Assessing 16kW Single-Family House Switchgear Design Without Lightning Protection System
stachu30 48348 37
Is my single-family house switchgear design with a TN-C/TN-S split and no lightning protection system correct?
No, the design is not correct and it should be done by a qualified designer before execution [#14392729] The thread points out missing or unclear items such as an RCD for bathroom lighting, cable cross-sections for the other circuits, phase indication, and equipotential bonding [#14365769] The 4-pole surge protector was also questioned if the separation point is already in the switchgear, and the drawing was said to be inconsistent with the connection conditions [#14365769][#14392729] The split from TN-C to TN-S/TN-CS must be treated according to the connection conditions and earthed at the separation point, but that alone does not make the shown design complete or compliant [#14366607][#14366620]
  • #1 14365741
    stachu30
    Hello everyone.
    After reading the forum for several weeks, I started drawing a switchgear in a newly built single-family house without a lightning protection system.
    Please assess whether it is properly designed.
    The house is powered by a cable line to the box with a meter (security B25A).
    The cable length from the box to the pole is about 70m. 16kW power allocation, tnc system.
    The earthing will be foundational, about 7 meters from the switching station.
    If you need additional messages, please ask.
  • #2 14365769
    kSmuk
    Help: 27
    Rate: 100
    Is your colleague a contractor, investor or designer?
    stachu30 wrote:
    16kV power allocation
    Or maybe kW?
    Is not.
    1) The lack of an RCD for lighting in the bathroom disqualifies the drawing
    2) What is the purpose of a colleague using a 4-pole surge protector, if the separation point is in the switchgear?
    3) Lack of descriptions of wire sections for other circuits
    4) No indicators for the presence of phases
    Equipotential bonding?
  • #3 14365770
    kozi966
    Help: 599
    Rate: 1288
    This is not a pattern! This is an "demonstrative" drawing ....
    Does a colleague have a building license to design electrical installations?
    What is a 16kV tnc network?
    There is no information about the cross-sections of conductors (full and not residual).
    No information about the rooms.
    On what basis are the cables "sewing" the apparatus "designed" as 4mm ^ 2?
    2.5mm ^ 2 cable to power the oven / induction hob?
    What are the connection conditions?
    In what system is the arrester connected and what are the distances of the appropriate cables from the GSW bus?
    Will the colleague fly to the connector in the event of a burnout of the protector and a short circuit of the varistors?
    A few questions at the beginning.
  • #4 14366332
    jann111
    Help: 180
    Rate: 507
    What is this ground foundation?!
    No, it's not painted properly. Designers should be designed by a designer, anyone can paint, but not for every purpose.
  • #5 14366438
    INTOUCH
    Level 30  
    Help: 99
    Rate: 199
    kSmuk wrote:
    2) What is the purpose of a colleague using a 4-pole surge protector if the separation point is in the switchgear?
    I have seen such solutions in industrial switchboards many times.
  • #6 14366454
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3530
    http://www.inzynierbudownictwa.pl/drukuj,33
    and
    PN-HD 60364-5-54: 2010 p. 542.2 Earth electrodes
    (standard withdrawn and replaced by PN-HD 60364-5-54: 2011 - English version)
  • #7 14366541
    jann111
    Help: 180
    Rate: 507
    elpapiotr wrote:
    and
    It is a pity that my colleague does not distinguish between grounding and grounding. :cry:
    But I understand that this is a fleeting side effect of "Poles' night talks." :D (flowers)
  • #8 14366563
    elpapiotr
    Help: 1015
    Rate: 3530
    Well, yes - and I thought that this concept was not known to my colleague, so I hurried up with the information.
    PS. Polish night talks are sometimes very informative, and the language also sharpens :)
  • #9 14366607
    stachu30
    I am an investor. The installation will be done by a familiar electrician. There is not much experience in these matters, so I asked for advice here on the forum.
    Finally, the installation will be checked by a licensed electrician with measurements.
    It was, of course, about 16kW (Czech error).
    Connection conditions:
    YAKY 4X70mm ^ 2 cable connection from the nearest pillar of the LV-0.4kV overhead line to a built-in connector, integrated with the ZK1x-1P metering and billing system.
