NC Plus vs Digital Polsat: Comparing Signal Strength & Quality Differences
mieszalek 5757 6
  • #1 17463910
    mieszalek
    Hello to you. Please tell me if there is a difference in signal strength, quality between the signal sent by nc plus and digital polsat?
    • NC Plus vs Digital Polsat: Comparing Signal Strength & Quality Differences 11.jpg (541.83 KB) You must be logged in to download this attachment.
  • #2 17463960
    sylweksylwina
    Help: 1882
    Rate: 2355
    If I'm not mistaken, both are from the hotbird satellite, so there should be no differences.
  • #3 17463973
    Kenworth 18
    Help: 2445
    Rate: 3752
    The choice of a digital platform depends on the programming offer and it should rather be suggested.
    With the use of a 90 cm antenna, there will be no problem in receiving the channels of both operators.
  • #4 17464024
    mieszalek
    will the picture quality be the same assuming the set-top box, TV and antenna are the same?
  • #5 17464146
    _kli_
    Help: 762
    Rate: 1040
    mieszalek wrote:
    Is there a difference in signal strength, quality between the signal sent by nc plus and digital polsat?
    The times when each operator was transmitting on different frequencies are over. Now nc +, CP and Orange they are broadcasting from Hot Bird from the same transponders. Only the content is encoded in other systems. Thus, the strength and quality of the signal from individual frequencies is the same for all operators. The difference in the signal parameters may be due to the difference in the receiving equipment.
    The picture from the nc + or CP decoder connected to the same TV set may differ slightly, which is the result of differences in construction of these sat receivers.
    If you use an operator independent receiver for reception, and for decoding the CI module signal from nc + or CP, the picture quality should be the same.
    The signal quality, not the image quality, depends on the size and quality of the antenna. The higher the signal quality, the greater its "resistance" to the influence of bad reception conditions (cloudiness, precipitation).
  • #6 17464158
    LeDy
    Help: 1992
    Rate: 2940
    In my opinion, NC + decoders are "less sensitive", they show less strength and quality of the signal.
    Polsat has a better display of signal parameters - strength, quality, bars and percentages and MER.
    The image quality is comparable in both.
  • #7 17464214
    _kli_
    Help: 762
    Rate: 1040
    Of course, it depends on the developers. There was a time that some nc + decoders on previous soft-drives showed 100% very easily. This has changed in recent versions of the software. Now the individual nc + models differ from each other in the% indications of the same parameters.
    CP decoders are not very precise when aligning the antenna, because they show the signal quality "step by step", eg 50-66-83-100% and the corresponding MER 12-13-14-15 dB. Of course, since 15dB is the maximum indication, MER of 16dB and more also show as 15dB.
    Orange decoders show 100% quality with MER> 12 dB.
The discussion compares the signal strength and quality of NC Plus and Digital Polsat, both of which transmit from the Hot Bird satellite. Users note that the signal parameters are generally similar due to shared transponders, with differences arising mainly from the receiving equipment. While the picture quality is comparable, some users suggest that NC Plus decoders may be less sensitive, displaying lower signal strength and quality compared to Polsat. The precision of signal quality indicators varies among different decoders, affecting the alignment process. Overall, the choice between platforms may depend more on programming offers than on signal quality.
