Triple Earthed Socket Installation: Step-by-Step Guide & Troubleshooting Tips (Polish/English)
9303 5
  • #1 16656211
  • #2 16656216
    karolark
    Help: 702
    Rate: 2519
    Problem with electrical or mechanical assembly :D
  • #3 16656218
  • #4 16656229
    mawerix123
    Help: 482
    Rate: 951
    A socket like a socket has three terminals, it is important to connect the protective one to the terminal intended for this purpose and the other two do not matter under which terminals you will mount.
    Show picture of this slot with the grill removed.
  • #5 16656233
    karolark
    Help: 702
    Rate: 2519
    As above - how many wired installations do you have?
  • #6 16656636
    Turysta_
    Help: 7
    Rate: 19
    You unscrew this screw inside. And you have access to the body, fasten the wires, tighten the screws holding the wires. Then mount the body in the can, snap it with teeth and screw the housing.
