Protocol of periodic measurements of machines and devices - hydraulic lift.
elpapiotr 18678 13
How should a recurring two-year electrical inspection protocol for a hydraulic lift be assessed and corrected when it contains apparent copied or inconsistent entries?
The protocol should be corrected instead of being reused, because it contains apparent copy/paste and measurement-description errors; a two-year measurement interval is generally appropriate unless special environmental conditions apply [#16429239] It should state the inspection date and applicable standards, including the relevant PN-HD 60364 requirements [#16411086] [#16429239] The reviewer specifically questioned the recorded protective-device data for the B breakers and the unusually long RCD tripping time compared with the previous protocol [#16411086] Other flagged inconsistencies include the TN-CS designation, PE appearing in insulation measurements, N connected to the motor, 230 V control voltage, and measurements from all three phases to N [#16409994] Responsibility for producing accurate paid measurement protocols rests with the surveyor, not with the UDT inspector who later reviews them [#16409994] [#16429239]
  • #1 16409741
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3532
    I got it for inspection - a guest from UDT crashes one and the same every two years:
    Quality is poor, because the client has a poor scanner.
  • #2 16409823
    jann111
    Help: 180
    Rate: 507
    Any questions? :D
    The litany of errors is obvious, but apparently the power of the paper is enough. :|
  • #3 16409911
    elpapiotr
    Help: 1015
    Rate: 3532
    And what are the questions.
    Attachment included for educational purposes - that's how you write protocols!
  • #4 16409994
    mawerix123
    Help: 482
    Rate: 951
    How to read it is spelled ;)
    The client went with the house receipt documents and the clerk questioned the measurement reports because she found the cables on the geodetic map, and I marked the reports with a rough font for the woman and added an appropriate note in the comments, maybe now she will find ...
    As for the inserted TN-CS protocol and where PE in insulation measurements :?: , N to the motor, 230V control voltage and measurement from three phases to N .... etc. resetting at RCD
    Often protocols are picked up by people who cannot read them, only when something is happening is there more serious interest in what has been written.
  • #5 16410752
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    This protocol is suitable for mummy, an anonymous text message with the url to the "specialist" also indicated. :lol:
    Ps. So who will "point out" the protocol? Criticizing is fun, but faulting criticism will certainly gain recognition (not only mine, I think). :wink:
  • #6 16410768
    elpapiotr
    Help: 1015
    Rate: 3532
    No problem, and I see no obstacles to move it.
    The customer, on the other hand, is of the opinion that the responsibility for this lies with the measurement person (paid measurements), the more so as these protocols are repeated every 2 years, with minor modifications in the details.
  • #7 16410918
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    Sorry, but I don't know what the hell's going on:
    Protokół wrote:
    The result of the measurement of the effectiveness of the protective reset measurements as a force circuit (...)
  • #8 16410941
    elpapiotr
    Help: 1015
    Rate: 3532
    Buddy Łukasz, there are more flowers there, you have to read. :D
  • #9 16410981
    Łukasz-O
    Help: 654
    Rate: 4292
    Then I would have to copy the entire protocol :D
  • #10 16411086
    elpapiotr
    Help: 1015
    Rate: 3532
    Why and what for?
    That's it. :D
    But:
    - date and standards
    - breaking current of protection (switches "B")
    - strange, rare time of RCD tripping (in the previous protocol it was given 10 times shorter)
  • #11 16411154
    Łukasz-O
    Help: 654
    Rate: 4292
    Because there was probably C16 on another site. The surveyor changed only to B and left the rest :D
  • #12 16411174
    elpapiotr
    Help: 1015
    Rate: 3532
    Probably not.
    I explained this in post # 6
  • #13 16429239
    mechatronikowiec
    Unfortunately, copy / paste errors do happen, but this protocol does not differ much from other utb protocols. If you want to attach yourself to something else, the applicable standard is PN-HD 60364 and that should be changed. The frequency of measurements every 2 years is appropriate, unless special environmental conditions exist.
    And of course it is not the "UDT guy cracking these protocols" but the surveyor :)
  • #14 16703552
    elpapiotr
    Help: 1015
    Rate: 3532
    Thank you for participating in the discussion.
    I close the topic.
The discussion revolves around the protocol for periodic measurements of hydraulic lifts, specifically addressing issues encountered during inspections by UDT (Office of Technical Inspection). Participants highlight the importance of accurate documentation and the challenges posed by poorly written protocols. There are mentions of specific measurement standards, such as PN-HD 60364, and the necessity of adhering to them every two years unless special conditions apply. The conversation also touches on the responsibilities of measurement personnel and the common errors found in protocols, including copy/paste mistakes and misinterpretations of measurement results. Overall, the dialogue emphasizes the need for clarity and precision in technical documentation to avoid misunderstandings during inspections.
