The battery discharges itself after disconnection - voltage 10V
DjAlcon 39300 32
Why does my car battery voltage drop to around 10 V and discharge after the car is parked, even when the battery is disconnected from the car?
Your battery is likely weakened and you also have a parasitic drain in the car, so you need to test both. A battery that was charged only to 13.11 V after 3 hours is not fully charged; it should be charged to about 14.4–14.5 V first [#16433924][#16432024] Then disconnect it from the car and leave it for 2 days: if it cannot hold around 12.5–12.9 V or fails to start the engine, the battery should be replaced [#16431872][#16433924][#16447391] If it does hold voltage off-car, look for the leak in the car’s installation by measuring current in series and pulling fuses; about 95 mA at rest was measured, and a healthy car should be much lower than a drain that quickly kills a weak battery [#16433872][#16431872] A voltage drop to around 12.3 V after a few days already indicates a nearly empty battery and high internal resistance [#16447391]
  • #1 16431790
    DjAlcon
    Rate: 38
    I have a problem with the battery, unfortunately my knowledge ends with measuring the voltage.
    I don't know why, but for some time it has been happening that the car has been parked for 2 days and the battery is completely discharged. A few moments ago, it could stand for 1.5-2 weeks without any problems. and it fired up with no problems.
    I checked its voltage and the meter showed 10.50 V
    I connected it to the rectifier, charging it for about 3 hours, the meter indicates 13.11 V
    After turning off the rectifier and leaving the battery loose (unplugged from the car) after about 3-4 hours, it performs a measurement, the meter shows 12.70 V
    My battery is less than 2 years old.
    Its parameters:
    55Ah - 615 - 12V - 470A (EN) - Jenox Classic.
    Regards :)
  • #2 16431872
    wzielonymgaju18
    Help: 32
    Rate: 110
    The voltage on the battery should be around 12.50V -12.90V and should stay in this range. should not be allowed to discharge below 11V as this will damage the battery. It is normal for the battery voltage to rise immediately after charging.
    If the bulk battery will hold the current at the level of 12.50V - 12.90V, it should be functional when it drops, it means that the battery does not hold the current and needs to be replaced.
    If the battery is OK, then you should look for the reason why the car is charging at a standstill. current. The maximum current consumption in a functional car at a standstill should not exceed about 300mA. Connect an ammeter in series between the clamp and the battery, pull out the fuses and check what current is drawing.
  • #3 16431890
    ociz
    Help: 1378
    Rate: 3475
    The battery is damaged, there is no point in messing with it anymore.
  • #4 16431903
    wzielonymgaju18
    Help: 32
    Rate: 110
    Where does the presumption that it's damaged come from? if it can be charged and holds the voltage around 12.70V, it should be operational.
  • #5 16431916
    Junior188
    Help: 6
    Rate: 22
    True, you need to look for power failures in the installation at a standstill. The author describes it a bit wrong, I also thought, after a cursory reading, that it does not hold electricity, but when it loads, it turns out that it is only connected to the installation.
    Since my friend is green, please educate: https://www.youtube.com/watch?v=obsE2VnV7rs
    In this way, you can only check whether our theory is correct for what and now it gives 90%, then you have to look for what has shorted, broken, etc. but the ability to only measure V does not really see it ;)
  • #6 16431956
    ociz
    Help: 1378
    Rate: 3475
    That's because it was loaded. Discharged to zero and practically fully charged in just 3 hours, it is not possible with a functional battery.
  • #7 16431989
    Strumien swiadomosci swia
    Help: 1404
    Rate: 6402
    ociz wrote:
    Discharged to zero and fully charged in just 3 hours
    You know 13.11 is about 30% later it hangs for a long time at about 13.8 13.9 V and a jump at the end above 14V.
    Also, the author has a long way to go until the end of loading.
    However, the car has a damaged installation and unloads.
  • #8 16432001
    DjAlcon
    Rate: 38
    To be clear, the battery is charged outside the car (I will only be reviewing to find out what is the reason for the consumption of electricity in the car). The charger was set to a charging level of 10A according to the table on the charger (maybe the charging time was longer). Now I will leave the battery alone overnight and in the morning I will measure what is going on and what voltage the meter will show.
  • #9 16432024
    Help: 1404
    Rate: 6402
    The battery must be charged to 14.5V before it is fully charged.
  • #10 16433872
    DjAlcon
    Rate: 38
    Today I measured the current in the system and the meter showed 0.10~0.09[A] i.e. averaging approx 95[mA] defenitely too much. I'll have to check over the weekend to see what could be causing it.
