HC-550M Camera Trap: MMS Sending Issue with Nju Mobile SIM and ERR_LOG File on SD Card
kejoss 22158 10
How can I make an HC-550M camera trap send MMS photos to my phone when it only creates an ERR_LOG file on the SD card?
Check that the APN is entered correctly in the camera for your SIM card, because incorrect operator settings are the first thing suggested in the thread [#16597894] One user reported having preset profiles for T-Mobile/Heyah, Plus, Play, and Orange, which suggests the MMS settings must match the network used by the card [#16660383] If MMS still fails, try updating the camera firmware: a newer HC-550G/HC-550M package (Ver.20180403) is mentioned [#18619044] The update procedure is to copy FWR801.bin to a blank TF card, insert it, switch the camera from OFF to TEST, wait about 15 seconds for the red LED to flash, then remove the file from the card and restart the camera [#18619044]
  • Nju Mobile SIM may be incompatible with MMS settings
    #1 16597498
    kejoss
    Rate: 9
    I have a problem with the camera trap that does not send mms. I configured according to the instructions (at least it seems to me) but I still do not want to send these photos to the phone, only the ERR_LOG file appears on the sd card I will add that the sim card in the camera I use Nju Mobile.
    I will be very grateful for your advice. Thank you in advance. Regards Jarek
  • #2 16597894
    michualex
    Help: 82
    Rate: 134
    APN in the trap you have typed?
    MK ALARMY
    Widziszewo, Długa 3, Kościan, 64-000 | Tel.: 663XXXXXX (Show) | Company Website: www.mkalarmy.pl
  • #3 16598184
    kejoss
    Rate: 9
    Yes, I have options:
    • HC-550M Camera Trap: MMS Sending Issue with Nju Mobile SIM and ERR_LOG File on SD Card Scren mms.png (185.27 KB) You must be logged in to download this attachment.
  • #4 16658669
    TELE112
    Rate: 32
    Did you solve the problem with sending mms from the hc550m photofauge, I send it once and once I do not, I have no idea. SMSY It does not have a problem.
  • #5 16658939
    kejoss
    Rate: 9
    Unfortunately not. Mi does not send SMS or mms. Can you write how you configured it? and in which network you have a sim card Thank you in advance for help. Pozdraiwm
  • MMS works intermittently with Play SIM and low battery
    #7 16660383
    TELE112
    Rate: 32
    I have settings for tmobile / heyah, plus, play, orange. Sam, I have a card in the play and mms once come once and not ok, I have a 6v battery connected to the camera (the batteries have pumped out the moment), the friend has a hc300m tmobile and laughs nicely on the batteries. I still have to try another tmobail and the Play subscription card. Setting the time of taking pictures does not work at all, it takes pictures as it wants and sends mms and e-mail.
  • #8 16665975
    TELE112
    Rate: 32
    Does anyone know where you can download the new software for the HC-550M camera,
    I downloaded the HC-550G to the 15 button remote control and installed it, unfortunately it does not send mms, the color change in the pictures is more pink, I can not operate the 7 button remote control, it does not respond to the commands sms outside * 520 * command. I wrote to the producer that he gave where he can download the software, on their throne is only corrected to the HC-300M.
  • #9 18619044
    gradek83
    Help: 930
    Rate: 2103
    TELE112 wrote:
    Czy ktoś wie gdzie można pobrać nowe oprogramowanie do kamery HC-550M
    Źródło
    Spoiler:
    HC-550M & HC-550G Old Version Firmware( SN number before 2017.5 )
    HC-550G & HC-550M Firmware Ver.20180403
    There are 3 steps to proceed system upgrade:
    Step 1: unzip and copy the FWR801.bin to a new TF card and insert this TF card into your camera.
    Step 2: switch from OFF to TEST, there is red LED keep flashing about 15 seconds, then camera screen will light up.
    Step 3: delete the FWR801.bin from TF card(format sd card or connect to PC via usb cable to delete), then switch TEST to OFF and restart camera.
    • HC-550GHC-550M Ver.20180403 (1).rar (1.25 MB) You must be logged in to download this attachment.
    • HC-550G old version firmware (1).rar (1.23 MB) You must be logged in to download this attachment.
  • #10 19524742
    dziekan_tek
    Rate: 47
    If someone needs it, I throw in the packed contents of the mini CD that comes with the HC-550M forest camera. The unpacked image is in .NRG (Nero) format
    • Trail Camera (HC-550M).7z (36.13 MB) You must be logged in to download this attachment.
  • #11 21252624
    vucaklov
    HC-550M Camera ERR_LOG File on SD Card
The discussion revolves around issues with the HC-550M camera trap, specifically its failure to send MMS despite proper configuration. The user, Jarek, reports that only an ERR_LOG file appears on the SD card when attempting to send photos using a Nju Mobile SIM card. Other users inquire about the APN settings and share their experiences with similar problems, noting inconsistent MMS functionality across different networks. Some users mention the need for updated software for the HC-550M and provide links to related discussions and resources. The conversation highlights the challenges of configuring camera traps for reliable MMS transmission and the importance of compatible network settings.
