DNS Server Unavailable: Troubleshooting Laptop's Internet Connection after Wi-Fi Router Connect
Kiritsu 14097 5
  • #1 16418355
    Kiritsu
    Hello, I have such a problem namely on one of the laptops does not work for me Internet after wi fi connect with the router, before there was no such problem on the other hand, on the second laptop and also phones work with this wi fi without a problem. Changing the DNS address to 8.8.8.8 did not help. What to do with this? I need help urgently
  • #2 16418563
    bogiebog
    Help: 2569
    Rate: 1530
    start the computer in safe mode + network support, does the problem still occur?
  • #3 16418681
    Kiritsu
    Yes, this problem still occurs
  • #4 16418755
    bogiebog
    Help: 2569
    Rate: 1530
    On the computer where net is, run cmd.exe, enter
    ping onet.pl
    ping 8.8.8.8
    tracert -d 8.8.8.8
    ipconfig / all
    paste results into the "spoiler" section
    do the same on a computer where there is no net and show the results.
  • #5 16419697
    Kiritsu
    tutaj dane z laptopa z internetem
    Spoiler:
    Pinging onet.pl [213.180.141.140] with 32 bytes of data:
    Reply from 213.180.141.140: bytes=32 time=17ms TTL=56
    Reply from 213.180.141.140: bytes=32 time=20ms TTL=56
    Reply from 213.180.141.140: bytes=32 time=18ms TTL=56
    Ping statistics for 213.180.141.140:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 17ms, Maximum = 20ms, Average = 18ms
    C:\Users\pandi>ping 8.8.8.8
    Pinging 8.8.8.8 with 32 bytes of data:
    Reply from 8.8.8.8: bytes=32 time=61ms TTL=46
    Reply from 8.8.8.8: bytes=32 time=62ms TTL=46
    Ping statistics for 8.8.8.8:
    Minimum = 61ms, Maximum = 62ms, Average = 61ms
    C:\Users\pandi>tracert -d 8.8.8.8
    Tracing route to 8.8.8.8 over a maximum of 30 hops
    1 ping onet.pl
    The ping command can not find the onet.pl host. Check the name and try again
    Be.
    C: \ Users \ PC> ping 8.8.8.8
    Study 8.8.8.8 with 32 bytes of data:
    Request period has passed.
    Response from 192.168.1.1: The target network is not reachable.
    Ping statistic for 8.8.8.8:
    Packets: Sent = 4, Inbox = 1, Lost = 3
    (75% loss),
    C: \ Users \ PC> tracert -d 8.8.8.8
    Tracking to 8.8.8.8 with a maximum of 30 hops.
    1 * * * Request period has timed out.
    2 * * * Request period has timed out.
    3 * * * Request period has timed out.
    4 * * * Request period has timed out.
    5 * * * Request period has timed out.
    6 * * * Request period has timed out.
    7 * * * Request period has timed out.
    8 * * * Request period has passed.
    9 * * * Request period has timed out.
    10 * * * Request period has timed out.
    11 * * * Request period has timed out.
    12 192.168.1.1 reports: The target network is not reachable.
    Tracking completed.
    C: \ Users \ PC> ipconfig / all
    Windows IP configuration
    Host name. . . . . . . . . . . : PC-Computer
    The suffix of the primary DNS domain. . :
    The type of node. . . . . . . . . . . . : Hybrid
    IP routing enabled. . . . . . . : No
    WINS Proxy server enabled. . . . : No
    Wireless LAN card Wireless network connection 2:
    Carrier status. . . . . . . . . . .: Media disconnected
    The DNS suffix of a specific connection:
    Description. . . . . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter
    Physical address. . . . . . . . . . : 16-F0-6D-94-AE-3C
    DHCP enabled. . . . . . . . . . : Yes
    Autoconfiguration enabled. . . . : Yes
    Ethernet card Local connection:
    Description. . . . . . . . . . . . . . . : Atheros AR8131 PCI-E Gigabit Ethernet C
    troller (NDIS 6.20)
    Physical address. . . . . . . . . . : 20-CF-30-18-B2-E0
    DHCP enabled. . . .. . . . . . : Yes
    Wireless LAN card Wireless connection:
    Description. . . . . . . . . . . . . . . : Atheros AR9285 Wireless Network Adapter
    Physical address. . . . . . . . . . : 74-F0-6D-94-AE-3C
    The IPv6 address of the local connection. : fe80 :: 9de2: af49: ba54: f33e% 11 (Preferred
    IPv4 address. . . . . . . . . . . . . : 192.168.1.101 (Preferred)
    Subnet mask. . . . . . . . . . : 255.255.255.0
    Lease obtained. . . . . . . . : 18 April 2017 14:00:47
    The lease expires. . . . . . . . . : 19 April 2017 14:00:47
    Deafult Gateway. . . . . . . . . . : fe80 :: 1% 11
    fe80 :: 62e3: 27ff: fe4b: bcf0 11%
    192.168.1.1
    DHCP server. . . . . . . . . . . 192.168.1.1
    DHCPv6 IAID. . . . : 192213101
    DHCPv6 client DUID: 00-01-00-01-1F-47-31-1C-20-CF-30-18-B2-
    DNS servers. . . . . . . . . . . 8.8.8.8
    8.8.4.4
    NetBIOS via Tcpip. . . . . . . : Activated
    The tunnel card isatap. {FA6DC141-F65F-408B-8CC6-A9347F5C2699}:
    Description. . . . . . . . . . . . . . . : Microsoft ISATAP card
    Physical address. . . . . . . . . . : 00-00-00-00-00-00-00-E0
    DHCP enabled. . . . . . . . . . : No
    Tunnel card Teredo Tunneling Pseudo-Interface:
    Description. . . . . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
  • #6 16419764
    bogiebog
    Help: 2569
    Rate: 1530
    You are connected to two different routers, a network diagram with devices.
