Beko WMB71042PTLMA Washing Machine: Door Lock Issue after New Lock Installation
Grzegorzk101 18168 7
  • #1 16493116
    Grzegorzk101
    The problem is with starting because they do not want to lock the door. New lock only after insertion. Help.
    Kenworth 18
    Help: 2442
    Rate: 3749
    If the previous blockade has burned and this is the reason for its replacement with a new one, the block may have been damaged or the washing machine electronics have been damaged.
    First, start by checking the cables from the lock to the electronic module. If the cables are OK, the controller must be repaired.
  • #3 16493155
    Grzegorzk101
    Thank you. I'll search.
    Added after 13 [minutes]:
    Which means "C on" after pressing the button.
  • #4 16493663
    Kenworth 18
    Help: 2442
    Rate: 3749
    You have the "child lock" function activated, and with the help of the operating instructions you must disable this function because you will not turn on the washing machine.
  • #5 16493742
    Grzegorzk101
    Approx. I have turned off the features, but I still cannot turn on.
  • #6 16493789
    Kenworth 18
    Help: 2442
    Rate: 3749
    Describe how the washing machine failed and whether this message was displayed after the failure. You didn't accidentally press the buttons to start the washing machine and didn't accidentally turn on the lock?
  • #7 16493829
    Grzegorzk101
    The washing machine did not fire after replacing the door release button. The lock did not activate and nothing could be done so I replaced the lock mechanism in the hope that it would help but nothing has changed. I have combined with reset, but the standard methods did not produce any results. As a result of various reset combinations, I arrived at the washing machine with the "start / stop" button pressed and E17 appears. When you release the button to do something, everything appears on the display
    and he won't do anything. You can only turn it off and start playing again, but "in dirty clothes" :cry:
  • #8 16497620
    Lodxx
    Home appliances specialist
    Help: 105
    Rate: 245
    Probably damaged Triac controlling the blockade, remove the module and send photos in good quality here.
The discussion revolves around a Beko WMB71042PTLMA washing machine experiencing a door lock issue after a new lock installation. The user reports that the machine fails to start due to the door not locking properly, despite replacing the lock mechanism. Responses suggest checking the wiring to the electronic module, ensuring the child lock function is disabled, and investigating potential damage to the control electronics, specifically the Triac controlling the lock. The user also mentions encountering an E17 error code during troubleshooting attempts.
