First TIG HF Welder for Novice Up to PLN 1,000: Fantasy Model Halo II & Powermat PM-TIG-220G
wdowski 8724 16
Can I buy a decent TIG welder for a beginner amateur up to PLN 1,000, or is another type of welder a better choice?
A decent TIG welder for a beginner at up to PLN 1,000 is not a good idea; a cheap MIG/MAG will be easier to use, more universal, and better for learning than a poor TIG HF [#16440962][#16440074] If you want TIG specifically, it is better to wait and save for a proper AC machine, even a Magnum or similar Chinese model [#16440256] One reply also notes that if you have limited space and only a basic 230V supply, you may end up with only small MMA welders up to 100A [#16456125]
  • #1 16423795
    wdowski
    Rate: 14
    Hey. I have slightly increased my budget since my last post. I would like to ask if you can get a decent TIG welder for a novice amateur up to PLN 1000? I know that I will still have to add PLN 500 for the cylinder and regulator, but I am aware of it. I want to have TIG and now MMA will have to be enough. I will buy what I need in 2 months.
    Could I ask my colleagues for help and assessment?
    Thanks.
    That's what's in the budget.
    -WELDER FANTASY MODEL HALO II TIG / MMA 180A
    Additional HOT START, ARC FORCE, ANTI STICK functions
    Nominal voltage: 230V ~ 50Hz
    Phase: 1
    MMA work cycle: 180A - 60%
    TIG DC duty cycle: 180A - 60%
    Security: 16A
    Power tolerance: 10%
    No-load output voltage: 64V
    Insulation class: B
    Weight: 7.75kg
    Degree of protection: IP21
    Dimensions: 385 x 160 x 270 mm
    -Powermat PM-TIG-220G
    No-load voltage 60V
    7.3kVA input power
    TIG DC / MMA welding method (electrode)
    Ignition method TIG - HF (non-contact ignition)
    Welding current range 10 - 220A
    Operating voltage range 10.4-18.8V
    Welding current duty cycle 100% 170A
    Welding current duty cycle 60% 220A
    60% rated duty cycle
    Supported TIG electrode diameters up to 3.0mm
    Supported MMA electrode diameters 1.6-3.2mm
    Insulation class F
    Degree of protection IP21S
    The weight of the device 7.9 kg
    -TOPTIG 205 PULS DC (Magnum, it looks the same)
    Inverter welder designed for TIG welding
    (WITH IONIZER), TIG + PULS, and MMA coated electrode.
    Device power 5.6 kVA
    IP21 class
    TIG welding current: 200A DC
    MMA welding current: 200A DC
    200A / 60% duty cycle
    Cooling fan
    Weight: 8.5 kg
    -Pirotec SIT 251/1
    HOT START, ARC FORCE and ANTI STICK and HF high frequency generator
    Voltage (V) 230
    Maximum welding current (A) 200
    Welding current adjustment range (A) 10-200
    Duty cycle 20% 200 A / 60% 100 A
    Electrode / wire diameters (mm) MMA: 0.8-5 TIG: 0.5-2.4
  • #2 16428091
    bearq
    Help: 414
    Rate: 1612
    You can't, why do you need TIG in such a poor version? Isn't it better to buy MIG / MAG?
  • #3 16428634
    wdowski
    Rate: 14
    And will Mig in the PLN 1,000 version be much better?
    Can you budge your comment a little bit? Give the MIG example you are talking about?
    It seems to me that the answer "no, because not" is none.
    I will add from myself that I need this welder to learn welding and then hobby welding a ring. I won't earn it. Size also matters because I don't have a garage or plot.
    Thanks.
  • #4 16429327
    bearq
    Help: 414
    Rate: 1612
    It won't be better, but MIG / MAG is easy to use and very versatile, you will easily learn how to weld on it what you can't say about TIG.
  • #5 16431541
    wdowski
    Rate: 14
    In cheap MIGs, I can see that the electrode cable comes out of the housing - without the Euro connector, it only limits me to the MIG.
