Unable to Insert Plug into Socket with Track Diaphragms - DIY Repair or Electrician Needed?
autokomputer 65892 9
Can I fix a socket with a stuck safety shutter/diaphragm myself, or do I need to call an electrician?
You may be able to fix it yourself if the problem is only the shutter/child-safety lock, but if the socket mechanism is damaged the outlet should be replaced and you may want an electrician. Gently turn the plug a little left and right while inserting it; do not force it [#16425600] If the safety lock is on the cover/bezel, it can be removed after unscrewing the socket from the mechanism [#16425098] One reply also notes that the outlet will need replacement, so whether it is DIY depends on whether you feel strong enough to replace it yourself [#16424957]
  • #1 16424946
    autokomputer
    Level 19  
    Rate: 45
    I have sockets with track diaphragms (this is probably what it's called). I can not plug in a single socket, because this screen has blocked. Can a person not familiar with electricity, like me, somehow fix it or should I call an electrician?
  • #2 16424957
    kosmos99
    Help: 338
    Rate: 820
    The outlet will be replaced, so it depends on whether you feel strong enough to replace them.
  • #3 16424991
    autokomputer
    Level 19  
    Rate: 45
    I thought that if I turn it on, I will be able to take out this blockage (because I do not have children, it is unnecessary) and mount again, but if I want to replace the whole socket, I will have to call an electrician.
  • Socket safety shutter can be removed from the cover
    #4 16425098
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3543
    Of course, you can remove this lock on the cover / bezel of the socket, after unscrewing it from the mechanism.
    The only question is why and for what reason there is such and no other nest (?)
  • Failed socket safety shutter and possible removal workaround
    #5 16425174
    autokomputer
    Level 19  
    Rate: 45
    The developer probably intended to protect children, but I do not have children, and you could plug in the plug a week ago, the blockade had to break down.
  • #6 16425600
    zbich70
    Help: 1171
    Rate: 6673
    Try turning the plug lightly to the right and left when inserting the plug.
    Gently, do not force it.
  • #7 16430262
  • #8 16430465
    mychaj
    Help: 214
    Rate: 943
    plug it in and not a different plug. :D
    Some crap - what's the blockade to the type of plug?
  • #9 16430602
  • #10 16431647
    mychaj
    Help: 214
    Rate: 943
    I did not understand the first time - Sunday :-)
The discussion revolves around a user experiencing difficulty inserting a plug into a socket equipped with track diaphragms, which are likely designed for child safety. The user contemplates whether they can resolve the issue themselves or if they should hire an electrician. Responses suggest that the blockage can potentially be removed by unscrewing the socket cover, but caution is advised. Some participants recommend gently turning the plug while inserting it, while others express frustration over the necessity of such safety features. The conversation also touches on the reliability of different socket brands, with mentions of Legrand and cheaper alternatives, indicating that the latter have not failed over years of use.
