Connecting LED Lights to Giraffe-Type Grinder: Voltage Requirements and Wiring Guide
Oba 121 12414 6
  • #1 16429879
    Oba 121
    I would like to connect the led to a giraffe-type grinder. I don't have any knowledge about it, but I connected the cable behind the speed controller. Now at the output at low speed I have only 10 -7v. From what I know, it takes 12v for a transformer to make LEDs shine. strong light (I think).
    Please help what to use and where to connect so that the LEDs shine.
    Thanks in advance
  • #2 16429893
    kokapetyl
    Help: 1787
    Rate: 2101
    You think that such LED lighting is enough to illuminate, for example, walls when applying finishing coats.
    Have you seen it with anyone yet? Is this your idea?
  • #3 16429908
    Oba 121
    I saw a movie on the tube thinking I was doing a job. But I also use 3 LED leflectors for lighting during grinding.
  • #4 16429937
    kokapetyl
    Help: 1787
    Rate: 2101
    I think I misunderstood you, I thought you wanted to attach these leds to the giraffe's "head" and you only want to get power from it. I think right now?
    But why such complications, since you have access to normal mains power anyway.
    The right power supply and the right number of these headlights.
  • #5 16429946
    Oba 121
    I want to mount it on the head.
    The led light on the head close to the wall will spill out any unevenness
    Walking with a leflector and a giraffe plus a vacuum cleaner is not comfortable
  • #6 16429983
    kokapetyl
    Help: 1787
    Rate: 2101
    If you say so, you probably are right, although in my humble opinion, strong side lighting gives the right results.
    We return to the topic of the topic.
    The power supply for these leds must be from a permanent source. I suggest a typical LED power supply of appropriate power for the LEDs used. Power supply next to the vacuum cleaner and cable for LEDs along the giraffe extension arm.
  • #7 16429993
    Oba 121
    This is a good but troublesome solution with a cable on top.
    I connected the cable to the head at the engine but I have a small voltage transfornators I intend to mount on the head of the spectators this solution in the video
    My problem is a small tension 7-10 before the hit
The discussion revolves around connecting LED lights to a giraffe-type grinder, focusing on voltage requirements and wiring solutions. The original poster has connected a cable behind the speed controller but is only receiving 7-10 volts at low speed, which is insufficient for standard 12V LED operation. Suggestions include using a dedicated LED power supply for consistent voltage, as well as the possibility of mounting the LEDs on the grinder's head for better illumination during grinding tasks. Concerns about cable management and voltage drop are also addressed, with recommendations for a more permanent power source rather than relying on the grinder's output.
