[Solved] Clio 2 1.2 16V Gear Selector Leak: Repair Kit Worth it? Alternatives & Experiences Shared
Eidems 11886 3
  • #1 16424850
    Eidems
    Help: 83
    Rate: 253
    Hello! I have a clio 2 1.2 16V, and the topic is apparently quite well known, leaking from the gear selector. I have a question, does it pay to fix it? A "kit" has appeared on the well-known auction site to repair this problem. It used to be available only on the French market. After reading several reviews after a few thousand kilometers, the problem returns again. Is there a good way to seal this selector? Anyone have any more experience in this area? Regards
  • #2 16425035
    decybel91
    Help: 1021
    Rate: 4211
    It probably leaks due to the wear of the shaft on which the seal runs. If you do not want to invest in a car fill the engine oil in the gearbox - the leak will not disappear, but it will be significantly reduced.
  • #3 16425097
    Eidems
    Help: 83
    Rate: 253
    I probably won't use it, a 90 PLN kit is a better solution. You can also change the sealant, but apparently it will be liquid again after some time.
  • #4 17941250
    Eidems
    Help: 83
    Rate: 253
    For posterity, after about 20,000 km there was a shortage of 150ml oil in the chest. Subject I analyzed, repair is unprofitable after some time the problem will return. The febi repair kit costs PLN 40, a friend assumed it and after a while it flies again, I don't move yet. Regards
