Connecting USB/AUX Module to Delco Electronics CDR 500 in Opel Vectra B: Step-by-Step Guide
Lekcja9999 14589 2
  • #1 16440514
    Lekcja9999
    I warmly welcome!
    Connecting USB/AUX Module to Delco Electronics CDR 500 in Opel Vectra B: Step-by-Step Guide Connecting USB/AUX Module to Delco Electronics CDR 500 in Opel Vectra B: Step-by-Step Guide
    I wonder how to connect this device to the car. I suppose
    that to the radio which is delco electronics cdr 500 (opel vectra B) it is possible, because I saw
    even on this video. It is true that it is a different radio, but the principle works the same:
    If anyone had any experience, please help me.
    GREETINGS
  • #3 16441130
    aaanteka
    Help: 729
    Rate: 1195
    The entire connection philosophy consists in connecting three wires from a 3-pin plug:
    - P channel
    - L
    - mass
    for the appropriate input in the radio (if it exists) it is usually the AUX / CD input.
    It may be necessary to use an appropriate plug ISO for this intended.
    Connecting the power supply is probably not a problem. Cable + 12V for the + 12V radio cable, ground cable for the radio cable.
    If you have a version powered from + 5V voltage, it will be necessary to additionally use a stabilizer (there is a place on the board).
    You can also use ready-made modules available on share forums.
