Sharing VPN Connection via WiFi: TP-LINK TDW8901G Router, Windows 10 Laptop, HotSpot Setup
kalin24 6756 10
Can I share a laptop’s VPN connection over a Wi‑Fi hotspot so other devices use the VPN instead of my normal network?
Yes, but the hotspot must route connected devices’ traffic through the VPN’s virtual adapter; otherwise you can get “connected but no internet” [#16403949][#16403941] The thread suggests checking the routing setup on the laptop and comparing `ping 8.8.8.8`, `tracert -d 8.8.8.8`, `route print`, and `ipconfig /all` before and after connecting the VPN to see where it breaks [#16403941] A simpler solution is to run the VPN directly on the router instead of on the laptop, because that makes the router itself send all clients through the tunnel [#16404956][#16405353] In this case the TP-LINK TDW8901G was reported to have no VPN configuration options, so a newer router was used successfully [#16453229] If you set up a router VPN, avoid PPTP if possible because it is not completely secure [#16453229][#16453465]
  • #1 16403586
    kalin24
    I have a TP-LINK TDW8901G router at home and a VPN software installed on my laptop with windows 10. I wanted to provide a VPN over WiFi (access point made in laptop) so I could connect to another laptop or smartphone with a VPN installed on that laptop. Can you make a HotSpot with a VPN?
  • #2 16403723
    arcis
    Depends on the VPN, mine creates a virtual network card with an address pool, and I came up with the idea of a bridge connection, and you can configure it nicely.
    I did that virtualbox bridgje a real network card and on virtual os I have real ip and on vpn computer, I just started to work out a proxy server and there are patents by the way ...
  • Clarifying VPN hotspot client setup and intended network topology
    #3 16403790
    m.jastrzebski
    Help: 679
    Rate: 865
    And where is the other laptop or cell you want to set up a VPN with?
    Or else, describe what you want to achieve because I don't get the idea of all the fun too much.
  • #4 16403925
    kalin24
    The other devices I want to connect to the VPN are at home.
    The general idea is to secure your internet connection by having one software on your computer (CyberGhost) that creates the VPN (creates a virtual network card). The computer on which the software is installed is secured, and now I want to create an access point (hotspot) on the laptop for other devices to connect to the internet via a VPN, not through my real network.
    I have already done so that I installed the Connectify program that creates HotSpot, I created a new WiFi network through which I made this virtual network card that CyberGhost created, but after connecting to this created network, the message "Connected but no internet" appears
  • #5 16403941
    bogiebog
    Help: 2569
    Rate: 1530
    Maybe cyberghost does not allow work on the router? (because in this configuration your computer is a router), i.e. it only protects connections from this computer and not from other computers.
    No VPN connection, show me
    ping 8.8.8.8
    tracert -d 8.8.8.8
    route print
    ipconfig / all
    now connect the VPN and show the above-mentioned commands again, paste the results into the "spoiler" section
  • #6 16403949
    m.jastrzebski
    Help: 679
    Rate: 865
    The Internet suggests that this CyberGhost is a VPN service. You run it on your computer and come out into the world from their VPN server. This is not related to any security but "anonymity" or bypassing regional restrictions.
    If you want an access point and devices like a cell on the same computer to connect to this access point and then fall into a VPN, you have to teach the computer to route such traffic. I recommend that you read the ROUTE command.
  • #7 16404956
    KOCUREK1970
    Help: 3860
    Rate: 5488
    And it's not easier to run such a VPN on the router?
  • #8 16405150
    kalin24
    ping 8.8.8.8
    tracert -d 8.8.8.8
    route print
    ipconfig / all
    Tomorrow I will try to check these commands
    Yes, indeed that would be the best solution, I wouldn't have to use a laptop for WiFi sharing, maybe someone has already set up a VPN on the router and would suggest how to do it? I do not know if this can be done on my router, I have to check.
  • #10 16453229
    kalin24
    KOCUREK1970 wrote:
    kalin24 wrote:
    I don't know if this can be done on my router
    It should (maybe not exactly the same models, but I suspect the same configuration principle):
    http://www.tp-link.com.pl/faq-244.html
    http://www.tp-link.com.pl/faq-411.html
    http://www.tp-link.com/no/FAQ-558.html
    In the TP-LINK TDW8901G router I did not find any options for VPN configuration, this is an older model.
    I got a newer router and configured myself to tunnel in the settings.
    Indeed, setting up a VPN on your router is the best and easiest way.
    If someone wants to configure such a connection, I recommend choosing a protocol other than PPTP, because from what I read it is not completely secure.
  • #11 16453465
    m.jastrzebski
    Help: 679
    Rate: 865
    This is not entirely true. PPTP encryption is breakable. But if something well secured is traveling through the tunnel, decoding PPTP will not help anyone because it will collide with the wall anyway.
    If you do something reckless, e.g. you log into the FTP server without encryption, the password is flying in plain text. If it's a piece through a hyper-secure tunnel and then a piece of public internet, then where's the safety? Someone will "overhear" this password in the public part as much as possible.
    Using strong VPNs makes sense when you connect 2 locations (e.g. two branches of the company) and some unsecured data will travel through this tunnel.
    If you use a VPN to go out to the public internet elsewhere, it doesn't matter what protocol you use, because you will leave the "secure" tunnel anyway.
    I use a VPN service to get a "public" IP address and be able to enter my home network. And I use PPTP on purpose.
The discussion revolves around setting up a VPN connection via WiFi using a TP-LINK TDW8901G router and a Windows 10 laptop with CyberGhost VPN software. The user aims to create a hotspot on their laptop to allow other devices to connect through the VPN. Initial attempts using Connectify resulted in a "Connected but no internet" message. Responses suggest that CyberGhost may not support routing traffic from other devices, and configuring the VPN directly on the router is recommended for a more effective solution. The user later confirmed that their older router lacked VPN configuration options, leading to the acquisition of a newer router that supports VPN tunneling. It is advised to avoid using PPTP due to security concerns, although some users argue its effectiveness in certain scenarios.
