Choosing a 2000W 4-Stroke Generator for Home: PSMtools PS-AP2600 vs Graphite 58G903 with AVR
Grzes133 85014 53
How can I safely power a home pellet stove, pumps, TV, computer and lights during a few-hour outage on a budget, and are cheap 2000–2600 W 4-stroke AVR generators suitable for that purpose?
Neither of these cheap AVR generators is the ideal choice for a pellet stove and circulation pumps; the thread recommends a true pure-sine source or, better yet, a dedicated UPS/inverter with a battery for CO systems [#19728274] [#19725133] TVs and computers are usually fine on an AVR generator because their switch-mode power supplies are tolerant, but motors, pumps and boiler/controller loads are much more problematic, especially with cheap units [#19725311] [#19728577] One reply points out that the Fogo F3001R has AVR+ but is not pure sine, so it may work for TV/computer/monitor type loads, while an inverter model like the FOGO F2001is is a much better quality solution [#19728577] For emergency heating, the suggested practical setup is a full-sine UPS/converter with a suitably large battery, at least about 70 Ah and preferably 100–120 Ah, with an optional PV panel to keep it charged [#19725133] [#19728577] Another reply warns that in this price range there are no miracles: cheap generators with ordinary AVR are simply not designed to reliably support central-heating systems [#19728274]
  • AVR generator still not safe for TV and computer loads
    #1 19724842
    Grzes133
    Rate: 16
    I am in the process of choosing a generator for my home. I mean emergency situations, e.g. in winter, when there is no electricity for several hours to support the stove and its controller, pumps, TV, radio, computer lighting at home, kettle.
    I know that TV and computer devices are very sensitive and it is necessary for the generator to have voltage stabilization. The amount is max PLN 1200, the power is approx. 2000W and it must be a 4-stroke.
    I know it's too small an amount for a good generator, but maybe one of these two.
    I don't want a UPS because there the battery will run out and I have no power supply, but I will fill the generator with gasoline and it works without restrictions.
    I considered two aggregates:
    Power generator PSMtools PS-AP2600 2600 W - the description states that it can work with sensitive TV devices and has very good reviews on the portal.
    GRAPHITE POWER GENERATOR 58G903 2000W AVR - supposedly has voltage stabilization, but I found the instructions in the manual not to connect it to devices such as TV, computer.
  • Pure sine output recommended for generators
    #2 19724879
    Mobali
    Help: 1355
    Rate: 3920
    When looking for a generator, look primarily for devices offering an output with the so-called pure sine. This is especially necessary if you have engines to power (e.g. central heating pumps). So before you make a decision, read a bit about the problems with this type of aggregates, for example here:
    https://www.elektroda.pl/rtvforum/topic654679.html#3385642
    https://www.elektroda.pl/rtvforum/topic3406045.html#16909179
    https://www.elektroda.pl/rtvforum/topic3506824.html#17485189
    So let go of cheap Chinese aggregates, because they can make a lot of mess. And the one with a sine ... Well, as in life - the better the sine, the greater the expense ;-)
  • #3 19724889
    anchilos
    Help: 491
    Rate: 967
    Grzes133 wrote:
    The maximum amount is PLN 1,200
    Give it up and forget it.
    At this price, they will write everything that is not there.
    https://allegro.pl/oferta/agregat-pradotworczy-2600w-230v-12v-6-5km-avr-9910612751
    Great as described.
    I guess I'm an idiot, because I paid 4.5k for a Honda without AVR (now about 6k).
    Without the AVR, it holds the tension perfectly.
    Regards.
  • Cheap generators unsuitable for boiler backup loads
    #4 19724912
    Mobali
    Help: 1355
    Rate: 3920
    The one indicated by alledrogo is an example of cheap aggregates that are completely unsuitable for working with CO. And it must also be honestly emphasized that the seller does not promise such miracles ;-)
    Grzes133 wrote:
    ...e.g. in winter, for several hours, there is no electricity to support the stove and its controller, pumps, tv, radio, computer, lighting in the house, kettle.
    And if the problem really only concerns several hours and you are able to give up the kettle during this period (because it is terribly energy-intensive!) There are other, much simpler solutions to the problem of maintaining the power supply.
