Damaged HGST Z5K500-500 Drive: Recover Data from 500GB, RAW Filesystem, Windows 10/XP
lufa9999 10968 7
  • #1 16414721
    lufa9999
    Rate: 138
    I have a problem with a 500GB drive, HGST, Z5K500-500. I have downloaded the much-needed data for it. He has been working properly until today. Now, about connecting with the USB cable, I have the message: "H: / is not available. The file or directory is damaged and unreadable". I tried a different cable, another USB input but the problem is. In the disk manager, it appears as a healthy, RAW filesystem. Interestingly, Crystal Disk Info states that the disk is good. There's something in it that works. I really care about this data, not on the disk. Is there any option of downloading this data from it to another disk? I have Windows 10 or Windows XP.
    Thanks in advance for your help!
    kokapetyl
    Help: 1787
    Rate: 2108
    Since this data is important, first make a poseector copy
    https://www.elektroda.pl/rtvforum/topic1330869.html
    It was only then that data recovery / repair attempts were made from copies.
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    Buddy but RAW Windows will not read.
    Is this disk formatted on RAW?
  • #4 16414751
    lufa9999
    Rate: 138
    No, he normally acted as a backup external drive, I used to rip data on him and it was OK. It's only crazy today. Try this with a copy of a posture?
    kokapetyl
    Help: 1787
    Rate: 2108
    Yes, any games on this disc are dangerous and you may lose data.
    I recommend DMDE for the copy, the program described in the given link.
  • #6 16416231
    lufa9999
    Rate: 138
    Ok. I have this poseector copy. What to do next?
  • #8 16416390
    lufa9999
    Rate: 138
    OK, I regained everything. Thanks for the help!
A user reported issues with their 500GB HGST Z5K500-500 drive, which became unreadable and displayed a RAW filesystem error. Despite the drive being recognized as healthy by Crystal Disk Info, the user was unable to access their data. Recommendations included creating a poseector copy of the drive before attempting any data recovery, using tools like DMDE for data recovery from the copy. After following the suggested steps, the user successfully recovered all their data.
