No Das Erste program on the decoder from Cyfrowy Polsat HD 5500Ss
pyjter2012 9153 11
How can I find Das Erste on a Cyfrowy Polsat HD 5500s decoder when it no longer appears on Hot Bird?
Das Erste is no longer on Hotbird; it should be searched on Astra 19.2°E, using transponder 11494 H with SR 22000 for the HD version or 11837 H with SR 27500 for the SD version [#16432219] [#16439297] If the channel is not found automatically, add the transponder manually and run the search again [#16432219] [#16439297] Also check the DiSEqC settings on the Polsat decoder and make sure the Astra port is selected [#16438606] The fact that other German channels and TV Trwam are received suggests the receiver is already seeing Astra, so the remaining issue is most likely the wrong transponder/search setup rather than the dish itself [#16439035]
  • Cyfrowy Polsat decoder cannot tune Das Erste on Astra
    #1 16431986
    pyjter2012
    I will describe the problem as best I can, but I am green in this matter.
    I am at friends in Germany. They have a satellite dish with 2 receivers (I don't know what it is called professionally) and receive programs from Astra and Hot Bird.
    Four antenna cables up to four decoders come out of the antenna.
    1 decoder is from Cyfrowy Polsat, the rest are some ordinary German decoders.
    The problem is as follows:
    On digital Polsat, in place of the Das Erste channel, a message is displayed that the program has been moved from Hot Bird to Astra. Searching on Astra manually and automatically with the settings for China, I do not find this program, but on the usual German decoder this program is.
    I checked the parameters and like everything is the same that on this German decoder it writes that the satellite is Astra 1F / 1G / 1H and on Cyfrowy Polsat it writes that the satellite is Astra 1H / 1KR / 1L / 1M. The Astra 1F / 1G / 1H satellite cannot be selected.
  • Request to clarify the LNB-to-decoder connection topology
    #2 16432099
    dedito
    Help: 527
    Rate: 595
    From the antenna? Rather, from the converters that you call the receivers.
    And there is nothing between converters and decoders?
    Show exactly what is the connection pattern from converters to decoders.
    If the decoder receives only one cable from the converter and there is nothing between it, the decoder receives only one satellite.
  • #3 16432219
    LeDy
    Help: 1992
    Rate: 2940
    Das Erste 11494H Astra 19 °. On Hotbird they no longer broadcast.
    Search transponder and if you don't have it, add and search.
  • HD 5500S cannot find Das Erste transponder manually
    #4 16438496
    pyjter2012
    I was at a friend's.
    I took photos to show how it looks:
    TV with Cyfrowy Polsat connected:
    Cyfrowy Polsat HD 5500s decoder:
    The television on which is the Das Erste program, the difference between these two decoders is the abovementioned designation: Astra 1H / 1KR / 1L / 1M and on the other Astra 1E / 1F / 1G
    Second decoder:
    There's something like this between the satellite and the set-top boxes:
    and the satellite dish looks like this:
    Can I add a transporder on this decoder?
    I searched all possible frequencies by hand and I can't find Das Erste on this decoder from Cyfrowy Polsat.
  • #5 16438606
    LeDy
    Help: 1992
    Rate: 2940
    What I mentioned above is MPEG-4 and this 11836 is still SD. If this is not the case, add a transponder and search.
    The above mentioned does not matter.
    Turn on DiSEqC in the polsat decoder, set the ports to receive Astra.
  • #6 16438657
    pyjter2012
    Polsat decoder receives Astre as seen in the attached first photo. DiseqC is set, and Das Erste is not there.
  • #7 16438689
    KIEROWCA_VW
    Help: 273
    Rate: 676
    The program will not jump by itself.
    Set the parameters of the channel you are looking for, if there is no transponder then add it (create), give a photo with this action.
  • #8 16438904
    pyjter2012
    Tomorrow I will add photos to show how I try to search for this program.
  • #9 16439035
    dedito
    Help: 527
    Rate: 595
    As she receives TV Trwam it is confirmation that she is receiving Astra.
  • #10 16439094
    pyjter2012
    Receives all other German programs that are probably broadcast on Astra? Except for Das Erste.
  • #11 16439297
    _kli_
    Help: 762
    Rate: 1040
    Parameters of Das ERSTE on the Astra:
    11 494 H / Transmission speed SR 22000 (HD version)
    11,837 H / Baud rate SR 27500 (SD version)
    Method of manual programming ZDF and ERSTE (in this case Hot Bird). Das ERSTE on HB is no longer suitable
  • #12 16441671
The discussion revolves around a user experiencing issues with the Cyfrowy Polsat HD 5500S decoder, specifically regarding the inability to access the Das Erste channel, which has reportedly moved from Hot Bird to Astra satellites. The user has a satellite dish connected to multiple receivers, including the Cyfrowy Polsat decoder and other German decoders. Despite confirming that the Polsat decoder is set to receive Astra signals, the Das Erste channel is not found, while it is accessible on the German decoder. Participants suggest checking the connection setup, ensuring the correct transponder settings, and enabling DiSEqC on the Polsat decoder. The parameters for Das Erste on Astra are provided, indicating the need for manual programming if the channel is not automatically detected.
