ITI 5800sx Fastscan Update: How to Replace File Packet without Internet Connection?
szymis 4929 7
  • Offline Fastscan update via USB flash drive
    #1 16592119
    szymis
    Hello. I can't perform a quick search. When I try to search I get the information "Activate transponder - wait" and then "Activate transponder - incorrect" "end". I found information on how to deal with this packet of files that need to be replaced but I don't know how to do it without a decoder connected to the internet. I can't do that. Can I update the fastscan with a flash drive? If so, I would like to ask for information on how to do it along with the path to which the file should be uploaded.
    I request information.
  • Delete FastSearch.pyo before replacing FastSearch.py
    #2 16592540
    jurekk69
    If you have a dream-explorer in the tuner then you can replace the files as much as possible using the remote control. All in all, I wonder why connect the tuner to the internet? you don't have to, but it's best and most probably done using a computer and total commander over an ftp connection. You replace one FastSearch.py file, but you must first delete the existing FastSearch.pyo.
    Path - I write from memory / usr / lib / enigma2 / python / Plugins / SystemPlugins / FastSearch /
    - I think it was like that.
    I mentioned with FastSearch_fix_nartensen.zip and it works without a problem, however, I have never checked if it searches for all channels.
  • #3 16593479
    szymis
    I have a dream explorer, so I understand that I have to use key combinations on the remote control from the "legend" displayed on the TV screen?
    Connecting the decoder to the internet I thought it was necessary to find the tuner's IP address because after entering the menu-system-network I could not see the IP address, I could not find it. However, I managed and found the IP address but I cannot connect via TC.
    In the hostname I enter the IP from the decoder, the user root and password pkteam because this is how I found in the net that it is used by default or most often. I don't have an ftp server, I don't have one set up and configured, that's why I wanted to change it by pendrive only after choosing the move / copy option, the yellow button on the remote control and indicating the new location It is happening. After removing the pendrive and restarting the tuner, the file is not copied to the location indicated. Should the USB stick remain in the nbox during the restart? 16GB flash drive - does it matter?
  • #4 16593655
    simhak
    Help: 109
    Rate: 336
    What image in the decoder?
    Try without a password.
  • #5 16593672
    szymis
    I tried without a password, it didn't help. Sorry, but where to check the image is there is no idea where to look. I'm just starting the adventure with Enigma2.
  • #6 16594038
    simhak
    Help: 109
    Rate: 336
    Information about the image is in the menu.
    Each of them has different login details, which in turn could have been changed by the previous user of the equipment.
    How do you connect the decoder to your computer?
    Is it BSLA or BXZB?
  • #7 16594317
    jurekk69
    Buddy @szyis, if all attempts to connect to the tuner have failed because of the lack of password, I suggest you upload new software. The only problem you may encounter is how to rework the tuner if it is bzzb or bxzb (the inscription is on the bottom of the tuner) it can be converted using a modchip - and then you need to upload the software a little changed. If there will be an inscription bska or bsla then assuming that nobody replaced the motherboard, in this case there is no modchip and all software will match.
    Of course, you need to think about the configuration of the tuner or card server configuration before downloading the software.
    But all is done very quickly.
  • #8 16598179
    Darek.S
    Help: 216
    Rate: 979
    Then try again root and dreambox . That's how it is in Open PLi ...
The discussion revolves around updating the ITI 5800sx Fastscan without an internet connection. The user encounters issues with activating the transponder and seeks guidance on replacing file packets via a USB flash drive. Responses suggest using a Dream Explorer remote for file replacement and provide a file path for the FastSearch.py file. Users discuss difficulties in connecting to the tuner via FTP, the importance of knowing the decoder's image, and potential login credentials. Suggestions include uploading new software if connection attempts fail, with considerations for the tuner model type affecting the software compatibility.