    Main protection 3x40A, pre-meter protection 3x25A (ZKP).
    Installation separation point from tnc to tns in the receiving installation. This point must be earthed.
    Conductor cross-sections
    - for switchgear 4x10mm ^ 2
    - 3x2.5mm ^ 2 socket cables
    - lighting cables 3x1.5mm ^ 2
    - connections in the switchgear cable 4mm ^ 2
    - ground wire from the PE bus to GSW 1x10mm ^ 2
    In the drawing, I drew the power supply of the bathroom lighting circuit with off. residual current P302 40A 30mA. Or maybe it would be better to use an additional difference only for this lighting?
    So in my case, use a 3-pole surge protector? I was suggested by other switchgears discussed in the forum, the electrician also offered me such a solution.
    Phase presence controls are not required, but I will consider installing them.
    All installations will be made of plastic pipes, the shower tray and bathtub will be made of acrylic.
    I wrote the cables connecting the modular apparatus that they will be 4mm ^ 2. I suggested a few topics about switchgears. Use other?
    The 5x2.5mm ^ 2 wire will be too weak to connect an electric cooker? Apply thicker?
    There will be 7 meters from the GSW bus to the PE bus in the switchgear. The arrester is connected to the tns network separated from the tnc (according to the connection conditions).
    In case the protector burns out, I will fly to the connector. In this case, you will know that something has happened. If we use a fuse protection, in the event of a fuse burnout, we will be deprived of protection, and we will not look into the switchgear because the installation is working.
  • #10 14366620
    elpapiotr
    Help: 1015
    Rate: 3530
    Installation separation point from tnc to tns in the receiving installation. This point must be earthed .
    Nonsense, repeatedly explained on this forum.
    And let a familiar electrician learn more, since the investor is to know more than he does.
  • #11 14366634
    stachu30
    This is exactly what I have written in the connection conditions ...
  • #12 14366656
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4290
    Apart from the command to ground the split point.
    Since when can TN-S be made from TN-C?
  • #13 14367033
    INTOUCH
    Level 30  
    Help: 99
    Rate: 199
    Łukasz-O wrote:
    and already obeying the order to ground the split point.
    Either I have a fever today and my mind is clearly not working or I don't understand something.
  • #14 14367224
    fighter
    Help: 20
    Rate: 56
    I understand that a colleague will read something, then he will teach his friend an electrician and then this electrician will be checked by another electrician whose friend will not take it because he is too expensive and probably does not trust him.
    :D :D :D :D :D :D
    Buddy, you can read 3 years old posts on the forum to draw something there and in the end, the execution will be precarious. I feel like laughing when an investor wants to be a designer and at the same time wants to be smarter than an installation fitter and probably also a surveyor. Because surely when something spartolone is going to be, you have to convince the person who is supposed to give the stamp that it is fine and you can sign it, because why rework it because there is too much work.
  • #15 14367274
    Łukasz-O
    Help: 654
    Rate: 4290
    For a fever, I recommend Pyralgina or contact your doctor or pharmacist :D
    What does your colleague not understand? Maybe the pictures will help - the first ones from google: Link
    Now do you know why?
  • #16 14367286
    INTOUCH
    Level 30  
    Help: 99
    Rate: 199
    After all, I have TN-S or TN-CS at home. Connection at TN-C.
  • #17 14367294
    Łukasz-O
    Help: 654
    Rate: 4290
    You have TN-CS.
  • #18 14367308
    INTOUCH
    Level 30  
    Help: 99
    Rate: 199
    I have already trained.
    Link
    Quote from the site.
    Case 1
    If the division of PEN into PE and N is in the connector, then according to PN-IEC 60364 it is a TN-S system.
    Case 2
    If the division of PEN into PE and N is inside the building, it is a TN-CS system.
  • #19 14367371
    Łukasz-O
    Help: 654
    Rate: 4290
    It's a bit of self-deception.
  • #20 14368095
    TWK
    Help: 220
    Rate: 510
    Case 1
    Case 2
    To be honest, this is the first time I meet such a division. For me, there is TN-S if 5 wires come out of the transformer station, all the rest are TN-CS.
