Mounting RGB LED Strip on Ceiling Edge: Glue, Silicone, Paint & Wallpaper Compatibility
dper15 6813 5
  • #1 16419765
    dper15
    Rate: 17
    I am looking for a good way to mount the LED strip on the edge of the ceiling. The tape must be mounted directly to the ceiling. You can recommend some glue or silicone. It will be mounted on paint and wallpaper.
  • #2 16419794
    retrofood
    Help: 1140
    Rate: 4800
    Drive to any electrical warehouse and choose the profile that suits you. That's all.
  • #3 16419887
    dper15
    Rate: 17
    Only it is to be mounted directly to the wall / ceiling. Without trays, angles etc.
  • #4 16419904
    marqqv
    Level 32  
    Help: 162
    Rate: 610
    Emulsion painted ceiling? You can use hot glue, if it is a good, clean, non-greasy substrate. The one that comes with a gun (if you didn't know it). I think it will last, or you can always stick the sticking out piece without disassembling the whole thing.
  • #5 16426689
    dper15
    Rate: 17
    I don't know because I haven't climbed there yet, but I suspect so.
    I decided to try to stick the tape with mounting glue, and I will let you know what the effect will be.
  • #6 16427353
    marqqv
    Level 32  
    Help: 162
    Rate: 610
    The mounting glue should also do the trick and you'll achieve the effect. There are still double-sided tapes too :D
