Yooda roller shutter - how do I add a new roller shutter to the Artistic 15 channel remote control?
Maciek_Krk 3855 0
  • #1 16435004
    Maciek_Krk
    Welcome,
    I currently have 12 Yooda roller shutters in my house, 11 of which are programmed to the Artistic remote (15 channel). I have recently plugged in 1 roller shutter (it hasn't been used since I started) and would like to add it to the remote.
    I found instructions on how to do this but I think I'm doing it wrong.
    I tried to do it this way:
    a) I set on the remote the channel under which I want to have the roller shutter
    b) I press 2x the P2 button
    c) press 1x up button on the remote control
    d) I press 2x down button on the remote control
    Unfortunately, nothing happens, i.e. according to the instructions, the roller shutter should beep when I press the P2 button, but this does not happen, and the roller shutter does not react afterwards either.
    I should add that after connecting the power supply, the roller shutter did not make a sound (it made two short up/down movements, which, if I have read correctly, means that there is already a remote control in memory.