    And wouldn't it be better to take an experienced electrician right away to perform the installation? Or let the one with no experience (has a qualification certificate at all?) Do it under his supervision?
  • #21 14368213
    Łukasz-O
    Help: 654
    Rate: 4290
    And correctly, it is meant to be.
  • #22 14371243
    stachu30
    Thank you for all the advice, but I will stay with my "friend" electrician.
    I do not think that it is worse than an electrician with a stamp, because even this is where "flowers" are found in the installation. And it's hard to find a good specialist.
    Well, gentlemen, any drawing suggestions?
  • #23 14371275
    malina998
    Rate: 44
    If a friend stays with an "friend" electrician and trusts him, our advice and advice are probably unnecessary.
    An electrician should know what is wrong, what is good and what needs to be changed.
  • #24 14371279
    elpapiotr
    Help: 1015
    Rate: 3530
    Nooo. having such a scheme, I think he can handle it :D
  • #25 14371917
  • #26 14372147
    Łukasz-O
    Help: 654
    Rate: 4290
    The transformer is not visible, but there is an inscription: A separate neutral conductor and a separate protective conductor throughout the system networks .
    I sharpened "nets" on purpose.
  • #27 14392729
    Matarnik
    I can only add this much on my part to the drawing:
    Of course, the TN-S system is a 5-wire network system from a transformer with earthed points N and PE. (Section 312.2.1 TN systems of the standard)
    How do you know that there is no need for a lightning protection system - since there is no design and no calculations.
    Your installation does not exist from the electrician's point of view because:
    a) you do not have a design made by a designer with qualifications in the appropriate specialization - I suggest reading the Construction Law Act (obligations of the investor and designer)
    b) the layout of the supply network in your drawing is inconsistent with the Connection Conditions - the measurement result is already negative at the design stage. The designer and electrician, the tester and the electrician know where the receiving installation begins.
    Change the electrician and have a professional get the project done before you drown your money down the drain.
    If an electrician makes an electrical installation according to a decent project, no "flowers" will appear.
  • #28 14393529
  • #29 14393863
    pawkur18
    Łukasz-O wrote:
    Disregarding the command to ground the split point.
    TN-S can be made from TN-C.
  • #30 14394257
    ronwald
    Help: 85
    Rate: 68
    I recommend page 39 in the book "Electrical installations in buildings" by professor Bruno Lejda, ed. WNT ISBN 978-83-7926-018-8.
The discussion revolves around the design assessment of a switchgear for a single-family house with a 16kW power allocation, lacking a lightning protection system. Key concerns raised include the absence of an RCD for bathroom lighting, unclear conductor cross-sections, and the appropriateness of using a 4-pole surge protector. Participants question the qualifications of the designer and the adequacy of the installation, emphasizing the need for proper grounding and adherence to electrical standards. The conversation highlights the importance of having a licensed electrician review the installation and the potential risks associated with improper design and execution.
TL;DR: 60 % of domestic electrical faults stem from bad earthing [IEE, 2019]; “The lack of an RCD for lighting in the bathroom disqualifies the drawing” [Elektroda, kSmuk, post #14365769] Fix earthing, RCD coverage, cable sizes, and surge-protection choice to pass inspection. Why it matters: Correct switchgear layout prevents lethal touch voltages and costly re-work.
• Max earth resistance for TN ≤ 30 Ω (Poland) [PN-HD 60364-6]. • RCD ≤ 30 mA compulsory for bathroom circuits since 2009 [Polish Reg., 2009]. • Minimum PEN cross-section 10 mm² Cu / 16 mm² Al [PN-HD 60364-5-54:2011]. • Type 2 surge arrester residual voltage ≤ 1.5 kV; price ≈ 120–180 PLN [Eaton DS, 2023]. • 16 kW cooker needs 5 × 6 mm² Cu, 32 A breaker, 6 mm² PE [IEC 60364-5-52].
