Opel Astra H (2005) - 1DIN Radio Connection Issue: Philips CE133 & ISO Connector Problem
xMateo9 14826 5
  • #1 16706495
    xMateo9
    Rate: 8
    Hello, there is a problem with connecting the radio in Opel Astra H (2005). Well, I bought an ISO CONNECTOR but when I connect a new radio in the car it does not work.
    radio PHILIPS CE133
  • #2 16706504
    piotrek22101
    Help: 695
    Rate: 1421
    Coiled red wire, must be connected to the plus after the ignition, lighter, fuses
  • #3 16706508
    DriverMSG
    Help: 3984
    Rate: 4892
    You have 2 red wires in the picture - did you connect them?
  • #4 16706512
    xMateo9
    Rate: 8
    You didn't connect two cables, I thought you didn't have to. Now the question is how and where to connect them
  • #5 16706528
    DriverMSG
    Help: 3984
    Rate: 4892
  • #6 16706536
    piotrek22101
    Help: 695
    Rate: 1421
    At the factory, the Opel cube is solid plus, only needed after the ignition.
