Troubleshooting VPN Connection Issue on Windows 10 with TP-Link Network Card: Steps & Fixes
Dajanc 3489 4
  • #1 17257656
    Dajanc
    Hey,
    I ran into a problem with my VPN connection recently.
    From my desktop computer at home, which receives the internet via a TP-link network card, I connected via a configured VPN connection to IP from my work. Recently, however, when I click "Connect", the procedure ends with the message "Connecting" to no avail.
    I found that deleting the connection and reconfiguring it works, but the next time the problem recurs. I'm using Windows 10.
    Can anyone help me?
  • #2 17257725
    sanfran
    Help: 963
    Rate: 3004
    My IT from work also complains about the VPN lift and the company switched to another solution. On my work computer, I use PULSE SECURE software for VPNs.
  • #3 17257728
    pitron
    Help: 51
    Rate: 100
    Do you choose the whole connection setup automatically.
    Maybe it adopts some settings permanently after the call ends.
    Ask your IT what parameters to set manually, e.g. L2TP / IPSec etc ...
  • #4 17257734
    Dajanc
    I don't seem to do anything automatically
    I set the name
    IP
    Network type: L2TP / IPsec with pre-shared key
    I have a key so I enter it
    Login Information Type - Username and Password
    I have the above data, so I enter it,
    I click save and connect later.
    The box with the remember my login information function is of course checked.
    I don't know but I have the impression that the problem has occurred since the last Windows update. Can it have an impact?
  • #5 17266420
    Dajanc
    Hey,
    I found something like this:
    http://hideipvpn.pl/windows-10-rs4-1803-vpn-problem/
    Nothing specific, but it could be update related .. Anyone able to help?
    I will add that I tried to install this add-on but it failed with the message that it is not suitable for this version.