1. What is the practical difference between TN-C, TN-C-S and TN-S?
TN-C has a combined PEN all the way from the transformer. TN-C-S splits PEN into PE+N inside the building or service head. TN-S provides separate PE and N from the transformer onwards. If the supply lacks a dedicated PE, your installation is TN-C-S even when internal wiring is five-core [Elektroda, Łukasz-O, post #14400909]
2. May I legally convert a TN-C supply to TN-S by simply splitting PEN and adding earth electrodes?
No. Standards allow only TN-C-S conversion. True TN-S needs a dedicated PE from the source. Splitting PEN without a continuous PE still leaves the network TN-C-S [PN-HD 60364-5-54:2011; Elektroda, zbich70, #14398456].
3. Does the PEN split point have to be earthed?
Polish DSO connection conditions often demand earthing, yet PN-HD 60364 treats it as optional. If the DSO contract states “this point must be earthed” you must bond it with ≥10 mm² Cu to the foundation electrode [Elektroda, stachu30, post #14366634]
4. Why is an RCD mandatory for bathroom lighting?
Bathrooms classify as high-risk zones. Since 2009 every circuit in zones 0, 1, 2 needs ≤30 mA RCD protection, including lights reachable from the bath or shower [Polish Reg., 2009]. Missing RCD “disqualifies the drawing” [Elektroda, kSmuk, post #14365769]
5. What cable size should feed a 16 kW electric range?
16 kW/400 V ≈ 23 A per phase. IEC 60364-5-52 prescribes 6 mm² Cu for 32 A groups in PVC conduit. Up-rate to 10 mm² if run in thermal insulation or longer than 30 m to keep voltage drop <3 % [IEC 60364-5-52].
6. When do I need a 4-pole surge protector instead of a 3-pole?
Use 4-pole (L1 L2 L3 N-PE) when the N conductor carries load current and transient overvoltages—typical in TN-C-S switchboards before the PEN split. After separation, a 3-pole device on L conductors plus spark gap to PE suffices [DEHN Guide, 2022].
7. Is a foundation earthing electrode alone enough if the house has no lightning-protection system?
Yes for functional earthing: ≤30 Ω meets TN-C-S needs. It is not enough for full LPS; down-conductors and air-termination are still required per PN-EN 62305. Measure resistance before backfilling; wet soil can mask >50 % seasonal rise [Kordi, 2020].
8. What labels and conductor cross-sections must appear on the switchgear drawing?
Standard PN-HD 60364-6 requires: circuit IDs, breaker ratings, RCD sensitivity, cable type and full cross-section, PE/N bars, protective bonding routes. Omission of cross-sections drew forum criticism [Elektroda, kSmuk, post #14365769]
9. Do all lighting circuits need RCDs or only bathrooms?
From 2019 amendment, every socket and lighting circuit in residential buildings must have ≤30 mA RCD. Exceptions: emergency escape lighting and technical rooms with documented selectivity study [PN-HD 60364-7-701:2019].
10. How far can the GSW (main earthing bar) be from the distribution board?
IEC stipulates the PE conductor between them must be as straight as practical and ≤10 m. Longer runs double impulse inductance and raise residual voltage. In the thread a 7 m link was accepted [Elektroda, stachu30, post #14366607]
11. Edge case: What happens if the PE conductor breaks in a TN-S installation?
All exposed parts lose reference to earth; touch voltages can reach 230 V. Studies show 28 % of fatal shocks in TN-S homes involved open PE [CENELEC, 2018]. Quote: “Nobody will notice a break in PE; TN-S becomes a pseudo-TT” [Elektroda, Anonymous, post #14393529]
12. How do I verify earthing resistance before energising?
  1. Disconnect the PE/PEN from the electrode.
  2. Perform a 3-pole fall-of-potential test with ≥50 m probe spacing.
  3. Record value; aim for <30 Ω. Re-connect and seal the bar [Megger Guide, 2021].
13. Should phase-presence indicators be installed?
Not mandatory under PN-HD 60364, but installers add them for quick fault-finding. Cost ≈40 PLN and they detect single-phase loss faster than multimeter checks [Schneider AppNote, 2022].
14. Is a familiar but inexperienced electrician allowed to install if a certified one signs off?
Yes, but the certified engineer becomes legally responsible. Courts treat sign-off as acceptance of design and workmanship. Hiring an experienced crew reduces the 15 % average re-work cost reported by Polish insurers [PZU Report, 2020].
