Renault Clio 2 1.2 16V 2002: G12+ Coolant Compatibility with GLACEOL RX TYPE D
Eidems 17652 7
  • #1 16396233
    Eidems
    Help: 83
    Rate: 253
    Hello! I have a question, can a Renault Clio 2 1.2 16V 2002 car replace the coolant with pink G12 + or do I have to stick to Renault and pour GLACEOL RX TYPE D? Is it somehow different from ordinary coolant? Regards
  • #2 16396340
    michu14031
    Help: 12
    Rate: 38
    Yes you can confidently apply
  • #3 16396549
    Eidems
    Help: 83
    Rate: 253
    Does color matter? Maybe you know the differences between G12 and this fluid from Renault? It seems to me that the fluid may be changed to blue / green with the designation G11. It is now probably blue.
  • #4 16396843
    michu14031
    Help: 12
    Rate: 38
    fluid type G11, silicate content 500-680 mg / l
    type G12 / G12 + fluid, silicate free
    fluid type G12 ++ / G13, silicate content 400-500 mg / l
    I have flooded G12 Hart in all cars from Punciak, Combo, ... to Jetta
    ociz
    Help: 1379
    Rate: 3486
    G12 + will be ok for this car. The manufacturer recommends silicate.
  • #6 16398404
    Eidems
    Help: 83
    Rate: 253
    Nowhere do I get an answer, is GLACEOL RX TYPE D interchangeable with G12 + and are they e.g. miscible? How are they different or is it just a Renault invention?
  • #7 16403275
    Eidems
    Help: 83
    Rate: 253
    I found information that it must meet the best Renault standard and e.g. they are: total glacelf or dynagel 2000 (it meets the Renault 41-01-001-D standard and does not contain toxic nitrites, silicates, amines, phosphates). I think I will decide on this dynagel, it is not expensive and has all the norms listed and it is not some "borygo or k2" for PLN 29.
  • #8 16470111
    Eidems
    Help: 83
    Rate: 253
    The car was flooded dynagel 2000 entered about 5l (when replacing the water pump), driven about 1000km, all OK, the car seems to heat up faster. Regards
The discussion centers on the compatibility of G12+ coolant with the Renault Clio 2 1.2 16V 2002, specifically whether it can be used instead of the recommended GLACEOL RX TYPE D. Responses indicate that G12+ is suitable for this vehicle, with emphasis on the importance of silicate-free fluids. The author inquires about the differences between G12 and GLACEOL RX TYPE D, noting that GLACEOL must meet specific Renault standards. A recommendation for Dynagel 2000, which complies with Renault standards and is cost-effective, is also mentioned. Users report successful use of Dynagel 2000 in their vehicles.
