LG 32LN5400 LED TV IPS Matrix Dark Spot Repair: DIY Options, Costs, and Feasibility
B3zK93 8415 9
Can I repair a dark backlight spot in my LG 32LN5400 LED TV myself, what would it cost, and is it worth it?
Yes, it can be repaired, but only if you are comfortable dismantling the LCD panel; otherwise it is easy to damage the matrix and turn the TV into scrap [#16444079][#16444417] The usual fix is replacing the faulty LED/backlight strip, which was estimated at about 35 PLN for the strip, and the repair cost in a 32" set is generally not high [#16444079][#16444417] A shortcut is to bypass the failed LED, and one user reported the TV still working for almost a year, but that is more of a workaround than a proper repair [#16444486] The proper long-term repair is to replace the damaged diode and, if needed, reduce the backlight current by modifying the current-sense bridge so the backlight runs a bit dimmer but more safely [#16444512] If you have never done panel work before, the safer choice is to let a service shop do it because they will take longer but with much lower risk [#16444417]
  • LG 32LN5400 dark spot and backlight repair options
    #1 16444059
    B3zK93
    I have a LG 32 "LED TV with an IPS Matrix.
    He has been with me like this since 2013.
    Currently, I use it as a monitor, and hence for a long time.
    Recently a friend noticed that the matrix has a darker spot (center bottom).
    It is possible that it is longer, but I did not pay attention until today, because the stain was "blinking". Probably some backlight / fall LED.
    I called the LG service and the guy informed me that it is most likely that the matrix backlight is going down.
    I'm from Grudziadz and the nearest website is in Toruń (That's what the guy from LG told me).
    So some questions.
    - Is it possible to repair it yourself? (Difficulty level)
    - Are the repair costs high (Replacing the diode etc?)
    - Does it pay off according to you?
    In general, the TV set blows well, only that point does something.
    At the moment I have reduced the backlight, it does not throw, but it can be that I am drinking something completely.
  • #2 16444079
    Józio17
    Help: 204
    Rate: 198
    Possible if the colleague can disassemble the matrix.
    The cost of the led strip about 35 PLN.
  • #3 16444114
    B3zK93
    I never did that. I wouldn't want to damage anything.
  • #4 16444417
    Andrzej4567
    Help: 26
    Rate: 252
    The answer is rather that if you've never done it before, I advise you not to do it. It is very easy if you do not have practice to damage the matrix, and this is associated with the scrapping of the receiver. The second thing is that if the mechanic does it, he will work longer. The costs of backlight repair in 32 "are not large.
    Best regards.
  • #5 16444486
    capanda
    I also had a similar problem, I stripped the matrix and looked for a damaged diode
    I decided to close it, skip it - one less has not changed the light on the screen - the TV has been running for almost a year - you can try
  • #6 16444512
    robokop
    Help: 1763
    Rate: 6376
    The fact that it works is only a fluke, the remaining diodes, thanks to the short-circuit damaged, work with higher current - that is, in worse conditions. Theoretically, they should die even faster now. In practice, the repair consists of replacing the damaged diode with an identical one, and modifying the measuring bridge of the power supply current, then the whole works with less current and less brightness - which is practically not noticeable to the user, and affects the durability of the backlight.
  • #7 16444593
    Andrzej4567
    Help: 26
    Rate: 252
    He probably works on Picture Mode, which has a lower backlight current and is therefore still working. Usually the user (client) switches to "dynamic" and then won't work for a long time, after the repair as above.
  • #8 16444880
    kazikszach
    Help: 516
    Rate: 1105
    Why do you write misleading foolishness, do you know the principle of operation of the led driver used to control the diodes in the matrix?
    Those with whom I met always had the character of a current source, so keep on telling yourself what changes the shorting of one diode.
    The topic of control rolled out in the forum, but apparently you have not read them.
  • #9 16444938
    robokop
    Help: 1763
    Rate: 6376
    Somehow so far in these TV I have not met, that only one diode was damaged - open. In serial circuits I usually found two - one compact, the other with a break, which was just "putting out the image", hence I conclude that the driver does not fully control the current. That's why "Ruthenians came up with the modification - removing one resistor from the bridge creating a shunt in the circuit of the serial transistor keying the backlight current - to reduce its maximum value. One more thing - this is PWM control - i.e. not voltage regulated, but medium current - so probably clear what will happen.
The discussion revolves around the issue of a dark spot on an LG 32LN5400 LED TV with an IPS matrix, which the user suspects may be due to a failing backlight LED. Various responses suggest that while DIY repair is possible, it carries a risk of damaging the matrix, especially for those without prior experience. The cost of replacing the LED strip is estimated at around 35 PLN, and professional repair is recommended for those unfamiliar with the process. Some users have attempted repairs by bypassing damaged diodes, but caution is advised as this may lead to further issues with the TV's performance. The conversation highlights the importance of understanding the LED driver operation and the potential consequences of DIY fixes.
