ITI 5800 BSKA: Fastscan Issues, Activating Transponder Errors, Enigma2 Factory Reset
misiekpb 10734 9
How can I fix fast scan on ITI 5800 BSKA when transponder activation fails, and is there a factory reset for Enigma2?
Install the current Fastscan plugin, because replacing it fixed the “Activating the transponder” / “incorrect” error during fast search [#16444556][#16450111] There is no useful factory reset for Enigma2; if the system is messed up, you need to reinstall the image from scratch [#16447058] You can flash it via FTP with DCC2 or from a FAT-formatted USB stick containing `rootfs.img`, `kernel.img`, and `update.img`, then insert it in the tuner and hold Power until the box reports OK [#16447058][#16450848][#16450177]
  • #1 16444207
    misiekpb
    Help: 35
    Rate: 144
    Hello. I can not perform a quick search. I have downloaded the latest list via the djcrash plugin, however when I try to search I get the information "Activating the transponder-wait" and then "Activating the transponder-incorrect" "end".
    It does not matter if I try to search NC + Hotbird, NC + Hotbird Astra or Polsat.
    I am asking for advice.
    And the second question, is it possible to do something like a reset to factory settings on enigma2?
    simhak
    Help: 109
    Rate: 336
    Replace - install the current version of the Fastscan plugin.
    Factory settings - for what purpose?
  • #3 16446951
    misiekpb
    Help: 35
    Rate: 144
    On the other hand, even if I were too much confused by trial and error ;)
    What is the location of plugins? Will I be overwhelmed by ftp?
    simhak
    Help: 109
    Rate: 336
    In Enigma, as you messy, no factory settings will help - you win the image from scratch.
    Plugins - after ftp can do it, look for dcc2 for Enigma.
  • #5 16449260
    Darek.S
    Help: 216
    Rate: 979
    You can find the whole image on the Internet OpenPli-86-bska-bsla-weather-correction-quick search-06/04/2017.rar but just replace the fastscan itself
    • FastSearch_fix_nartensen.zip (9.6 KB) You must be logged in to download this attachment.
  • #6 16450111
    misiekpb
    Help: 35
    Rate: 144
    Substitution of the plugin helped. Thank you.
    A image wgram with a pendrive?
  • #7 16450177
    Darek.S
    Help: 216
    Rate: 979
    Yes. You upload three faces to formatted to fat. To the tuner and by holding the Power button to the network. After the upload is finished, the text OK
  • #8 16450819
    misiekpb
    Help: 35
    Rate: 144
    And if in the case of a badly downloaded software, can you consider a decoder? The decoder itself starts installations or arrows you have to choose something? Because somewhere I used to read about sda sdb, etc.
  • #9 16450848
    Darek.S
    Help: 216
    Rate: 979
    misiekpb wrote:
    somewhere once I read about sda sdb, etc.
    Yes, but it is rather about mounting the hard disk. And as for uploading the enigma, you can do it in several ways but I always did it via a pendrive (speech about nbox). You need to download the software in the correct format and there are three files: rootfs.img, kernel.img and update.img. And how to upload already described (maybe laconically but perhaps understandably ...)
  • #10 16498064
    misiekpb
    Help: 35
    Rate: 144
    Fastscan swapped, it blows. Thank you.
The discussion revolves around issues with the ITI 5800 BSKA related to Fastscan functionality and transponder activation errors. Users reported receiving messages indicating "Activating the transponder-wait" and "Activating the transponder-incorrect" when attempting to perform a quick search after updating the Fastscan plugin. Solutions suggested include reinstalling the current version of the Fastscan plugin and performing a factory reset by re-flashing the device with a new image, as factory settings alone may not resolve the issue. Users also discussed the process of uploading software via a USB pendrive, emphasizing the need for the correct file formats and the steps to initiate the upload. The conversation concluded with confirmation that replacing the Fastscan plugin resolved the initial problem.
