Lupo 3L Gearbox Adaptation - IGN OFF Issue: Understanding & Solving the Error Message
pawfil1 7734 5
  • #1 16429276
    pawfil1
    Rate: 29
    I bought a 3l Lupo a few days ago (this is my second 3l lupo) with damage as in the subject (box). I adjusted the clutch cable (1.93V) and then started to adapt the gearbox. Unfortunately, when I select block 014 and it appears in the first window, I see "IGN.OFF!" and here's a question for you what it is
    may mean?
    As the first idea - turn off the ignition, but it does nothing
  • #2 16429383
    michu14031
    Help: 12
    Rate: 38
    I suspect no communication, and it detects the ignition is off
  • #3 16429419
    pawfil1
    Rate: 29
    And what could this lack of communication be? Physically cutting the cable?
  • #4 16429613
    michu14031
    Help: 12
    Rate: 38
    first check the harness if there is a broken wire somewhere, the best would be to describe the driver pins.
    Check in blocks, e.g. of the counter, whether it recognizes the position of the ignition switch
  • #5 16429680
    pawfil1
    Rate: 29
    tomorrow I will try to look at the bundle and try again.
  • #6 16432715
    pawfil1
    Rate: 29
    I already know what I was doing wrong. Wanting to start adapting, I entered Meas. Blocks and there I entered the group number (014) and it was a mistake, I should click Basic Settings and look for group 014 there.
    Subject to be closed.
