- Trouble Playing Slim FHD 1080p Car Camera Videos with Allplayer, Media Player, MPlayer
Mapciu 21453 16
Why do Slim FHD 1080p car-camera AVI files fail to play in multiple media players, and how can I determine whether the files are valid?
The files cannot be played because they are empty or damaged, not because a codec is missing. The uploaded sample compressed from 24 MB to only 24 KB, indicating that it contained no meaningful video data [#16398132] A hex-editor check showed repeated `FF` values instead of video content, so the file is not a valid video file [#16398258] The same diagnosis was confirmed with `ffinfo`, which detected neither video nor audio data [#16902630] Installing additional players or codecs will not restore these files; the recording or storage media is likely producing corrupted output [#16396607]
  • Slim FHD 1080p footage fails in multiple players
    #1 16396365
    Mapciu
    Witam.
    Nie jestem w stanie odtworzyć filmów z kamery samochodowej Slim FHD 1080p. Uzywam Allplayera, codeclite+, windows media player, mplayer. Ten ostatni wpisuje do dziennika nastepujacy blad:
    C:/Program Files/SMPlayer/mpv/mpv.exe --no-config --no-quiet --terminal --no-msg-color --input-file=/dev/stdin --no-fs --hwdec=no --sub-auto=fuzzy --priority=normal --no-input-default-bindings --input-vo-keyboard=no --no-input-cursor --cursor-autohide=no --no-keepaspect --wid=724400 --monitorpixelaspect=1 --osd-scale=1 --sub-ass --embeddedfonts --sub-ass-line-spacing=0 --sub-scale=1 --sub-font=Arial --sub-color=#ffffffff --sub-shadow-color=#ff000000 --sub-border-color=#ff000000 --sub-border-size=0.75 --sub-shadow-offset=2.5 --sub-font-size=50 --sub-bold=no --sub-italic=no --sub-codepage=ISO-8859-1 --sub-pos=100 --volume=50 --cache=auto --osd-level=0 --screenshot-template=cap_%F_%p_%02n --screenshot-format=jpg --screenshot-directory=C:\Users\Przemek\Pictures\smplayer_screenshots --audio-pitch-correction=yes --af-add=equalizer=0:0:0:0:0:0:0:0:0:0 --volume-max=100 --term-playing-msg=MPV_VERSION=${=mpv-version:}
    INFO_VIDEO_WIDTH=${=width}
    INFO_VIDEO_HEIGHT=${=height}
    INFO_VIDEO_ASPECT=${=video-aspect}
    INFO_VIDEO_FPS=${=container-fps:${=fps}}
    INFO_VIDEO_FORMAT=${=video-format}
    INFO_VIDEO_CODEC=${=video-codec}
    INFO_AUDIO_FORMAT=${=audio-codec-name}
    INFO_AUDIO_CODEC=${=audio-codec}
    INFO_AUDIO_RATE=${=audio-params/samplerate}
    INFO_AUDIO_NCH=${=audio-params/channel-count}
    INFO_LENGTH=${=duration:${=length}}
    INFO_DEMUXER=${=current-demuxer:${=demuxer}}
    INFO_SEEKABLE=${=seekable}
    INFO_TITLES=${=disc-titles}
    INFO_CHAPTERS=${=chapters}
    INFO_TRACKS_COUNT=${=track-list/count}
    METADATA_TITLE=${metadata/by-key/title:}
    METADATA_ARTIST=${metadata/by-key/artist:}
    METADATA_ALBUM=${metadata/by-key/album:}
    METADATA_GENRE=${metadata/by-key/genre:}
    METADATA_DATE=${metadata/by-key/date:}
    METADATA_TRACK=${metadata/by-key/track:}
    METADATA_COPYRIGHT=${metadata/by-key/copyright:}
    INFO_MEDIA_TITLE=${=media-title:}
    INFO_STREAM_PATH=${stream-path}
    --term-status-msg=STATUS: ${=time-pos} / ${=duration:${=length:0}} P: ${=pause} B: ${=paused-for-cache} I: ${=core-idle} VB: ${=video-bitrate:0} AB: ${=audio-bitrate:0} C:/Users/Przemek/Desktop/film Monika/SUNP0181.AVI
    Playing: C:/Users/Przemek/Desktop/film Monika/SUNP0181.AVI
    Failed to recognize file format.
    Exiting... (Errors when loading file)
    Co tutaj musze zrobic, aby filmy sie odtwarzaly, widze ze brakuje wszystkich atrybutow, kodek GMP4 tez mam zainstalowany, jednak filmy dalej sie nie odtwarzaja. Czy jest jakis sposob, aby atrybuty pliku byly widoczne?
  • #2 16396400
    piotrek86
    Help: 67
    Rate: 192
    Try QuickTime Player
  • #3 16396480
    Mapciu
    Error 2048> Wuicktime was unable to interpret the file
  • #4 16396607
    mistrzszymon1
    Help: 59
    Rate: 94
    I personally prefer VLC media player. he always helped in such situations :)
  • #5 16396850
    Mapciu
    VLC has also been tested, unfortunately it has not been able to ...
  • #6 16397004
    Artur34
    Help: 5
    Rate: 16
    Try to open it from the potplayer download from the official site and load additional codecs that will ask you for installation.
    Maybe the webcam itself is already corrupting files or memory card.
    You can also try the file conversion option via VLC file -> Convert / save
    If the above does not work, you can still use Any Audio Converter
  • #7 16397441
    linuks
    IT specialist
    Help: 1473
    Rate: 491
    Pack a movie to zip and put on the forum to see what it is. Because without such a movie it will only be a begging.
  • #8 16398128
    Mapciu
    Here, one example, unfortunately, the above-mentioned methods have also failed. :(
    • SUNP0190.zip (29.92 KB) You must be logged in to download this attachment.
    • SUNP0125.zip (24.78 KB) You must be logged in to download this attachment.
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    The file is empty, you can see it already after the 24MB file compression level -> 24KB.
  • #10 16398258
    linuks
    IT specialist
    Help: 1473
    Rate: 491
    Exactly, instead of the video, it is written with the numbers FF. You will not do anything about it because it is not a video file.
    Greetings.
  • #12 16902586
    safbot1st
    Help: 2719
    Rate: 1585
    The film does not play. The link is broken. Put the shortest film you have in the packed file as an attachment.
    ps. Do not pick up other people's topics, but create new ones.
  • #13 16902619
    dapietros
    I wanted to add a new topic, but I do not have that much point :(
    • MOVI3564.7z (11.1 KB) You must be logged in to download this attachment.
  • #14 16902630
    safbot1st
    Help: 2719
    Rate: 1585
    Please, I send points.
    My linux ffinfo 1.0 says that the video did not detect any video or audio data.
    The file probably damaged, but for what reason I do not know.
  • #15 16902652
    dapietros
    Thank you for points :)
  • #16 16902668
    safbot1st
    Help: 2719
    Rate: 1585
    Cool. The same as in the subject - the file is damaged - same FF in the hex editor.
The discussion revolves around difficulties in playing videos recorded by a Slim FHD 1080p car camera using various media players, including Allplayer, Windows Media Player, and MPlayer. Users report encountering errors, such as "Error 2048" with QuickTime and issues with VLC and PotPlayer. Suggestions include trying different players, converting files using VLC, and checking for file corruption. One user noted that the file size significantly decreased during compression, indicating potential damage. The consensus is that the video files may be corrupted or improperly recorded, leading to playback failures.