    In sum: 0.1[A]*12V = 1.2[W]
    converting it to the battery, how much can the car stand at rest so as not to go below the voltage 11[V] in the battery.
    Parameters: 55Ah - 615 - 12V - 470A (EN) - Jenox Classic.
  • #11 16433901
    vodiczka
    Help: 1185
    Rate: 4301
    DjAlcon wrote:
    that is, averaging about 95 [mA], definitely too much
    Let's say twice as much but this is not a consumption that will kill the battery in 2-3 days.
    With a leakage rate of 100mA, you lose 2400mA per day, or 2.4Ah of capacity.
    If the battery actually only had 50% of its rated capacity, how long would it last? :)
    DjAlcon wrote:
    I connected it to the rectifier, charging it for about 3 hours, the meter shows 13.11V.
    Does it indicate with the charger connected or immediately after disconnecting the charger?
  • #12 16433924
    Xantix
    Help: 686
    Rate: 1656
    DjAlcon wrote:
    converting it to the battery, how much can the car stand at rest so as not to go below the voltage of 11 [V] in the battery.
    About two weeks with this current.
    In your place, I would fully charge the battery (i.e. to 14.4 V) and then put it outside the car for 2 days and after these two days measure the voltage and try to start the car on this battery. If the engine does not start, the battery must be disposed of. If it works normally - then look for causes in the car's installation. By the way, what car is it? Maybe you have some receiver in it that turns on cyclically and draws a lot of current by killing the battery?
  • #13 16433993
    vodiczka
    Help: 1185
    Rate: 4301
    I wanted him to count himself :)
    Xantix wrote:
    If I were you, I would fully charge the battery (i.e. to 14.4 V) and then put it outside the car for 2 days and after these two days measure the voltage and try to start the car on this battery.
    I already posted my measurements somewhere but I will repeat faster than I can find the link.
    1. New battery, 2. Six-year-old battery, both operational, both Centra Futura 64Ah. Initially charged with a current of approx. 5A and in the final phase (above 14.4V) with a current of 0.4A to a voltage above 14.7V.
    voltage measurement after 12h: 1. = 13.09V --- 2. = 12.54V
    voltage measurement after 96h: 1. = 12.96V --- 2. = 12.54V
    actual capacity: 1.>60Ah --- 2.>30Ah (6A discharge current)
  • #14 16434023
    Xantix
    Help: 686
    Rate: 1656
    I know, a friend once boasted that he had a 6-year-old Centra and that he replaced it even though it was relatively functional due to the fear of "sudden death" of the battery at the least appropriate moment (remember correctly? :) ). But what does this have to do with the author's battery?
  • #15 16434024
    DjAlcon
    Rate: 38
    Immediately after disconnecting the rectifier, it showed 13.11 [V], I left the battery alone overnight and in the morning the measurement came out 12.70 [V].
    After 3 hours of charging, it turned out (too short), despite the indication of 12.70 [V] in the morning, that the car started and went out immediately, it had to be pressed down on the accelerator pedal for a while to recharge.
    In that case, what indicator will tell me that I have it well charged?? [V] no, maybe [A]??
    Xantix wrote:
    If I were you, I would fully charge the battery (i.e. to 14.4 V) and then put it outside the car for 2 days and after these two days measure the voltage and try to start the car on this battery. If the engine does not start, the battery must be disposed of. If it works normally - then look for causes in the car's installation. By the way, what car is it? Maybe you have some receiver in it that turns on cyclically and draws a lot of current by killing the battery?
    I'll do that on the weekend, unplug the battery, charge it to 14.40 [V] and leave it at home.
    The car is a used Lanosik :) (I need to find instructions with the electrical system, fuse layout) I have several types that can take current - e.g. radio, maybe a lamp, gas, probably not the evaporator controller, probably not working?.
  • #16 16434038
    Xantix
    Help: 686
    Rate: 1656
    DjAlcon wrote:
    gas probably not the evaporator controller is not working?.
    The gas installation seems to take something there, but these are not large values, the more that since it is a well-worn Lanos, you probably have an underdeveloped 1st or 2nd generation installation there.
    DjAlcon wrote:
    maybe a lamp
    The light in the trunk comes to mind. I had such a case that the light was on all the time despite the closed trunk lid - this caused the battery to discharge after a longer stop.
  • #17 16434126
    leotdipl
    Help: 51
    Rate: 153
    hello, it seems that the battery has "went down" with the capacity (Ah).
    The active mass flowed largely for good from the grids.
    The fact that after charging it holds you a voltage of 12.7V does not mean anything
    in terms of energy expenditure.
