[Solved] Considering the STANLEY STAR 7000 200A Inverter Welder for DIY Projects - Opinions?
HenryK3 34788 18
Is the STANLEY STAR 7000 200A inverter welder a good choice for a beginner DIY user, and are its specifications and power requirements trustworthy?
For a beginner DIY buyer, the thread leans toward caution: the welder is listed at 200 A but only 6% duty cycle at 200 A (40% at 20°C), with about 7.0 kVA input power and likely a 20 A supply protection, so the advertised specs may be optimistic [#16437408][#16438585][#16438598] Several posters warn that cheap inverter welders often exaggerate performance, suggesting you should expect less than the label claims and that around 400 PLN may buy a better unit [#16440087][#16438598] If you want something more predictable, one recommendation was to choose a known brand/model such as Magnum Snake rather than an unknown clone-like product [#16437411] On the other hand, a later user reported that the Star 7000 works well for amateur use, including 3.25 mm electrodes and 25 m of 3x1.5 mm² extension cable, with good arc ignition [#17600146][#18171515] But another owner had a failure after 2.5 years of occasional use, with smoke and a blown fuse, so long-term durability looks mixed [#18170548]
  • #1 16437362
    HenryK3
    Help: 95
    Rate: 192
    I am trying to purchase an inverter welder for DIY.
    I have no experience in welding.
    I'm thinking about STANLEY STAR 7000 200A
    welding current: 200 A weight: 7.1 kg
    Smooth welding current adjustment, Hot start, Anti stick, built-in fan.
    Set with a suitcase, wires and an auto-darking visor for 549 PLN.
    What could this be for the "invention"? STANLEY (I think) is not a producer of welding machines.
    Thank you in advance for your tips and hints.
    HenryK3
  • #2 16437408
    qadam12
    Help: 62
    Rate: 254
    Check what is the working-to-rest ratio given as a percentage, if it is above 75% at a current of about 160A, this is worth / 80% means 8min. work -2min. interruptions / and what kind of protections needed at 160A current - it will be "pulled" by it.
  • #3 16437411
    jerry1960
    Level 37  
    Help: 285
    Rate: 1560
    Personally, I'd rather buy some "Magnum Snake" at least know what's inside.
  • #4 16437420
    ryszard1955
    Help: 34
    Rate: 22
    You can always look inside, evaluate and give away.
  • #5 16438405
    ELSPAW_
    Rate: 9
    Provided that you buy on a receipt and on a distance.
    Added after 4 [minutes]:
    As a colleague qadam12 says, check first of all what is the consumption of power from the network (required protection).
  • Limited information and uncertain origins deter welder purchase
    #6 16438550
    HenryK3
    Help: 95
    Rate: 192
    Thank you for the advice.
    With "look inside, assess and give back" is not a good idea in my case.
    It can be sealed, which I can look at since I do not know it. Rather, it will be a clone.
    I do not know if there is an option to return from the promotion in obi.
    There is not much information about this welding machine on the net.
    Apparently Made in Italy (who believes let it believe).
    I did not even find a clear nameplate, I saw 200% on one of the pages.
    I do not have much pressure to buy, I was hoping that someone from the Collegues knows this "invention".
  • #7 16438585
    Michelson
    Help: 82
    Rate: 305
    Here is the catalog with welders link . It contains some data, in addition to power consumption from the network (only max. 7.0kVA). I found somewhere that the required security is 20A.
  • #8 16438598
    qadam12
    Help: 62
    Rate: 254
    Welding current: 10 - 200 A
    Work cycle: according to EN60974-1 (40 ° C) 6% - 200 A, at 20 ° C (normal use) - 40% - 200 A
    Diameters of the electrode / wire: 1.6 to 5 mm
    Power consumption: 7.0 kVA
    Rated voltage: 230 V - 50 Hz
    Cooling system: fan
    Weight: 6.9 kg
    For 400 you can buy a much better one - so I do not recommend it
  • Seeking a 400 PLN welder recommendation and breaker details
    #9 16439056
    HenryK3
    Help: 95
    Rate: 192
    :arrow: Michelson
    thanks for the link :D It is very likely that the security is 20A. I wonder if C-25 or BI25 :cry: . It is a pity that we do not have the answer of someone who knows, uses this welder.
    :arrow: qadam12
    W / g data (it is written) 160A 75% supposed to be ok
    Included is a suitcase and an auto-darkening visor worth about 100 PLN?
    Please, write to me what specific model of welding machine you currently recommend for 400 PLN.
    :arrow: jerry1960
    I looked so fast, the online prices of Magnum Snake 200P 200A start at over PLN 700 + visor about PLN 100.
    You recommend?
    It's almost 2x exceeds the budget.
    I asked the main question under the influence of emotions (quasi-promotion?).
    Every piece of information is valuable to me, although I do not have to buy urgently.
    Considering the STANLEY STAR 7000 200A Inverter Welder for DIY Projects - Opinions?stanley_..e.jpg (139.79 kB)You must be logged in to download this attachment.
  • #10 16439162
    qadam12
    Help: 62
    Rate: 254
    INVERTER WELDER IGBT 250A
    Look for PLN 399 - 40 visors you can buy
    1 Working cycle: 100% - 193A, 60% - 250A
  • Questioning dubious welder specifications and model identification
    #11 16439306
    HenryK3
    Help: 95
    Rate: 192
    Buddy, you killed my nail ...
    Write what checked model / type you had in mind.
    One of the auction sites is (from the elektro-mar2 seller)
    GERMAN INAERATOR WELDING MACHINE 250A IGBT Eurotek EW248
    price PLN 290
    weight (with packaging): 5 [kg] ???
