Upgrading Dell Latitude E6400 Laptop: Find Best Compatible Processor for Intel Core 2 Duo P8700
Narty123 5208 6
  • #1 16421500
    Narty123
    Hello. I have a Dell Latitude E6400 laptop with an Intel Core 2 Duo P8700 2.53 Ghz processor. I would like to replace the Prock in it, but I do not know what maximum I can afford when looking at the capabilities of the equipment. I found information that I can put i3 or i5 in, but after a more detailed analysis of the processor specifications, it turns out that they have a different type of socket. What is the best processor capable of entering my laptop? I'm counting on your help. greetings
  • #2 16421533
    nici
    Help: 266
    Rate: 979
    T9600, I have one in the same dell.
    Remember that this computer has poor cooling, clean it well and give it a decent paste or it will fry.
    No i3, i5 will come up
  • #3 16421553
    Narty123
    Thanks :) But I have one more question then. The T9600 has a Montevin core and my P8700 has a Penryn. There is no difference how I change to a processor with this core?
  • #4 16421560
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    What chipset? Like GM45 / PM45, this T9600 will work.
  • #5 16421561
    nici
    Help: 266
    Rate: 979
    You know what, just check if both processors have the same socket. My dell did not show such a processor after serial numbers, someone just replaced it with plug and play.
    There is probably one more powerful model but I couldn't find it anywhere, this T9600 is enough.
    You can't make a speed demon out of this laptop, but it's OK for a simple job
  • #6 16421610
    Narty123
    GM45 :)
  • #7 16421615
    nici
    Help: 266
    Rate: 979
    Go ahead and buy it, it will work if it is functional
✨ The discussion centers on upgrading a Dell Latitude E6400 laptop, specifically replacing the Intel Core 2 Duo P8700 processor. Users suggest the T9600 as a compatible upgrade, noting that it has a Montevina core, while the P8700 has a Penryn core. Concerns about the laptop's cooling capabilities are raised, emphasizing the need for proper maintenance and thermal paste application. The chipset in question is GM45, which supports the T9600. Users confirm that as long as the processor is functional and fits the socket, it should work without issues. However, they caution that significant performance improvements are not expected.
