How do I set the time control for Yooda roller shutters with obstacle detection?
Fronteri 3204 9
How can I add timer control to Yooda roller shutters with obstacle detection and impulse-style wall switches?
The practical solution is to use a Yooda-compatible potential-free transmitter/remote that can handle group control and time or astro functions, instead of trying to time the shutters directly from the Integra impulse input [#17419500] Each shutter already has its own integrated controller, so you should first check whether the fitted relay/controller can be switched by jumpers from the simple one-button mode to up/stop/down mode, which would make automation much easier [#17314092] If you use a transmitter, the shutter can still be stopped by pressing the opposite direction while it is moving, even without a separate stop wire [#17314424] For two independent groups, one reply notes that direct Integra control would need separate open/close outputs per group, i.e. 2×2 outputs for two groups [#17314397] A concrete example mentioned in the thread is a Proxima TFT remote that works with Yooda/Dooya/Aluprof/Portos and offers group and time control [#17419500]
  • #1 17312763
    Fronteri
    I have installed roller shutters with Yooda motors with obstacle detection, radio-controlled (Nuxo remote control 30 channels), and on a bell switch by the window (assuming roller shutter in the up position - click roller shutter down, second click roller shutter stops and then roller shutter up - roller shutters controlled with impulses from the switch, there is no 230V connection to the switch, only 2 thin control cables).
    I would like to control these roller shutters temporarily and I have no idea how to go about it so that it makes sense, and the company I bought the roller shutters from cannot offer a solution.
    From each roller shutter I have a cable leading to the INTEGRA 64 control panel, which I could use for time control of these roller shutters, but the problem is the impulse control, where a situation may occur in which a roller shutter is not closed for the night and the morning timer from the integra, when releasing a signal to the roller shutter, lowers it instead of leaving it in the upper position (unless it can be bypassed somehow).
    Please give me some hints on how to bite the subject.
    Regards
  • #2 17312918
    Zbych034
    Help: 550
    Rate: 1418
    Check for other inputs on the roller shutter controllers.
  • #3 17313516
    Fronteri
    Unfortunately, there isn't.
  • #4 17313709
    kj1
    Electrician specialist
    Help: 278
    Rate: 850
    You may need to purchase an additional remote control. Have a look HERE .
    I don't know if this remote will work with your system, but this can be clarified with the seller.
  • #5 17314092
    pafciowaw
    Automation specialist
    Help: 480
    Rate: 365
    Out of curiosity, I read up on the web about this roller shutter system.
    To the best of my knowledge: then, in addition to the roller shutters (tubular motor in an 8-angle tube), each roller shutter/group of motors? must have a controller/transmitter.
    According to https://silnikdorolet.pl/sterowanie-przewodowe-yooda/62-przekaznik-r1s.html
    has the possibility to set the operating mode with jumpers. The Author's installation uses the simplest/cheapest control method - one-button. If this could be changed/converted to an up/stop/down system then group control (closing/opening at a specific time would be trivial.
    You need to check what type of relay has been fitted - start with this to consider improving the functionality of the system.
  • #6 17314227
    kj1
    Help: 278
    Rate: 850
    pafciowaw wrote:
    To my knowledge: this is in addition to the blinds.....
    Well, precisely no. Each roller shutter has its own integrated controller/.
    Link .
    It seems to me that the solution may be to use THE driver.
  • #7 17314360
    Fronteri
    The YOODA potential-free transmitter would be an interesting solution if it were not for the fact that one group of roller shutters can be controlled here, and I would like to divide the whole house into at least 2 groups (living room+kitchen and separately the bedrooms). With such a system, I would need 2 transmitters, which would 'eat up' PLN 500, and 6 outputs from the integra - a bit weak. I think it will be hard to come up with something sensible with these drives....
  • #8 17314397
    pafciowaw
    Help: 480
    Rate: 365
    Col. kj1 - actually that is a good idea :) .
    Col. Fronteri - like two groups of roller shutters and close/open functions then only 2 x 2 = 4 outputs from Integra ;)
  • #9 17314424
    Fronteri
    It could be controlled without a stop wire (anyway, you can stop the roller shutter by pressing the control button in the opposite direction while it is moving - I'm talking about control from a remote control, so it would probably be the same with this transmitter). No matter how you look at it, it's a bit expensive. I'll probably stick with two relays and a slightly handicapped control directly from the integra.
  • #10 17419500
    Marek J.
    Help: 526
    Rate: 951
    Fronteri wrote:
    The YOODA Potential-Free Controlled transmitter would be an interesting solution if it were not for the fact that one group of roller shutters can be controlled here, and I would like to divide the whole house into at least 2 groups (living room+kitchen and bedrooms separately). With this arrangement I would need 2 transmitters
    One remote for all roller shutters, groups, time control astro function etc. etc. e.g. such:
    https://www.proxima.pl/produkt/pilot-roletowy-tft-kopia-2/
    Yooda=Dooya=Aluprof=Portos...
    https://www.proxima.pl/wp-content/uploads/201...Instrukcja-Proxima-Pilot-TFT-PORTOS-YOODA.pdf
The discussion addresses the challenge of implementing time control for Yooda roller shutters equipped with obstacle detection and controlled via impulse signals from a bell switch and a Nuxo 30-channel radio remote. The main issue is the impulse-based control system, which complicates automated timed commands from the INTEGRA 64 control panel, risking unintended shutter movements if the current position is unknown. The roller shutters each have integrated controllers with no additional inputs for direct time control. Suggested solutions include acquiring additional remote controls compatible with the system or using Yooda potential-free transmitters, though these may require multiple units and several control outputs, increasing complexity and cost. The possibility of converting the control mode from a single-button impulse to an up/stop/down system via relay jumpers was noted, which would facilitate group control and timed automation. One recommended approach is grouping shutters to minimize control outputs needed from the INTEGRA panel. Alternative remote controls with astro timer functions compatible with Yooda (also known as Dooya, Aluprof, Portos) were mentioned as practical options for centralized time and group control.