  • Cheap generators unsuitable for pellet stove backup
    #5 19724928
    Grzes133
    Rate: 16
    Grzes133 wrote:
    ...e.g. in winter, for several hours, there is no electricity to support the stove and its controller, pumps, tv, radio, computer, lighting at home, kettle.
    Both from alledrogo are not suitable for the oven?
    in one of them the seller writes this: "Allows you to work with sensitive receivers, such as computers, televisions or telephones"
    And what else can I use to support a 23 kW pellet stove, it has 3 pumps, a fan and a pellet feeder ... It would be good if it also supported 1 lamp.
    Instead of a kettle, I have a gas stove for cylinders, so I can give up the kettle
  • #6 19724933
    anchilos
    Help: 491
    Rate: 967
    Grzes133 wrote:
    pellet feeder
    Inrush currents approx. 5x compared to normal operation.
    What power of the feeder motor?
    Forget the kettle!!!
  • #7 19724956
    Grzes133
    Rate: 16
    Feeder motor power 40W.
  • #8 19724966
    anchilos
    Help: 491
    Rate: 967
    So none.
  • Recommend dedicated UPS solutions for pellet stove backup power
    #9 19725133
    Mobali
    Help: 1355
    Rate: 3920
    The solutions exist, they are simple, and most importantly - dedicated to CO systems. Here are examples:
    1. Rectifier/UPS converter with a full sine of 12V plus a battery of appropriate capacity (I will send an example on priv, because we do not paste links to alledrogo here)
    2. A similar set, but supplemented with a solar panel responsible for "free" charging and maintaining the battery. In my opinion, this is the most reasonable and very reliable solution.
    Importantly, by choosing one of these solutions, you will spend much less, and the system will be safer for the receivers connected to it. Similar dilemmas are also in this thread - maybe you can use something: https://www.elektroda.pl/rtvforum/topic3848219.html Well, and use the "search", because the topic of emergency power supply of CO systems often appears in Elektroda.
  • #10 19725160
    anchilos
    Help: 491
    Rate: 967
    Mobali wrote:
    supplemented with a solar panel responsible for "free" top-up
    Will it amortize before it crashes?
    I noticed the quotation marks.
  • Generator sizing must account for starting currents and load sequencing
    #11 19725208
    luap
    When selecting a generator, it is necessary to balance all receivers that we have to supply, assume a sequence of switching on and take into account the starting currents. In the case of devices with motor drives, starting currents should be assumed at the level of x7 (for direct starts), which will translate into an approximately 2-fold increase in active power and a 7-fold increase in apparent power of the starting motor (these discrepancies result from the fact that the motor the transformer is compact and has a very low cos? ;) . The level of active power to be taken over by the generator affects the transient frequency drop, while the apparent power affects the transient voltage drop. In addition, the sequence of switching on should be taken into account, because each genset has a specific capacity to take over the load in a step - as a rule, it can be assumed at the level of ~ 60% of the genset's rated power.
    As for the power supply of electronic devices, they usually have impulse power supplies operating in a wide range of input voltages and are not very sensitive to frequency deviations of the supply voltage because there is a rectifier at the input.
    Approximately 20% of the generator power reserve should be added to the power balance prepared in this way.
  • #12 19725256
    nak71
    Help: 20
    Rate: 29
    anchilos - "I must be an idiot, because I paid 4.5k for a Honda without AVR (now about 6k)."
    I do not know what Honda you bought, but on a well-known website, Honda prices without AVR start at PLN 2,700. and from AVR are from PLN 3750.
  • AVR is sufficient for TV and PC loads
    #13 19725311
    William Bonawentura
    Help: 190
    Rate: 619
    Grzes133 wrote:
    I know that TV and computer devices are very sensitive and it is necessary for the generator to have voltage stabilization. The maximum amount is PLN 1,200
    With twice the fund, you can buy a Chinese with an inverter. He will have both good stability and work culture. The AVR must have a constant engine speed regardless of the power input. The inverter with a small load "pops" at 1000 rpm.
    Both the TV and the PC are very insensitive to the supply voltage because they are powered by impulse converters. They already run at 90-100V and it can be "rectangle". They just don't handle the stress. But here AVR is effective enough.
