Creating LED-Lit Wall with Gypsum Stone: Attachment & Cornices for LED Strip Placement
WSRH 14829 7
  • #1 17299015
    WSRH
    Rate: 62
    Hello, gentlemen, I want to do something like this in a room:
    While the combination of LEDs and the placement of gypsum stone is not a problem, the problem for me is how to attach the led strip on top so that it shines nicely towards this wall.
    I found some cornices
    http://sklep.styroplast.pl/listwy-led-oswietlajace-sciane-ld-c-21_52.html
    but on average I like it, I would prefer a simple strip to which I would stick an LED strip, well, what is its name, where to look for it?
    Do you have any ideas or advice?
  • #2 17299039
    PPK
    Level 30  
    Help: 94
    Rate: 430
    In the photo there is a curtain rod-like. I use an asymmetrical Al angle (L - 50x20mm or 80x20mm), veneered from the outside with self-adhesive foil. Masks and cools the tape at the same time. I especially recommend the RGB tape with the driver, you can perfectly choose the color ..... :)
  • #3 17299065
    Jawi_P
    Level 36  
    Help: 260
    Rate: 717
    Search under the heading "LED aluminum profiles".
    To choose the color as they say. They are also systemic, with connectors, angles and diffusers. You will choose something.
  • #4 17299073
    boguslaw robak
    Help: 35
    Rate: 53
    Hello, look for a great snake = RGB, great effect on brick, best regards.
  • #5 17299121
    Zutket
    Level 36  
    Help: 270
    Rate: 1045
    There are suitable aluminum profiles for LED strips under 45 degrees. You need to place such a profile behind the cornice towards the wall. You will get such profiles in every warehouse that carries LED strips. And one more thing, When installing, you should think about the use of the regulator if the tape is to be along the entire length of the wall. Of course, warm white tape.
    A colored light hose in the living room to illuminate the wall? Congratulations on the idea, but you don't argue with tastes.
  • #6 17299215
    Jawi_P
    Level 36  
    Help: 260
    Rate: 717
    That's the whole truth. But I'd buy one that flashes to the beat of the music ;)
  • #8 17303605
    retrofood
    Help: 1140
    Rate: 4800
    WSRH wrote:
    a bad thing for me is how to attach an LED strip on top so that it shines nicely towards this wall.
    You will find a wide selection of aluminum profiles for mounting LEDs in every electrical warehouse.
The discussion revolves around creating an LED-lit wall using gypsum stone, focusing on the attachment methods for LED strips. Users suggest various solutions, including using asymmetrical aluminum angles for mounting, which can conceal the LED tape while providing a clean look. Recommendations include searching for "LED aluminum profiles" that can be installed at a 45-degree angle behind cornices to direct light effectively. The use of RGB LED strips is encouraged for aesthetic effects, and a Sonoff driver is mentioned for controlling the lighting. The author identifies specific products, including a cornice and an LED profile, to implement their design.
