Iveco Daily 35C15 Catching Brake Issue: Falling Brake, New Pump & Blocks, Servo, ABS System
lukaszlublin 23730 15
Why does the brake pedal on an Iveco Daily 35C15 sink to the floor while driving even after replacing the pump, pads/calipers and bleeding the system?
The most likely cause is that the ABS-equipped brake system has not been bled correctly; a normal bleed can leave air in the circuit and make the pedal drop to the floor, so the ABS brake system needs its specific bleeding procedure [#17188515] Also check that the master cylinder/pump is the correct size for the vehicle—there are 25.04 mm and 28.58 mm versions—and verify the clearance between the pump and the servo pushrod [#17190003] If the problem still remains, one reply points to the ABS pump or a poor-quality substitute pump, and recommends an original pump and branded brake fluid [#16414922][#16414273]
  • Brake pedal sinks despite new components and bleeding
    #1 16413343
    lukaszlublin
    Hello forum members,
    The topic has already been raised several times but not resolved.
    Problem in the falling brake on Iveco. When braking by car, the brake goes all the way to the floor.
    At a standstill, it hardens several times under the pumped one. Everything looks like it's OK.
    -new blocks
    -new terminals
    -new pump
    - servo working
    -tight cables
    - 100% vented system
    -no errors on the computer regarding the ABS pump
    - ABS functional
  • #2 16413570
    ociz
    Help: 1379
    Rate: 3487
    lukaszlublin wrote:
    -new terminals
    Which? The rear are falling apart, especially after unskilled handling. Check the effectiveness of the handbrake.
  • #3 16414216
    lukaszlublin
    ociz wrote:
    lukaszlublin wrote:
    -new terminals
    The car brakes while driving, but the brake takes too low and it is hard to brake with increased load weight.
    The handbrake works fine.
  • #4 16414273
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    There is no air and nowhere is leaking and the pedal falls in, i.e. the pump passes and there will be no other reason. Buy ori pump, pour branded liquid and not no name from the station (I use Organika successfully) and the problem should disappear for a long time. LPR iveco pump substitutes are often broken from the news or fall after a week.
  • #5 16414922
    Hart3
    Help: 100
    Rate: 479
    The reason may be the ABS pump, for this condition I have prepared connectors for test elimination from the system.
  • #6 17188441
    janczuro
    Rate: 21
    Hello. Did your friend solve a problem with the brake pedal? I have the same Iveco 35C15 from 2010. Brake discs and pads have been replaced, rear calipers after regeneration, manual functional. The system is 100% vented. I checked the brake pump so it also falls off. I wonder if the ABS pump can be this reason (abs is good).
  • #7 17188515
    Staszek49
    Help: 228
    Rate: 1141
    Gentlemen, before replacing the brake pads, etc., the ABS pump was operational, because if so, the brakes were not properly bled.
    The braking system with ABS requires a slightly different way of bleeding - the forum contains detailed descriptions and videos.
  • #8 17189861
    janczuro
    Rate: 21
    For me, ABS normally switched on in winter. I have had this problem with the brake since I bought the car, i.e. for about a year, but before the repair the brake, despite the fact that it was quite effective. And now it is much weaker, the car traveled about 1000 km so the blocks should have already reached. I vented the system in several ways, the pedal does not just grow soft and falls into the floor as if the master cylinder is not efficient enough. I wonder if it is possible that the ABS pump is so airy that no way of venting by pressing the brake pedal it will not be effective but connecting the venting pump can help.
  • #9 17190003
    Megawe
    Help: 246
    Rate: 1441
    You can check the clearance between the pump and the stem in the servo. The pump diameter is important because they can be 25.04 mm or 28.58 mm. If there is a brake power corrector in the system, it can also cause that the pedal will be as low as the "pig tails" on these copper wires. The brakes can be bled without leaking the system. Unscrew the caliper, press the brake pedal several times so that the piston extends, set the caliper so that the fluid inlet is on top and quickly press the piston. We do this several times, the second person can check if the fluid with air is returning in the tank. It's a good idea to apply special brake cylinder grease.
  • #10 17190167
    janczuro
    Rate: 21
    Thank you for your answer. Can a colleague write if the dimensions of the diameter of the master cylinder which he gave are the dimensions of the piston or the whole pump. Because maybe my car has the wrong master cylinder. The car had a replaced cabin and the pump probably came from this cabin. with pushing the piston, I did so with the rear calipers (Brembo with handbrake) with the difference that the rear calipers are screwed in and I unscrewed the vent when screwing in. I had them disassembled (replacing the rubber bands) and after folding and filling with the liquid, there is always air in them somewhere so I vented them. Of course, the vented system was also a traditional method.
  • #11 17909542
    Soltysc11
    Rate: 9
    Hello. I with a similar problem, braking on a remote engine. After regenerating the terminals. Someone solved the problem?
  • #12 19290934
    Dawid_d153
    Rate: 14
    Hello, was the problem with the falling brake resolved?
  • #13 19457516
    jacZek
    Rate: 69
    Hello. I also have such a problem after replacing the rear calipers. The brake goes down
  • #14 19640155
    sebek0614
    Rate: 19
    Hello, can anyone share information on how to deal with the brakes because I have no idea anymore. I have already spent many hours on this car, two workshops have been lost, including ASO and the car still does not brake as it should
  • #15 21919987
    automister
    Hello, have you managed to sort out the problem with the brake sticking?
  • Bypass ABS/ESP pump if pedal sinks stationary
    #16 21920205
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    Why bother fixing this problem? As long as the pedal is high when the engine is off, it’s fine. The only real solution is to bypass the ABS/ESP pump if it bothers you that the pedal sinks to the floor when the car is stationary. The important thing is that when you’re driving, it brakes effectively, and that’s all that matters. I used to drive a Renault where the pedal would drop when the car was stationary if you pressed it harder, and the braking was brilliant.
Discussion about an Iveco Daily 35C15 with a brake pedal that sinks to the floor while driving, although the pedal becomes hard when pumped at a standstill. The system has new pads, calipers/terminals, brake pump, functioning servo, tight lines, full bleeding, no ABS fault codes, and working ABS, but braking remains weak under load. Suggested causes include a defective master cylinder/pump, incorrect pump diameter or clearance with the servo pushrod, air trapped in the ABS pump, improper bleeding procedure for ABS systems, rear brake issues, or a brake force corrector problem. Some replies recommend checking the handbrake, using an original master cylinder and quality brake fluid, and testing or bypassing the ABS/ESP pump if necessary.