  • #14 19725329
    Grzes133
    Rate: 16
    Will this unit be better than the previous two:
    Barracuda AGP28001FRR 2800W
  • Cheap generators unsuitable for carbon monoxide backup
    #15 19725353
    hevet2
    Level 32  
    Help: 216
    Rate: 620
    Both are perfect, I don't know where you came from.
    The kettle may outgrow them, but it will also manage itself in the short term.
    From the cheap ones, look at the Kraft Dele with a copper winding.
    They have as much in common with Honda as I have with the moon.
  • #16 19725419
    Mobali
    Help: 1355
    Rate: 3920
    And how long do you think it takes for a PV panel to "fall down"?
    hevet2 wrote:
    Both are the best...
    Well, I wish you a lot of luck when working with boiler controllers and central heating pumps.
    hevet2 wrote:
    ...look at Kraft Dele with copper windings.
    Kraf Dele - synonymous with quality and reliability?
    I just agree here.
  • #17 19725479
    anchilos
    Help: 491
    Rate: 967
    EA6000
    Added after 6 [minutes]:
    It's quick to answer a question with a question.
  • #18 19725573
    Grzes133
    Rate: 16
    Or maybe this solution will be good?
    1000W uninterruptible power supply with pure sine connected to the battery. The stove is connected to the power supply.
    In addition, in the event of a longer power outage, this Barracuda unit is connected to charge the battery to ensure continuity of operation of the power supply.
  • Small generator can run boiler controls without AVR
    #19 19725854
    hevet2
    Level 32  
    Help: 216
    Rate: 620
    hevet2 wrote:
    ...look at kraft dele with copper winding.
    I just agree here.
    I've been using it for years with boiler, TV and computer controllers and there is no problem (supposedly there are problems with gas stoves, but it's for other reasons).
    As for the Kraf Dele brand, it is a mean product (like all others, but it had copper), anyway, what you can buy for PLN 1,200 (but you can use it and it produces electricity) and you don't need any luck because thousands of people use it. For PLN 1,000, he will not buy a decent inverter with a real sine, let's not be magic. The controller, blower and central heating pump run on a small two-stroke unit without AVR (after small maneuvers).
  • AVR is enough for TVs and PCs, not pumps
    #20 19728274
    Mobali
    Help: 1355
    Rate: 3920
    hevet2 wrote:
    I have been using it for years with boiler, tv and computer controllers and there is no problem (
    It is different with others, especially with pumps and controllers. It is obvious that TV or computers will not have any problems - this is a direct result of the design of their power supplies. There's no point in repeating myself, so I'll quote my colleague:
    hevet2 wrote:
    As for the Kraf Dele brand, it's a mean product...
    Exactly - so why recommend such crap to someone?
    That's what I tried to explain above. There are no miracles and in this price range there is only poor quality and ordinary AVR. And this equipment is simply not designed to support CO systems, which I tried to point out to the author of the topic.
  • Question about Fogo F3001R sine wave output
    #21 19728380
    Angry_Us3r
    Help: 6
    Rate: 17
    Hello, I know it's a slightly different price range, but what do you say about the Fogo F3001R?
    Any chance this dynamo produces something like a sine wave?
    Technical data:
    Voltage stabilization: +2/- %
    Frequency: 50Hz
    Voltage: 1 phase 230V
    Maximum power: 2.7 kVA
    Rated power: 2.5kVA
    Rated Current: 10.9A
    Weight: 38 kg
    Length: 580mm
    Width: 405 m
    Height: 415mm
    Generator: Synchronous
    Model: KR80D
    Degree of protection: 23 IP
    ENGINE - Manufacturer: TMH
    Engine Model: T210
    Fuel Type: Gasoline
    Tank capacity: 3.6L
    Consumption at power: 75% 1.4 l/h
    Sound power: 96 Lwa / dB(A)
    Sound pressure: 75.8+/-0.6 LpAm / db(A)
  • Inverter generator or battery UPS for safer backup
    #22 19728577
    Mobali
    Help: 1355
    Rate: 3920
    Other than a slightly different quality compared to the Kraft Dele, don't expect miracles on the power side. This Fogo F3001R chiller has AVR+ so it's not a pure sine wave. Those devices that have switching power supplies, so they will work without any problems (TV, computer, monitor, etc.). Brush motors are not bothered by this, but it will be much worse with induction motors. Also UPSs connected to such a network can go crazy, because they usually control the voltage at the input much more precisely. Despite the higher price, do not expect that central heating devices (mainly pump motors!) will work properly.
