water level reaches 0.5 meters ... but not from the bottom but from the top. The water will pass through all seals, the contractor also assured me that the well would be dry, after all, it was tarnished on all sides.
    As for the load of your tank - 1 m? of concrete is enough, provided that it will press the tank downwards. The displacement of this tank is practically 2.5 tons, so 1m? should be enough. Of course, as you write reinforced concrete, the tank is always filled with a minimum of 500-1000 liters.
The discussion revolves around the burial of a used 2.5m3 polyester resin plastic tank in clay soil, focusing on the creation of a concrete encasement for stability and maintenance. The user seeks advice on whether to pour concrete around the tank to prevent buoyancy issues, especially given the tank's age and previous repairs. Responses suggest that while a concrete encasement can provide structural support, it may complicate future maintenance and repairs. Alternatives such as filling the space with sand or gravel are proposed, with considerations for drainage and soil pressure. The importance of reinforcing the concrete and ensuring the tank is filled with water during the pouring process to equalize pressure is emphasized. Concerns about concrete shrinkage and the potential for water accumulation between the tank and concrete are also discussed.
TL;DR: Concrete density 2.4 t / m³ means a 1 m³ collar adds ~2.4 t of downward force; “Laminate does not age” [Elektroda, Dobromir pomysłowy, post #19599988] Encasing a 2.5 m³ resin tank in clay needs proper ballast, drainage, and shrinkage control [PCA, 2021].
Why it matters: Correct ballast stops tanks surfacing, cracking or collapsing during empty cycles.
• Uplift force on an empty 2.5 m³ tank ≈ 2.5 t [Archimedes, basic physics]. • Fresh concrete mass: 2.3–2.4 t / m³ [PCA, 2021]. • Recommended slab thickness: 150–200 mm with Ø8 mm rebar grid @200 mm [ACI 318-19]. • Typical shrinkage of normal-weight concrete: 0.05–0.10 % of length [Neville, 2011]. • B20/C16-20 mix suits non-structural shells [PN-EN 206, 2020].
1. How much concrete ballast is needed for a 2.5 m³ plastic tank?
An empty 2.5 m³ vessel displaces 2.5 t of groundwater. Add at least the same downward mass. One 1 m³ ring (≈2.4 t) plus the 0.5 t residual water the owner keeps inside gives ~2.9 t, leaving a 16 % safety margin [Elektroda, nuszek, #16393948; PCA, 2021].
2. Does a concrete shell prevent wall collapse when the tank is vacuum-pumped?
Yes. A 1000 L neighbour’s tank imploded after pumping because backfill soil squeezed it [Elektroda, wojtek1234321, post #16393912] A reinforced shell resists the 30–50 kPa external pressure created by vacuum extraction [EPA, 2014].
4. Is sand or gravel backfill a valid alternative in clay soils?
Gravel works only if water can drain. In 12 m of impervious clay, it forms a bathtub and buoyancy stays [Elektroda, wald3k, post #16394135] Use concrete or anchor straps when drainage is impossible [USDA Soil Manual, 2015].
5. How do I calculate buoyant uplift correctly?
1 m³ of displaced water creates 9.81 kN uplift. Multiply water volume displaced (tank volume minus always-present liquid) by 9.81 kN to get force. Convert to tonnes by dividing by 9.81 [Archimedes]. Ensure ballast weight exceeds this value by 10–20 % for safety [“Buried Tanks”, API 652].
6. Which concrete mix and consistency is recommended?
Use C20/25 (old B25) or at minimum B20, slightly damp and easy to vibrate [Elektroda, Dobromir pomysłowy, post #19599988] A slump of 40–80 mm limits bleed water yet fills voids [PN-EN 206, 2020].
7. Should the base slab be tied to the side shell?
Yes. Loop starter bars from the 150–200 mm slab into the wall cage so slab and collar act monolithically, stopping shear between pieces [ACI 318-19].
8. How can I relieve groundwater pressure around the tank in pure clay?
Install a vertical relief pipe with perforations down to a gravel pocket beneath the slab. It gives water a preferential path and lets you monitor the level [US Army TM 5-818-5, 1994]. Clean the pipe each spring.
9. How often should I inspect or re-laminate an ageing polyester tank?
Check annually for blistering or fiber print-through. Add a 2-3 mm epoxy-glass layer every 5–7 years if micro-cracks appear. ‘Laminate does not age,’ yet UV and stress do damage joints [Elektroda, Dobromir pomysłowy, #19599988; Composites World, 2020].
10. What happens if water freezes between concrete and the wall?
Ice can exert 9 kN/m². Adequate adhesion and no gaps prevent water entry. Seal the interface with a S-1 grade polyurethane mastic before backfilling [Sika Tech Sheet, 2020].
11. Edge case: can the tank be removed after concreting if it cracks?
No, removal becomes major demolition. Krzysztof warned that a concreted tank is "difficult to remove in the event of a breakdown" [Elektroda, Krzysztof Kamienski, post #16393998] Consider leaving an inspection hatch and flexible couplings to manage future repairs.
12. 3-step installation cheat-sheet
  1. Excavate hole 30 cm wider than tank; cast 150 mm reinforced slab.
  2. Set tank, fill it with water, install rebar cage, pour 1 m³ C20/25 concrete around while vibrating.
  3. Cure 7 days, backfill native clay in 200 mm layers compacted to 95 % Proctor.
