Amica Comfort 800 Washer: Resolving Errors E03 and E06 During/After Wash
slonyk5 96051 9
How can I fix E03 or E06 errors that appear during or after washing in an Amica Comfort 800 washer?
E03 and E06 point to a drainage problem: first check and clean the pump filter, and verify that the hoses are clear and the bypass/override valve works properly [#4895824] If the washer still counts down but does not actually work, the pump motor is likely faulty and should be replaced [#5051667][#5059899] One user confirmed that after replacing the water pump motor, the machine worked normally again [#5063691]
  • #1 4895422
    slonyk5
    Rate: 54
    Hello !!! Error E03 or E06 pops up during washing and after washing ... Greetings
  • #2 4895824
    nares
    Home appliances specialist
    Help: 1515
    Rate: 3386
    Errors indicate a drainage problem. The pump filter and the patency of the hoses to be checked - sometimes also the operation of the override valve.
  • #3 5010665
    tomciko
    Rate: 31
    I have a similar problem.
    After the error message E03 appeared, I cleaned the pump filter.
    After putting it on, the message E06 appeared and now after switching on the washing machine is counting the time but nothing happens, i.e. the washing machine is not working.
    Can I do something else on my own or after the washing machine?
    Please help.
  • #4 5051276
    slonyk5
    Rate: 54
    If I can reheat the topic, because I now have the same problem as my friend tomciko, i.e. earlier after cleaning the filter, everything was flickering, but now the error code E 06 is shown and the washing machine is standing, despite the fact that the time on the displays is running out. GREETINGS
  • #5 5051667
    asdasd11
    Help: 53
    Rate: 150
    Pump motor to be replaced.
  • #6 5052687
    slonyk5
    Rate: 54
    I see that the diagnosis is clearly defined ..... The cost is not terrifying. I found engines on the Allegro border of PLN 40. Thanks
    Today my wife did two washes and everything went flawlessly. On the other hand, the third situation repeated ... E O6 ... Pump motor at 100% ??? It may depend on the washing mode?
  • #7 5059868
    slonyk5
    Rate: 54
    Today, again, one wash at 40C went flawlessly, another at 95C ... error code E06 ...
    nares
    Help: 1515
    Rate: 3386
    A typical symptom of pump motor malfunctions - replace it at last and you do not have to buy it on Allegro, but in a household appliances store.
  • #9 5061875
    slonyk5
    Rate: 54
    After replacing the pump, the first attempt and the error E03 appeared .... what now ???
    I will do a reset and one more dress rehearsal :) Maybe there was a memory error. GREETINGS
  • #10 5063691
    slonyk5
    Rate: 54
    Water pump motor replacement and everything OK !!! Thank you so much for help. Subject to be closed. POZDO
The discussion revolves around error codes E03 and E06 encountered in the Amica Comfort 800 washer, indicating potential drainage issues. Users suggest checking the pump filter, hoses, and the pump motor. One user reported that after cleaning the pump filter, the E06 error appeared, leading to the machine not functioning despite the timer running. Subsequent responses indicated that replacing the pump motor resolved the issues, with one user successfully replacing it and confirming that the washer operated correctly afterward. The discussion highlights the importance of diagnosing pump-related problems and suggests sourcing replacement parts from local appliance stores rather than online marketplaces.