    From this company, the FOGO F2001is is a single-phase power generator equipped with an inverter generator that offers much more accurate voltage and frequency stabilization. There will be no ideal, but it is a much better quality shelf and "better current." Here is a description of this device:
    Fogo f-200..is-.pdf (126.13 kB)You must be logged in to download this attachment.
    Once again, I emphasize that a better, cheaper and safer alternative for several hours of power supply is a UPS with a battery. It is also a more reliable system, the backup time of which depends directly on the battery capacity and the power consumed. The absolute minimum is about 70 Ah, but 120 Ah units should already work very efficiently. A solar panel can be used to recharge and maintain the system in standby. A set consisting of a battery and a suitable converter can be assembled from PLN 500 to PLN 1000 (the costs are mainly determined by the battery capacity). However, with full safety for the powered devices, it will still be from a quarter to only half of the money that needs to be spent on a cheap and not fully suitable generator. Adding to this the operating costs (mainly fuel) and the inevitable inconveniences of owning a generator, the choice seems obvious.
  • #23 19728726
    anchilos
    Help: 491
    Rate: 967
    I'm very interested.
    Please some example:
    Panel and inverter that will support in winter
    Mobali wrote:
    about 70 Ah, however 120 Ah units
  • #24 19728740
    vorlog
    Level 40  
    Help: 527
    Rate: 2586
    I bought SinusPRO 500 from VoltPolska link
    PLN 375 on Allegro.
    It will work with an AGM 100Ah car battery, because I have a loose one (of course there are no more 100Ah ones), load - two pumps working in the first gear (2x 30W), cyclically. A little should come.
    V
  • #25 19728750
    anchilos
    Help: 491
    Rate: 967
    vorlog wrote:
    from VoltPolska
    Isn't it "made in Cathay"?
    Regards.
  • #26 19728755
    vorlog
    Level 40  
    Help: 527
    Rate: 2586
    And what isn't...
    V
  • #27 19728774
    anchilos
    Help: 491
    Rate: 967
    vorlog wrote:
    And what isn't...
    Little Chinese "made" abroad. :D
    fashion. let it go.
  • Honda engine only, not a full Honda generator
    #28 19728825
    płetwa
    Help: 165
    Rate: 553
    anchilos wrote:
    EA6000 Added after 6 [minutes]:
    Quick to answer a question with a question
    This unit has only the HONDA engine, it was manufactured (or rather assembled) in Poland for ARIES POWER (HONDA distributor), not by HONDA POWER EQUIPMENT. Not everything with a HONDA engine was built by HONDE.
  • Budget inverter recommendation with AGM battery backup
    #29 19729389
    hevet2
    Level 32  
    Help: 216
    Rate: 620
    PLN 375 on Allegro.
    V
    Show me the graph from the oscilloscope of the "produced" sine that it will walk on the "square" I have not questioned anywhere (as you already refer to me).
  • #30 19729393
    vorlog
    Level 40  
    Help: 527
    Rate: 2586
    Somehow I don't want...
    Oh, anyway... What the hell :P
    V
The discussion focuses on choosing a low-cost home backup generator for emergency winter outages to power a pellet boiler, circulation pumps, controller, TV, computer, lighting, and possibly a kettle. Participants explain that cheap 2 kW-class generators with AVR are often unsuitable for sensitive loads and motor-driven heating equipment because of poor voltage/frequency stability, high inrush currents, and misleading seller descriptions. Several replies recommend either a true inverter generator with a pure sine output or, better for boiler systems, a dedicated UPS/inverter with a battery and optionally PV charging. Specific alternatives mentioned include Fogo inverter units, Volt Polska SinusPRO with AGM batteries, and larger emergency power systems. The thread also compares budget brands such as Kraft Dele, Barracuda, Graphite, PSMtools, Hecht, and Kruzer, while stressing that TV and PC power supplies are usually tolerant, but pumps, feeders, and boiler controllers require much more careful sizing and waveform quality.
