Lenovo IdeaPad 100-15IBD: RAM Slots Inquiry - One or Two Slots, Win10 vs. Manual Info
kaszpirwski 21375 12
Does the Lenovo IdeaPad 100-15IBD have one RAM slot or two, and why does Windows 10 report two slots while the manual shows one?
This model has one physical RAM slot; Windows 10 can still report two because it reads chipset/SMBIOS data showing support for two memory modules, even if the manufacturer installed only one [#16421648][#16421854] Some variants of the same chassis were sold with 4 GB in the slot, 4 GB in the slot plus 2 GB soldered on the board, or 8 GB in the slot, but that does not mean there are two user-accessible slots [#17473308] In the thread, the 4 GB module was identified as installed in the only slot, with the other “slot” being just a detected-but-empty controller entry [#16421761][#16421742]
  • Lenovo IdeaPad 100-15IBD RAM slot count discrepancy
    #1 16420963
    kaszpirwski
    Hello, I have a question about this laptop, I mean the number of slots for ram memory in the manual is written with one slot and the win 10 system writes about 2 slots maybe someone had to deal with this laptop and can answer my question in advance thanks and best regards. This is my first post on elektroda.pl I apologize in advance for something wrong
    https://obrazki.elektroda.pl/4117394700_1492549340.jpg
  • #2 16421207
    DriverMSG
    Help: 3984
    Rate: 4893
    I do not know what is your motherboard model. in a laptop, but it is possible that it has a RAM memory + one slot for additional RAM.
  • #3 16421497
    kaszpirwski
    the frames are already soldered yet the moment and the laptops will be a one-time release of Lenovo ideapad 100-15IBD 80QQ this is exactly my laptop model I know that the market came out a few models in the same housing but differ spec my equipment is the one with two graphics cards I was looking for I watched online videos and saw only one slot only for which windows 10 sees 2 slots in memory of the frames
    There is a possibility that there is a free slot for the slot and for this wine 10 sees 2 because I personally know that I do not know anything
    I found something on eBay
    http://www.ebay.com/itm/Lenovo-IdeaPad-100-15...erboard-NMA681-5B20K40900-Tested/252855380962
    soldering probably only goes to the question why 10 wines see 2 slots
  • #4 16421648
    Kasek21
    Help: 4981
    Rate: 3549
    The laptop has one RAM memory slot.
    It reads data from the chipset of the disc.
    What does the CPU-Z show - the SPD tab for "each" slot?
  • #5 16421740
    kaszpirwski
    in the first there is no description
    If there is one slot for which the first slot is not a description, I am not a service technician but I think that if he had one slot, the description would be in the first slot and not in the second slot if I'm wrong, please correct me
  • #6 16421742
    Kasek21
    Help: 4981
    Rate: 3549
    I understand empty in Slot # 1?
  • #7 16421755
    kaszpirwski
    yes in the first lack of description
  • #8 16421761
    Kasek21
    Help: 4981
    Rate: 3549
    You have one slot and a 4GB memory module installed.
  • #9 16421777
    kaszpirwski
    ok, thank you for your help just for what I have a description in the CPU-Z that ram in the second slot and the first empty? In total, windows 10 also writes about 2 slots
  • #10 16421854
    Kasek21
    Help: 4981
    Rate: 3549
    Because this chipset would handle 2 memory modules but the manufacturer mounted one.
  • #11 17473308
    9452130
    A bit late but I see on various pages that a lot of people are looking for information on this topic. The laptop had 3 options on the frame.
    1. 4gb in an additional slot
    2. 4gb in an additional slot + 2gb soldered on the board (slot 1).
    3. 8gb in the additional slot
    So if someone wants to do an upgrade, then the bone is changed from 4 to 8.
  • #12 18980617
    noidemm
    Rate: 254
    Refresh the cutlet :-)
    Laptop as in the subject of lenovo 100-15IBD one memory slot. I took out the old 4 GB chip, put in the new 8 GB DDR3 1600Mhz CL11 goodram and it doesn't work. Bios updated. Any ideas. The laptop is spinning the fan, the disk is working, there is nothing on the matrix.
  • #13 18996757
    PanTrebuh
    You need to insert the low voltage module. Look for the designation PC3L or DDR3L (L - low voltage).
The Lenovo IdeaPad 100-15IBD is discussed regarding its RAM configuration, with conflicting information about the number of slots. The manual indicates one RAM slot, while Windows 10 detects two slots. Users clarify that the laptop typically has one slot for RAM, with some models potentially having soldered memory. The chipset supports two modules, but Lenovo often installs only one. Upgrading options include replacing the existing 4GB module with an 8GB DDR3L module, as low voltage memory is required for compatibility. Issues with BIOS and memory recognition are also noted.
