Connection Diagram for Daewoo Window Switch Adaptation for Daihatsu Feroza Installation
TheKocur 7800 2
  • #1 16398289
    TheKocur
    Rate: 11
    Hello, a few months ago I was in the scrap yard and bought such a window switch Connection Diagram for Daewoo Window Switch Adaptation for Daihatsu Feroza Installation I don't remember anymore what he was from. I don't remember the model, but from what I saw on the internet it was from Daewoo Nubira. I want to connect it to the Daihatsu Feroza, because it would be difficult to find such a switch for this car. Anyone have a schematic of this switch?
    g107r
    Help: 811
    Rate: 993
    1 light blue mass
    2 orange + 12V
    4 brown mass
    5 dark blue engine
    6 dark green ?? backlight weight
    if it's a different color, check the numbers from the switch to see if it is nubira.
    8 brown engine
    Is it supposed to work as an INDEPENDENT switch, or replace the burned one in the passenger's door and be connected to the main driver's panel, i.e. to act as a connector of the FIRST switch in the driver's panel with the motor in the door?
    In Nubira it is the right front door, the driver has his own switch.
  • #3 16401719
    TheKocur
    Rate: 11
    I close the topic.
    I connected according to the diagram of my colleague above :)
