Golf 4 1.6 Sr: Horn & AirBag Driver Issues - Checking Relay Placement & Functionality
Armator44 17232 5
  • #1 16404203
    Armator44
    Namely, I do not have a horn and I have an AirBag driver, I read a lot of threads and various forums for repair, and still where I would not check it was not (+). the relay was also not heard when the horn pushed .. I got to the relays and took a picture
    Well, my question. Are the relays well inserted ??
  • #2 16404267
    piotrek22101
    Help: 695
    Rate: 1421
    The steering wheel may be damaged, it connects the mobile part of the steering wheel with the plugs. Typically, a pillow, horn, radio control goes it.
    • Golf 4 1.6 Sr: Horn & AirBag Driver Issues - Checking Relay Placement & Functionality tasma-pod-kierownice-golf-iv-passat-b5-audi-a3-3441182971.jpg (31.6 KB) You must be logged in to download this attachment.
  • #3 16404283
    Armator44
    Tape efficient pulled out and checked and the radio I have a drawback because there is no bass even when tweak
    piotrek22101
    Help: 695
    Rate: 1421
    To my knowledge, the bottom row, the first relay from the left with the number 53. It's best to take it out and check if there are voltages in the stand.
  • #5 16404489
    Armator44
    I have switched the relay and the horn is working.
    Thank you
  • #6 16404501
    piotrek22101
    Help: 695
    Rate: 1421
    Check whether everything is there, you have changed the place of the relay.
