Convert USB External Drive from RAW to NTFS after Samsung TV Connection: Recover 500GB Data
shivygliwice 5394 9
How can I recover data from a USB external drive that turned RAW after being connected to a Samsung TV?
You generally should not try to convert the RAW drive back to NTFS first; recover the files with a data-recovery tool, then format the disk afterward. Check the drive’s SMART status in CDI or Hard Disk Sentinel to rule out physical damage, and inspect the partition layout in DMDE [#16800303] In DMDE, open the detected partition and check the contents of $Root / $MFT; if needed, boot a Linux live system and note the mount error code, because the file system structure is probably corrupted [#16800483] [#16801454] In this thread, Active@ File Recovery was able to copy out the needed files from the RAW disk [#16803879] After the important data is recovered, you can try chkdsk or format the drive, but chkdsk will not run on a RAW volume and is irreversible [#16803912] [#16803918]
  • #1 16800280
    shivygliwice
    Rate: 23
    I am asking you for help. I plugged a USB external drive to a Samsung TV in order to watch a movie from the drive on a TV. After disconnecting it and reconnecting it to my Windows computer, I want to format it. In the properties, I can see that the format has been changed from NTFS to RAW.
    Is there any way to change back to NTFS to recover the data (about 500GB) I have there?
    Dra98
    Help: 1321
    Rate: 1076
    shivygliwice wrote:
    Is there any way to change back to NTSF to recover the data I have there?
    Please include a screen from SMART, e.g. from CDI or Hard Disk Sentinel to exclude damage to the HDD. In addition, I am asking for a screen from the DMDE program window partitions, current partitioning.
  • #3 16800328
    shivygliwice
    Rate: 23
    Convert USB External Drive from RAW to NTFS after Samsung TV Connection: Recover 500GB Data Convert USB External Drive from RAW to NTFS after Samsung TV Connection: Recover 500GB Data
    was that it?
    mati211p
    HDD and data recovery specialist
    Help: 2585
    Rate: 1133
    Go to Toshiba Ext in DMDE and check the content. If your data is there, check for errors in $ MFT, or use Linux live (on CD or USB flash drive) and enter the error code that appeared when trying to mount the partition. Some part of an important file system file is corrupted probably.
  • #5 16801286
    shivygliwice
    Rate: 23
    I don't know if that was what DMDE was about
    how to view files with programs, e.g.
    Active @ recovery File
    m3 data recovery
    both programs show that the data on the disk is there
    mati211p
    Help: 2585
    Rate: 1133
    But you entered $ Noname 02 and not Toshiba EXT in DMDE. You were supposed to go to Toshiba EXT and check the contents of $ Root. It still looks like an attempt to create a partition yesterday at 4:51 pm. Also provide messages from linux live as I wrote. Maybe the whole thing can be recovered, because if not, you will be left with recovery programs.
  • #7 16803879
    shivygliwice
    Rate: 23
    I downloaded the Active @ File Recovery program and with this program I was able to rip the necessary files from the disk.
    The only question is whether the disk is fit for use after formatting or the situation that took place rather disqualifies the disk as damaged?
    when it comes to linux live, I still managed to do this operation
    mati211p
    Help: 2585
    Rate: 1133
    Since you recovered important data (what you wanted) and you even want to format it, now you can even use chkdsk with a clear conscience and see if the data will be restored directly on the lost partition after using it. If you want to recover something else, it's best to use chkdsk as it is irreversible. I am writing this because I do not know the logical corruption in the current partition and I have not checked them. SMART is ok, probably disconnected from the power supply too soon, or some other situation.
  • #9 16803918
    shivygliwice
    Rate: 23
    after typing chkdsk option pops up message that it is a RAW drive and chkdsk option does not work: /
    unless I'm doing something wrong
  • #10 16803935
    mati211p
    Help: 2585
    Rate: 1133
    This surprised me a bit, I must say, because in DMDE there are all pointers and $ MFT classes.0 is ok. If this is impossible, give the error code from linux live as I wrote. We'll see what still prevents chkdsk from being performed, which I don't know. There is probably another non-standard way, but it definitely goes against the rules of data recovery, so I probably won't even mention it ;) .
A user encountered an issue with a USB external drive that changed from NTFS to RAW format after connecting it to a Samsung TV. They sought assistance to recover approximately 500GB of data and restore the drive to NTFS. Responses included suggestions to use the DMDE program to check partition contents and errors, as well as recommendations for data recovery software like Active @ File Recovery. The user successfully recovered files but questioned the drive's usability post-recovery. Further advice included using chkdsk, although the user faced challenges due to the RAW status of the drive. The discussion highlighted the importance of checking SMART data and potential file system corruption.
