Amica Tawe 6103 LSS: Program Stuck, Error E21, Water Intake, Washing/Spinning, Humming Sound
Akka932 15222 7
  • #1 16449856
    Akka932
    The program hangs, error E21, the washing machine draws water normally, but later when it goes to washing / spinning, a soft humming sound is heard.
    Can anyone help? The washing machine is 3 months old.
  • #4 16450642
    Piotr2608
    Help: 851
    Rate: 4487
    The washing machine is 3 months so it is under warranty. Writing the topic on the electrode in the non-beginners section, it can be presumed that the author after reading the user manual - page 18 cleaned the drain filter.
    ZimTech Piotr Zimny
  • #5 16450717
  • #6 16450721
    Piotr2608
    Help: 851
    Rate: 4487
    skryn wrote:
    It can be presumed that the author of the topic, like 99% of users of all sorts of equipment, did not read the user manual. These are supposedly for idiots ...
    All in all right - I have no more questions.
    ZimTech Piotr Zimny
  • #7 16450730
  • Motor brush contact issue caused E21 error
    #8 19330746
    daniel028
    I have exactly the same washing machine and the same error. The filter turned out to be clean, the pump was OK. In the motor, one of the brushes did not fully touch the commutator. Long brushes are also far from the end of their work. I cleaned the commutator scraps with 800 paper and the washing machine works as it should. Previously, I had a problem that it was not spinning the laundry and it showed error E21. The washing machine is about 5 years old. I consider the problem solved in my case.
The Amica Tawe 6103 LSS washing machine is experiencing an E21 error, where the program hangs after normal water intake, accompanied by a soft humming sound during washing/spinning cycles. Users suggest checking the pump filter for blockages, as it may be obstructed by foreign objects. One user resolved a similar issue by cleaning the motor's commutator and ensuring the brushes made proper contact. Given that the machine is only three months old, it is still under warranty, and contacting service may be advisable if basic troubleshooting does not resolve the issue.
