Desktop WiFi Issue: TP Link Archer T2U, Dasan H640GW - Windows 10 1511, MSI GeForce GTX 6GB OC
saabaakaa 6183 2
  • #1 16448390
    saabaakaa
    Hello :) my problem is that I have a stationary with a TP LINK ARCHER T2U network card, the graphics card in the computer is MSI GeForce GTX 6GB OC, no other components are given because they are not needed. Drivers from this graphics card require Windows 10 which it wants to have with update 1511. And here the problem begins, namely:
    1. When installing Windows 10 update 1511, Windows does not see the router, but when I do a hotspot from the phone is ok drivers are installing.
    2. By installing Windows 10 version 10240 a stationary with a network card sees the network but I cannot install the drivers
    3. By installing Windows 7 the card can see the network and I can install the drivers
    The router is Dasan H640GW
    At the end I will add drivers as well as to the network and graphics card are downloaded from the manufacturer's website and are the latest from which there may be a problem.
    jimasek
    Help: 3783
    Rate: 2681
    saabaakaa wrote:
    1. When installing windows 10 update 1511, windows cannot see the router, but when I do a hotspot from the phone is ok drivers are installed.
    But what do the card drivers with the phone have in common?
    What is this router, on what channel does the wireless network from your router, you tried to change this channel?
  • #3 16448494
    saabaakaa
    The router is from a company that provides me with the internet if I can enter its settings but I do not know where to change it, but if the channel was bad, rather Windows 7 or 10 in a different version would not see the router and it is not. The router is DASAN H640GW
    Added after 8 [minutes]:
    I found I actually changed the channel on the router and the wifi appeared to close :) thanks jimasek
