The laptop can not see my wi-fi network and the others like this (HP Pavilion G6
Dawid3901 56511 7
  • #1 16424119
    Dawid3901
    Today when working with my laptop I lost connection with wi-fi, I tried to reset the router and turn off and turn on the network card - it did not bring any effects: / laptop sees all other wi-fi networks except the one with which I have always been connected. I would ask for the simplest explanation because I am "green" in these matters: /
  • #2 16424192
    leonov
    Help: 1039
    Rate: 2247
    What are your router settings? What kind of equipment is it?
  • #3 16424204
    Dawid3901
    TP-Link TD-W8961ND router which settings do you mean? if o and p then 192.168.1.1
  • #4 16424226
    Przemek2011
    Help: 15
    Rate: 81
    What kind of windows system do you have?
  • #5 16424232
    Dawid3901
    I have windows 10
    (the computer was last formatted and windows were reinstalled)
    antek1cza
    Help: 182
    Rate: 199
    This means that SSDI and key are default.
    Dawid3901 wrote:
    turning off and turning on the network card
    WiFi in a laptop?
    Dawid3901 wrote:
    the laptop can see all other wi-fi networks besides the specific one
    and the default SSDI of this router can see?
    I suggest :
    1. Log on to the router by cable.
    2. Check what SSDI and KEY are currently. How are the defaults to change to what it was like.
    3. Reconnect after wifi and work some time on the computer.
    4. How it starts to disconnect is not to reset the router just log on to it on the LAN cable and check the current settings.
    Przemek2011
    Help: 15
    Rate: 81
    This is a common problem in this system.
    1. Click on the Start menu button and select Control Panel.
    2. Select "Network and sharing center".
    3. On the page that opens, Select "Manage wireless networks".
    All profiles of known wireless networks are listed on the page. Click on your saved network and choose forget. After that, try to search your network again. After such an operation, the network password must be entered again.
    At the moment I do not have access to a computer with a wifi card, but the order I gave above should be good.
  • #8 16424266
    Dawid3901
    I still do not find this network for me: /
    Added after 9 [minutes]:
    No, he can not see
    Added after 8 [minutes]:
    Problem solved, thanks :)
The user experienced an issue with their HP Pavilion G6 laptop, which could not detect their specific Wi-Fi network despite being able to see others. After attempting to reset the router and toggle the network card without success, they sought assistance. Responses included checking router settings, specifically the SSID and key, and suggested logging into the router via a LAN cable to verify configurations. Additionally, users recommended managing wireless networks in Windows 10 by forgetting the problematic network and re-entering the password. Ultimately, the user resolved the issue, indicating that the network was found again.