  • #6 16438429
    ELSPAW_
    Rate: 9
    What is cheap - it's expensive. Can we afford it?
  • #7 16440056
    wdowski
    Rate: 14
    And can we go back to the beginning and look at the subject with the eyes of an ordinary DIY hobbyist? Does every hobbyist have to have equipment for 4-5 thousand PLN to weld a pair of angles - rather not.
    I know this saying that the thrifty pays twice but I just can't afford anything more expensive.
  • #8 16440074
    bearq
    Help: 414
    Rate: 1612
    We can, why a DIY TIG hobbyist? If you buy a TIG for welding angles, you will cry. I already wrote to you, buy MIG / MAG and enjoy welding and you do not bother with TIG which is not suitable for everyday use by DIY. Even more so for PLN 1,000.
  • #9 16440256
    kortyleski
    Help: 957
    Rate: 3860
    As soon as tig / MMA, wait and collect cash by buying AC. Even a magnum or related Chinese. Very good equipment for amateur. You weld aluminum, alloys.
  • #10 16440962
    ELSPAW_
    Rate: 9
    Thanks.
    A PLN 1000 MIG will be better than a poor TIG HF.
    Easier to use and more universal, especially for "beginner amateur".
  • #11 16441493
    wdowski
    Rate: 14
    I understand that in order to weld with an electrode I have to change polarization? How do I do it since the cable to the gun is permanently in MIGs for 1000. I did not see another one but I can be wrong.
    And so when buying mma / tig, if the gas comes out or something else happens, I will do it anyway.
  • #12 16456021
    wdowski
    Rate: 14
    Nobody has any other ideas / suggestions? Do only 3 people have an idea in the subject?
  • #13 16456125
    Sniezynka
    Help: 199
    Rate: 841
    If you want to learn how to weld at the beginning, I suggest such a welder: http://www.sabtech.pl/spawalnictwo/spawarki-i...ig-mag-mma/spawarka-mig-mag-190-ii-mma-detail.
    But I'm afraid that if you don't have space for welding and the right 230V and 25A power supply protection in the socket, only small MMA welding devices will remain, up to 100A.
  • #14 16456352
    wdowski
    Rate: 14
    The welder from the link really looks nice though heavy damn - up to 25kg
    Without a dedicated place with the flow can be a problem, although I found a thread here on the forum link and someone is writing that MIG welding with 16B protection at maximum settings and worked. Maybe it's a lottery.
    I need to see what's in my fuse box.
    The second thing, every page is a different photo of the welder and a different description. How is it possible that the MIG 190 II MMA Digital weighs 9kg?
  • #15 16456749
    bearq
    Help: 414
    Rate: 1612
    Possible, tin cans, no welding frame, probably a 5kg spool and a fist-sized heat sink with a capacity of 200A ...
  • #16 16458740
    Sniezynka
    Help: 199
    Rate: 841
    Because there are fakes even of Chinese, Secondly, the welder must weigh light and good, unfortunately Esab or Kemppi, and it costs.
    As for installation, it is important not only to protect, but also to thickness 2.5mm2 and length. Of course, you don't have to immediately weld with 3.25mm electrodes to learn, just buy 2.0mm then and the power consumed by the welder will be lower.
  • #17 16672904
    wdowski
    Rate: 14
    Thanks gentlemen for the advice. I'm going semi-automatic. Money almost collected
The discussion revolves around selecting a TIG welder for novice users with a budget of PLN 1,000. The two models considered are the Fantasy Model Halo II and Powermat PM-TIG-220G. Participants express skepticism about the practicality of TIG welding for beginners, suggesting that MIG/MAG welders may be more user-friendly and versatile for hobbyists. Concerns are raised about the limitations of budget TIG welders, including their performance and suitability for basic welding tasks. Some users recommend saving for a more capable MIG welder, while others discuss the importance of having adequate power supply and installation considerations for effective welding. The conversation highlights the need for a balance between budget constraints and the functionality required for amateur welding projects.