    A short-circuit test should answer the question of whether to buy a new one.
  • #18 16434151
    DjAlcon
    Rate: 38
    I have to check, but sometimes I took off the rear part of the trunk and nothing seemed to me that with the lights closed.
    Yes Lanos from 2002 - no power steering :-) control unit, gas and starter plus lights, radio and speakers.
    In the front door, one loudspeaker does not work, I unplugged it (maybe someday I will find a moment to install a new one) in the other, something plays poorly, on the "trunk cover" there are 2 loudspeakers mounted as I bought it, the owner installed it himself.
    A strange affliction is when the rear window heating is turned on, the radio (not the original one) starts to lose range (since I have a car - RMF and Radio Maryja work, the rest do not).
    This is not a car packed with electronics, so let's say here I can bury myself without fear that I will break something :-) .
    leotdipl wrote:
    The fact that after charging it maintains a voltage of 12.7V does not mean anything from the point of view of energy expenditure.
    You can expand your thought, if the devices in the car take 100[mA], then such an expense in such a battery loses 2.3 times faster (200[mA], 300[mA])
    I understand such a thing only in a specialized shop / workshop.
    Active mass - that is, the battery is discharged to such an extent that it cannot be charged.
  • #19 16434177
    Xantix
    Help: 686
    Rate: 1656
    DjAlcon wrote:
    A strange ailment is when the rear window heating is turned on, the radio (not the original one) starts to lose range (since I have a car).
    Do you have an external radio antenna? Because in some cars, the resistance paths of the rear window heating were the receiving antenna of the radio. Perhaps for this reason, when you turn on the heating, you have a problem with the radio losing stations.
    Yes it's true. More electric than electronic...
  • #20 16434516
    Help: 1404
    Rate: 6402
    Yes, but it is enough that the radio is connected without a key and you have a problem.
  • #21 16434553
    Xantix
    Help: 686
    Rate: 1656
    I guess it depends on what radio. I had it hooked up in the Opel without a plus after ignition and nothing bad happened. Fact, it was some old VW Gamma, but even when I left it on, it turned itself off after an hour...
  • #22 16435089
    vodiczka
    Help: 1185
    Rate: 4301
    When a friend suggested:
    Xantix wrote:
    and then he put it outside the car for 2 days and after these two days he measured the voltage
    the author of the topic can compare the results :) In my opinion, a faster voltage drop to 12.5V may mean a higher battery self-discharge current.
    If possible, discharge it with a current of 6-10A to a voltage of 10.8V measured under load and determine its actual capacity.
    You can make a simplified assessment by measuring the voltage on the clamps at the time of starting. If it drops below 10V, it's not good, and below 9V the battery needs to be replaced.
  • #23 16447384
    DjAlcon
    Rate: 38
    So that's how the battery stood for 3 days in the car.
    I made a measurement:
    - At a standstill 12.30V.
    - After activating the controls etc.: 11.60V.
    - When starting the car for less than 1s: 10.60V.
  • #24 16447391
    Xantix
    Help: 686
    Rate: 1656
    12.3 V is almost an empty battery (about 1/3 of the charge left).
    This indicates a high internal resistance of the battery.
    In general, it seems that the battery is barely alive and is likely to "death".
  • #25 16447428
    vodiczka
    Help: 1185
    Rate: 4301
    I doubt it, rather between 35% and 50% Almost empty is 12.0V.
    This would show that it is closer to 35% and not 50%
    Pretty good here.
  • #26 16447444
    Xantix
    Help: 686
    Rate: 1656
    vodiczka wrote:
    I dare doubt
    And I can't. Because I read it
    and this
    which led to the conclusion
    Which my colleague later indirectly confirmed.
    1/3 is otherwise 33% (up to 35%, therefore only 2 pp). Are we going to argue about a few percent?
  • #27 16447468
    Ricoh_220
    Help: 464
    Rate: 752
    I was looking for problems myself, I measured it and it was ok when I got an Opel for 2 days, 30 minutes of charging and then ok. I solved the problem by replacing the battery and do the same if you have the opportunity to borrow a battery from a friend for a few days and it will solve your doubts.
    Hello, this method is probably the most effective.
    P.S
    Often there are people who do not use the car every day and seek help from them.
    Zakład techniki biurowej"Kserograf" .Serwis kserokopiarek i urzdzeń marki ricoh
    Bronowicka 73, Kraków, 30-091 | Tel.: 603XXXXXX (Show) | Company Website: https://kserograf.e.pl
  • #28 16447560
    DjAlcon
    Rate: 38
    The car stood for about 60 hours as I measured - 12.30V (+ 100mA consumption at a standstill).
