VW T5 1.9 tdi 2005 - The car stalled while driving, spins but did not fire again
Prozak88PL 8664 10
Why did a VW T5 1.9 TDI stall while driving and then crank but not start again?
The most likely cause is a seized turbocharger with the exhaust side blocked, which can stop the engine from firing even though it cranks [#16396459] Check it by opening the oil filler cap and turning the engine; if it starts to blow and wants to run, the turbo fault is confirmed [#16396459] The original poster later confirmed that the turbo was stuck and closed the topic [#16396648]
  • #1 16395516
    Prozak88PL
    Hello . I have a nice puzzle for you, and I am asking for help in solving it as the mechanics spread their hands one by one.
    VW T5 1.9 tdi 2005 car mileage around 220,000.
    The car went out while driving and has not fired anymore, it spins to surprise but does not start.
    When you try to fire, there is smoke from under the lid, 2 candles are flooded.
    -The computer showed only the fight position sensor error, which is already after the exchange, which did not give any results.
    - fuses checked
    - compression is normal
    - the fuel is in the tank (diesel), the pump gives it
    - timing in place
    - the car did not start when trying to start with a self-start
    - candles heat up
    - the caseback was removable underneath everything in a book style
    -Immobilizer shows no error
    - the car was scanned with several computers, none shows errors.
    I count on your knowledge and willingness to help.
    Greetings .
  • #2 16395563
    jerry1960
    Level 37  
    Help: 285
    Rate: 1560
    What is the compression pressure (enter). Air and fuel filter when replaced.
  • #3 16395591
    polmar
    Help: 38
    Rate: 220
    Someone looked at the timing?
  • #4 16395731
    Prozak88PL
    Pressure on the first 27, second 27, third 26, fourth 26
    fuel filter replaced about 20-25 thousand ago
    Air filter approx. 8
    Timing checked
  • #5 16396163
    piotrekwoj1
    Help: 947
    Rate: 3433
    Burns on the plaque?
  • #6 16396237
    jerry1960
    Level 37  
    Help: 285
    Rate: 1560
    Diesel with such compression as it gets fuel at the right moment must ignite. You write that the self-start also does not smoke. It is impossible. Hit the plaque in the intake, he has to smoke.
  • #7 16396262
    worek110
    Help: 17
    Rate: 46
    Record a video of the firing attempt I would like to see.
  • #8 16396316
    Prozak88PL
    Plaque does not help either. The movie will load in the evening after 21. Now I use tel and I can only send it in a private message as mms, I cannot change the format, the format in which my phone records is not supported by this portal.
  • #9 16396427
    robokop
    Help: 1763
    Rate: 6371
    He has the right blood pressure and doesn't even want to smoke - amazing miracles. You miss the truth somewhere in this description.
    bucek21
    Help: 14
    Rate: 86
    Turbocharger rotor twisted and exhaust outlet clogged in the hot part. Standard cause. Check it, open the oil filler cap and turn it, if it blows and wants to start, you have solved the case.
  • #11 16396648
    Prozak88PL
    Bucek 21 Thank you for professional advice !! Turbo is standing! Thanks again for your help. I consider the topic closed.
    Greetings .
The discussion revolves around a 2005 VW T5 1.9 TDI that stalled while driving and failed to restart. The owner reported that the vehicle cranks but does not fire, with smoke observed from under the lid and two flooded glow plugs. Diagnostic checks revealed a fault with the crank position sensor, which was replaced without resolution. Other checks included fuses, normal compression, fuel availability, timing, and the immobilizer status, all of which returned no errors. Responses from the forum included suggestions to check the compression pressure, timing, and potential issues with the turbocharger. Ultimately, it was determined that a clogged turbocharger was the likely cause, which was confirmed by the owner after inspection.