    Delivery costs - Courier shipment PLN 12.00
    Eurotek Model EW248 250A
    Hot Start, Anti Stick, Gen Power
    IGBT technology
    Smooth regulation of the welding current in the range of 20 - 250 A, allows even the beginner optimal performance of welding work. Possibility of using 1.6 - 4 mm electrodes. The welder has an ammeter (???), a fan and a thermostat. Small dimensions and weight compared to traditional welders.
    Welding current - Adjustable 20 - 250A
    Diameter of the electrode 1.6 - 4.0 mm
    BLE A A in the previous 200A 1.6-4.0 mm
    I am beginning to doubt the credibility of what the Seller writes ...
    MASK WELDING ROLLER SAMPLING AUTOMATIC SCALER + 2 FILTERS MODEL M79384
    weight (with packaging): 25.00 [kg] ???
    Delivery costs - Courier shipment PLN 15.00
    Fear to be afraid... Considering the STANLEY STAR 7000 200A Inverter Welder for DIY Projects - Opinions?spaw1.jpg (55.98 kB)You must be logged in to download this attachment.
    Did you mean IGBT 250A LCD DISPLAY FOR GERMAN KRAFT & DELE PROFESSIONAL for 399, - ???
  • #12 16439418
    qadam12
    Help: 62
    Rate: 254
    Yes
    Added after 43 [seconds]:
  • #13 16440087
    bearq
    Help: 414
    Rate: 1612
    These working cycles are just a wishful thinking, take 1/3 of what the producer says. The cheapest one for PLN 400 is fine, you do not need to sleep once on a better one.
  • #14 16441002
    ELSPAW_
    Rate: 9
    A colleague has 100% reasons for these working cycles served from Far Eastern imports, this is what everyone would like to have but it does not have reality - but you read it well :)
  • Abandoning Stanley purchase over unreliable welder specifications
    #15 16443348
    HenryK3
    Help: 95
    Rate: 192
    Thank you for your help.
    Thanks to you, I give up the purchase of the STANLEY welding machine given in the subject.
    It is known that products from the Far East have different housings, names and written parameters. Fantasy production :D
    It can be assumed that in most of these cheap welders, the content is very similar in appearance. There may already be differences with the quality of the quasi-same electronics. The prices depend also on the lettering on the housing and on the Seller's margin.
    I would expect a cheap welder to have a decent (for price) durability and performance. Written 250A, that is, up to approximately 130A, a working cycle, e.g. 75%.
    That's why I created this topic.
    One of the Colleagues suggests Kraft & Dele KD837 IGBT-250 250A with display for PLN 400. Thank you for the advice :D I would buy it willingly but in the supermarket because I have "exceptional luck" to buy faulty devices. Markets order larger quantities and it can be expected that the parameters can be close to half of those written ;)
    In the supermarket, there is always a greater chance of getting the cash back for an exceptional sell and a bit better with a guarantee ..
    I am afraid to buy at the auction from the Seller without a registered office or from a distance of over 500 km :cry:
    I leave the topic open.
    Because the purchase is not very urgent for me.
    Below, as a curiosity, I will give 2 examples of similar welders of similar brands Kraft & Dele _v.s._ KRAFTWELE :D from the auction site ...
    And these "reliable" descriptions. Power in (A). Input current in (W). :idea:
    Considering the STANLEY STAR 7000 200A Inverter Welder for DIY Projects - Opinions?KRAFT.jpg (204.72 kB)You must be logged in to download this attachment.
  • #16 17600146
    Marcinkowski Tomasz
    very good welder. Italian product. Most welders have a description of 300 amps and a wire of 1.6 to 4.0 mm. star 7000 .200 amps and wire from 1.6 to 5.0 mm. I've been using it for a long time and it's great, and I have to add that I'm an amateur. The yellow 4.0 mm are best. practically everything, delicate profiles and thick steel. I used many others out of curiosity. all these magnums, or ideals is just a mess which after a few minutes turn off or do not want to spark. I also add that apart from having a Stanley welder, nothing else connects me with this company. My opinion is purely private
  • #17 18170548
    andrysz
    Rate: 14
    I enjoyed this welder for 2.5 years with occasional use. When welding with a thin electrode and a small welding current, something shot, smoked, the fuse popped up and the welding machine. The warranty has expired, I am looking for a service in the vicinity of Włocławek to see if it is worth repairing and possibly removing the failure.
  • #18 18171515
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1008
    I got this Stanleja in the OBI promotion I got hit and I have to say that she was bravely dealing with the 3.25 electrode so much that she worked on a 25m extension cord 3x1.5 mm2, during welding the fan slowed down a bit. Very good ignition of the arc and I have no comments its exploitation and there is nothing to fault about it I have been welding for 30 years. If someone already has the intention to buy a welding machine from this manufacturer, I recommend the model 7000
  • #19 18366435
    HenryK3
    Help: 95
    Rate: 192
    I recently bought one on promotion from a nearby Kraft&Dele store. It works without complaint apart from the fact that the display shows 120 when the actual current is 80A.
The discussion revolves around the STANLEY STAR 7000 200A inverter welder, particularly for DIY projects by users with little to no welding experience. Concerns were raised about the welder's specifications, including its working-to-rest ratio, power consumption, and overall reliability. Some participants suggested alternative models like the Magnum Snake and Eurotek EW248, emphasizing the importance of checking the quality and performance of budget welders. Users shared personal experiences, with mixed reviews on the STANLEY model, noting its decent performance but also potential issues with durability and service. Ultimately, the consensus leaned towards caution in purchasing the STANLEY welder due to its uncertain quality and the prevalence of clones in the market.