    I have about 14km to work so I think that this distance will recharge enough to allow me to return ;-) .
    Ok then, I'll drive it for a while and probably replace it in 2-3 months if it still works (2-year battery).
  • #29 16447622
    Ricoh_220
    Help: 464
    Rate: 752
    The only thing that surprises me is that it's a young battery.
    The symptoms are identical to what I had.
    Then it fell overnight short circuit on the cells after connecting the external one, it was not able to spin when I disconnected it and gave the external one perfectly.
  • #30 16447667
    Wlodek22
    Help: 78
    Rate: 524
    Let it better embrace these 100mA of leakage current
    This and the current battery will last another 2 years.
✨ The discussion revolves around a car battery issue where the battery discharges rapidly after disconnection, showing a voltage of 10V after two days of inactivity. The user has a Jenox Classic battery (55Ah, 615, 12V, 470A EN) that is less than two years old. Responses suggest that the battery may not be holding a charge properly, with recommendations to check for parasitic current draws in the vehicle's electrical system, which should not exceed 300mA at rest. Some participants argue that the battery might still be functional if it holds a voltage of around 12.70V after charging, while others suggest it may be damaged due to rapid voltage drop under load. The user plans to further investigate the current draw and consider replacing the battery if issues persist.
TL;DR: 100 mA parasitic draw can flatten a 55 Ah battery in ≈23 days; “12.3 V is almost an empty battery” [Elektroda, Xantix, post #16447391] Check resting voltage, charge to 14.4 V, then test current leak. Why it matters: Quick checks avoid needless battery swaps or breakdowns.
• Healthy resting voltage: 12.50–12.90 V [Elektroda, wzielonymgaju18, post #16431872] • Full charge voltage: 14.4–14.7 V [Elektroda, Strumien swiadomosci swia, post #16432024] • Parasitic draw limit: ≤300 mA; aim for <50 mA [Elektroda, wzielonymgaju18, post #16431872] • 100 mA leak ≈2.4 Ah lost per day [Elektroda, vodiczka, post #16433901] • Typical 55 Ah replacement battery: 14 kg, €60–€90 [“Exide spec sheet”, 2023]
How long will a 100 mA parasitic draw drain a 55 Ah battery?
100 mA removes 2.4 Ah every 24 h [Elektroda, vodiczka, post #16433901] From full, voltage drops to the 50 % point in about 11 days and hits crank-failure (≈11 V) near day 23.
How do I measure standby current safely?
  1. Switch car off and close doors.
  2. Insert multimeter (10 A range) in series with the negative cable.
  3. Wait 10 min for modules to sleep, then read draw. Pull fuses one-by-one to spot the circuit [Elektroda, wzielonymgaju18, post #16431872]
At what cranking voltage should I replace the battery?
If voltage under starter load drops below 9 V, the battery is finished [Elektroda, vodiczka, post #16435089] 10–10.5 V is borderline; plan a replacement soon.
Can a two-year-old battery already lose most capacity?
Yes. A single deep discharge below 11 V can sulphate plates and slash capacity by 40 % [BatteryUniversity, 2022]. The thread shows a two-year unit hitting 10.5 V after parking [Elektroda, DjAlcon, post #16431790]
3-step test: battery or car?
  1. Fully charge to 14.4 V, then disconnect from car.
  2. Let it sit 48 h; voltage should stay above 12.6 V.
  3. Reconnect, measure overnight drop. Stable off-car but falling in-car means wiring leak [Elektroda, Xantix, post #16433924]
How much charge does a 14 km commute restore?
With a 50 A alternator and average 20 A net charge, 14 km (~20 min) returns roughly 6–7 Ah. That only replaces a small overnight loss, not a deep discharge [Bosch, 2021].
What happens if I keep letting voltage fall below 11 V?
Repeated deep discharges can cut cycle life to 30 % of rated cycles and may cause internal shorted cells—a failure seen as overnight voltage collapse [Elektroda, Ricoh_220, post #16447622]
How long should I charge a 55 Ah battery at 10 A?
Rough guide: hours = Ah/charging-A ×1.2. So 55 Ah/10 A ×1.2 ≈ 6.6 h. Finish when amperage tails below 2 A [“CTEK Manual”, 2022].
Does rear-window defrost affect radio reception?
Yes. Some cars use the defrost grid as the radio antenna. Energising the heater adds noise and can mute stations [Elektroda, Xantix, post #16434177]
