Hello, today I bought a mower shown in the pictures for PLN 60. Can someone tell me what this engine is? My way is some Briggs & Stratton. But can someone tell me a more accurate model?
It's a Briggs & Stratton engine. Sprint or Classic model.
On the sheet metal casing of the starter, on the side of the MTD 3.5 inscription, near the spark plug, the bearings: Model, Type, Code should be stamped.
Thanks. And do you know if elements such as the carburetor, air filter, fuel pump, spark plug are the same in these 3.5 HP Briggs & Stratton engines? Because I can see that most of these engines look the same, only with a different muffler.
Ok thanks for your help. So I understand that even if I bought a second Briggs & Stratton 3.5 HP engine, for example: parts from mine will fit. One more thing how much oil enters?
I know this is an old topic. But I am looking for a manual on how to put a mower like this together. I have the wheels not mounted and have no idea how to put it together. I don't even know if something is missing. Please help.
The discussion centers around identifying the engine of an MTD 3.5KM mower, which is confirmed to be a Briggs & Stratton engine, likely a Sprint or Classic model. Users inquire about the interchangeability of parts such as the carburetor, air filter, fuel pump, and spark plug among different 3.5 HP Briggs & Stratton engines, with responses indicating that these components are nearly identical and interchangeable. Additionally, it is noted that the engine requires 0.6 liters of oil. A separate user seeks assistance with assembling the mower, indicating potential missing parts. AI summary based on the discussion. May contain errors.
